Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Guys help!!!!
  1. #16
    juanmgarza26's Avatar
    juanmgarza26 is offline CarAudio.com Elite
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    Re: Guys help!!!!
    fuse is still good
    ---------- Post added at 09:05 PM ---------- Previous post was at 09:04 PM ----------
    the fuse is between the main car battery and the isolator
    ---------- Post added at 09:05 PM ---------- Previous post was at 09:05 PM ----------
    the fuse is still good, the fuse is between the car batt and the isolator
  2. #17
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Re: Guys help!!!!
    Quote Originally Posted by juanmgarza26 View Post
    sorry to post so many questions, how exactly does the PAC-200 work? I know it isolates the battery from the main battery but i want to know what happens when the remote turns on and off... really appreciate all the responses
    It's a relay. If you know how relays work, then you should understand that. If not, basically what it does is allow current flow to/from that rear battery only when the car is on (when the isolator senses voltage from the turn-on lead, wherever that may be from depending on how it's wired), and shuts off that path to the rear battery when your car is off. It's beneficial if you play your stereo with your car off, so that if the battery powering your amps dies, you still have your front battery fully charged to start your car, which will then recharge your rear battery. Make sense?
  3. #18
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    Re: Guys help!!!!
    does it matter where the input voltage is coming from? Mine is off the remote of the head unit...
  4. #19
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Re: Guys help!!!!
    I thought you said you already ruled the isolator out? Test it by measuring the voltage in the rear with the car on.
  5. #20
    Nov 2012
    McAllen, TX
    564
    160 Post(s)
    Re: Guys help!!!!
    true never mind then haha just making things more complicated for myself -.-
  1. Which head unidt is better guys ? HElp
    By paulfrank24 in forum General Discussion
    Last Post: 01-23-2004, 04:48 AM
  2. Guys help me find a 4 channel amp...
    By kmu in forum Amplifiers
    Last Post: 10-02-2002, 12:07 PM
  3. hey guys help me out is this good deal
    By jaygeorge1979 in forum Subwoofers
    Last Post: 08-07-2002, 11:41 PM
  4. Replies: 2
    Last Post: 03-29-2002, 02:35 PM
  5. hey can you guys help me out
    By mr.cableboi in forum Wiring, Electrical and Installation Help
    Last Post: 12-17-2001, 02:57 AM
