Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
***Current Setup***
2006 Pontiac G6 Sedan
Pioneer avh-p4300 Head Unit
FI Sp4 15 (D1.27 ohm)
3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
Sundown Audio Saz 3000D
***Current Setup***
got proper amperage requirements, amps can only put so much power with below what it needs.
>>SQL<< disliked this post
Go buy a dmm set it to ac connect jt to the speaker outs on the amp and on a 50hz tone turn your gains up till ur dmm reads 38avc
---------- Post added at 07:16 PM ---------- Previous post was at 07:16 PM ----------
Acv*
are you using 0 gauge wire?
Things to look forward to:
(2) 10" or 12" imperium audio designs subs
set of PHD MF 6.5" comps
Completely seal off and deaden my doors
aquire a 2k amp
aquire a 2 channel amp for front stage
right now stock 125 amp alt, extra batt in trunk. cant remeber what kind but it was from a audioshop, it was used for their demo's..also big 3, all 0 guage from front to back also. i have a high output alt. on the way tho. and more batt. soon
---------- Post added at 10:19 PM ---------- Previous post was at 10:19 PM ----------
thanks
---------- Post added at 10:20 PM ---------- Previous post was at 10:19 PM ----------
yea
***Current Setup***
AP is greater THAN Sundown.
xShoWTeKx disliked this post
Voltage never drops below 12.9 at worst. usually between 13.4-14 volt. and it blew before because somebody put the power and ground backwards
---------- Post added at 10:39 PM ---------- Previous post was at 10:39 PM ----------
hell no, the quality of the sundown is waay beter man i love it
***Current Setup***
Oh well that's bad biz about swapping them. Are those voltages with the new amp or old? Did you set the gains properly on that amp, or just turn it up like you are doing on this one? I would think that amp would pull more than that at wide open, you may not have been seeing all of the power out of it; you might have had the gain lower than where you could have put it.
Bookmarks
