[QUOTE=gckless;8234062]Awesome post dump pal. Also, why is "than" of importance in that sentence?[/QUOTE im waiting to see the biggest size possible for my car (pontiac g6) and im just going to get it. whatever is the largest one i can buy
Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
***Current Setup***
2006 Pontiac G6 Sedan
Pioneer avh-p4300 Head Unit
FI Sp4 15 (D1.27 ohm)
3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
Sundown Audio Saz 3000D
electrical: Optima yellow top, big 3 in stinger 1/0g
HU: JVC AVX-77 touch screen
Front stage: RE XXX 6.5" comps
front stage amp: Rockford T600.2
subs: 2 Rockford T1 12's,
sub amp: Rockford T1500.1BDCP
Enclosure: center port(designed&built by JayDubb757)
***Current Setup***
Ok, sounds like you did not have that SAZ turned up too far then, given that this amp is louder and the SAZ pulled less current. I know they are pretty efficient, but they aren't that efficient. Get a DMM, they are cheap, and set the gains well. It's not hard. But don't run your SAZ properly set on you current electrical when you get it back. There's a decent chance you will toast it again if you do. Keep it down until you can get some more DC current in there.
***Current Setup***
Op that saz is gona need more electrical that what you have currently to get it running proper....
MODS
Sorry if I am late to the party and this was already covered but I saw the pics of the blown amp bro. If one power supply fet died they should have replaced em all. They are all connected across the same two terminals that your buddy swapped the power and ground on. I would take it back and get your money back and send it to db-r . Power supply may not be operating normally even if the amp "works" . Hell some shady places nip out the one or two shorted fets and send you back on your way.
feedback and references here: http://www.caraudio.com/forum/showthread.php?t=427479
And did you say your still using the stock head unit...??!!??!?
MODS
i had this problem once, check the rca wire that connects to the plug. my saz 1500 only had one rca wired, made 300 watts at best fixed that problem and it was back to normal.
***Current Setup***
Rise does come into play if you are ussing a dmm. When you use a dmm you are looking for a set power output amount at a rated ohm level. Even if you wire the amp down to 1 ohm nominal it could be seeing impedance rise up to 2 ohms and if you use your dmm to set your amp to put out the amount of power its rated to do at 1 ohm without knowing about the impedance rise youre going to fry your amplifier
tc300 liked this post
an o-scope or a dd-1 are the only things I would use. preferably the o-scope, there is a decent one you can get for around 70 dollars that lets you find out your head unit max volume and set your gain levels but I can remember the name of it, hopefully someone else will chime in.
LOL. If you don't get it, just don't worry about it then.
Benbenondatrack,
Just giving you ****
Although, IMO, your charging system did not suffice with the SAZ-3000D, perhaps if you have a good group 31 battery in the trunk though, then just the H/O alternator you have coming will be needed. But, the more the better of course. Did you check and see what exactly that battery in your trunk is yet? 1ohm as your nominal impedance will certainly cause for some decent current draw. If/when you have that AP amplifier tuned and producing as much clean power as you'll be able to obtain, undoubtedly the SA will be louder, ONCE it has the charging system it needs to produce some powah. Takes power to "make" power; even though the SA is going to be much more efficient than the AP, being that it is twice as powerful there is no way around that.
There are a bunch of people not too far North of you, hell, send some members in Bloomington, IN some PMs (I'll look in my contacts list for the ones I used to talk to). You'll get a lesson and get what you need. And eventually you ought to grab yourself an O-scope if you plan on getting really far into mobile audio.
I have seen an aq 1200 make more power then a aq 2200 and crescendo 3k in the same exact setup...rise is a b!sh
fyi ,most loc will only get you about 1v so ur gain is gonna need to go like 3/4 or more...
gain is there for a reason...
Bookmarks
