Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Help a newb with going active...
  1. #16
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Re: Help a newb with going active...
    Quote Originally Posted by dirtboy25 View Post
    That's why I bought the 80prs... I'll go ahead and do an active 2 way and see where that puts me. Once I can use the 80prs in network mode I'll have a lot more I can play with.
    As far as getting away from the passive crossovers, how will I power the tweets? Will I need to buy a separate amp or can I use the internal amp on the HU somehow?
    I would only assume that if I use the same amp as my mids I wouldn't be able to separate them.
    You'll need 4 channels
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  2. #17
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Your lack of volume issue with the PRS80 in network mode might have been the level for each speaker. You have -25 to 0 for mids and tweets and -24 to +6 for the sub. Also SLA might need to be moved up a few clicks, I usually run mine at +2 or +3.
    I've been running active with PA stuff for several years, makes it very easy to swap mids/tweets and get them dialed in properly. I run TA in the daily but not in the demo ride.
  1. Help a newb with amp questions
    By bentz69 in forum Wiring, Electrical and Installation Help
    Last Post: 08-27-2012, 07:25 AM
  2. going active, need help with tweeter amp
    By GrnEydDvl in forum Amplifiers
    Last Post: 01-12-2007, 11:27 PM
  3. Need help going active with Rainbows.
    By lil azn 06 in forum Speakers
    Last Post: 06-24-2006, 09:27 AM
  4. Help the newb with some stuff
    By 04blackgmc in forum Wiring, Electrical and Installation Help
    Last Post: 05-30-2006, 03:18 PM
  5. Help with Going Active
    By MemphisSoul4U in forum Speakers
    Last Post: 01-24-2006, 08:28 PM
