+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: New system issues
  1. #16
    bgballin26's Avatar
    bgballin26 is offline Member
    Apr 2012
    Stillwater, Ok
    34
    Re: New system issues
    Update: I wired my sub to 1 ohm, I downloaded a 40 hertz test tone but for some reason it wouldn't play, I ended up playing a hard hitting song off young jeezy cd and adjusting my gain to roughly 31 volts, no bass boost, no sub sonic, around 80 on lpf. It sounds ten times better, no clipping issues. Now I need to figure out how to get a test tone cd to play so I can set it the proper way. And I do think my box is hurting the performance.
  2. #17
    trumpet's Avatar
    trumpet is offline Supporting Vendor trumpet is a Supporting Member of the forum!
    trumpet is a Supporting Vendor of the forum!
    Jan 2011
    Langdon, ND
    32
    1,940
    48 Post(s)
    Quote Originally Posted by bgballin26 View Post
    Ok, I did have problems finding a good spot to ground, I ended up sanding a spot close to where the 6x9's mount and using a self tapping screw. So maybe my ground is still not good enough.
    I read that you got the bass working better, but you need to fix the ground connection. Self-tapping screws are not good for amplifier ground wires. I use a bolt, a nut, and a lock washer. Also your ground location could be better. You're getting additional resistance by having the circuit path go through multiple layers of metal and welds. If you can ground it through the floor of the body near the strongest structural supports that lead up to the engine bay that's better. You'll need to be able to get to the underside to put the lock washer and nut on.
    Small town service, family owned and operated.
    Click for my CDT Audio dealer store, Clarion, JBL, Precision Power, Massive Audio, Diamond Audio, Metra, and much more
    my system: Clarion CX501, JBL MS-8, Massive Audio NX4, Xtant 1.1i, CDT DRT-26A, ES-020, ES-6MO, CL-62SL, JBL MS BassPro SQ
  3. #18
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    Maybe i could drill a hole through the floor pan in the trunk and use a rubber grommet and run the ground wire underneath somewhere? I would run another wire up to the engine bay but truth be told getting the power wire through the firewall was the hardest part and biggest headache of the install, i had to go behind the driver side fender well, poke a hole in a rubber grommet holding 50 (guessing) wires and really couldn't see what i was doing. If i can find a better place toward the rear i'm all for it.
  4. #19
    DDtC's Avatar
    DDtC is online now Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    5,958
    44 Post(s)
    You need to have the subsonic on.
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
  5. #20
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    Ok, so should i set the sub sonic at the hertz my box is tuned too?
  6. #21
    Timmy13091's Avatar
    Timmy13091 is online now CarAudio.com Elite
    Apr 2012
    Chicago
    1,895
    16 Post(s)
    No what your box to just what it peakes at .. Around 28hz I'd say U wanna be able to still hit the lows
    My Car- 2005 Ford Taurus
    Headunit- Pioneer
    Front Stage- building ..
    Sub stage- 2 Dc level 4 xl upgraded 12"s
    Sub amp- dc 3.5k (second coming soon)
    Box- ~ SMS 4 cubes 32hrtz big ole port !!!
    Electrical- Tenney 220 amp Lots of sky high 0 and some batts
    Bought from- kangaroux / underfire / Tdford05 / Marleyskater420 / Mylows10 / double 07 / Vertex Audio / Pro-Rabbit / jock hater (Sold and traded too) /underfire / marleyskater420 / keefy248 / knotdrummer / vertex audio brandonkain82
  7. #22
    Nov 2011
    Dallas, Tx/Ada, Ok
    19
    3,126
    21 Post(s)
    Op if you need any help with building the box, or need one built, or need your gains set HMU. I'm about an hour 45 from you. Always down to help someone in need
    New Car, New Build coming soon... will consist of:
    RF 360.3&Apple iPad Mini
    Tantric comps
    Sundown subs and amps
    Mechman HO alt
    Deka batts
    Knu Conceptz&Shok wire
    Audio Technix deadening
  8. #23
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    Quote Originally Posted by 04murdalanche View Post
    Thanks i really appreciate that, i have been watching youtube videos and reading articles, i used to just throw a system in and bump it, but now i'm learning how everything works and the proper way to do things, i'm very impressed with Sundown Audio, and can't believe i'm putting this much power to 1 10" sub.
  9. #24
    Nov 2011
    Dallas, Tx/Ada, Ok
    19
    3,126
    21 Post(s)
    you should check out their Z line, youll be amazed.
    Tantric comps
    Mechman HO alt
    Deka batts
  10. #25
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    I was looking for test tones and found this:
    Download Audio Tone Files
  11. #26
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    frequencies look really high on those test tones. I think you are supposed to use around 50hz or somewhere close to that, i was trying 40hz, but when i played it with my volt meter hooked up to the speaker outputs nothing was happening, until i put in a music cd then it started working. Not sure if it's something i did wrong while burning to a cd or what the problem might be.
  12. #27
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    I for sure need to upgrade my electrical, when i really crank it up with the head lights on they start dimming hard. The positive wire on the battery has a fuse built into the connector, i have no idea what this is for, but i'm sure it is needed, so i don't know about doing the big 3.
  13. #28
    bgballin26's Avatar
    Apr 2012
    Stillwater, Ok
    34
    Now that i have had some time to get used to my system i think i need to add another sub, one is just not getting loud enough for my liking. Any thoughts? This is the first 10" sub i have had in awhile, i usually rock 12's or 15's but my trunk is not tall enough to go with 12's. Would adding another 10", running at 2 ohms and having my box tuned lower (32hz) be louder than my 1 10" and 1 ohm?
    Kenwood Excelon 696
    Precision Power Phantom P1000.1
    Sundown Audio SA-10 D2 wired @ 1 ohm
    Kicker 4 gauge wiring kit
+ Reply to Thread
  1. New system installed, Sound Issues!
    By Mistadabolina in forum General Discussion
    Last Post: 05-03-2004, 11:50 AM
  2. new system coming in now Zane your input would be very helpfull here
    By stereoskitz in forum Wiring, Electrical and Installation Help
    Last Post: 03-24-2002, 06:25 PM
  3. New System Diagram
    By zane in forum General Discussion
    Last Post: 02-26-2002, 12:52 PM
  4. New System
    By GKS_UO in forum General Discussion
    Last Post: 01-31-2002, 03:47 PM
  5. wanna buy new system??
    By powerinGTI in forum Subwoofers
    Last Post: 12-31-2001, 09:03 AM
