.5 ohm vs 2 amps stapped @ final 2 ohm load(each amp @ 1ohm)
I was just curious how this works toward a electrical system. i know it can vary due to the many factors. i looked through search and found the info on those factors. but nothing on this. so really the only thing im wondering is which would have the bigger draw on electrical system?
This may be a dumb question but its something that im curious about.
thanks in advance,
:toast: cheers
Re: .5 ohm vs 2 amps stapped @ final 2 ohm load(each amp @ 1ohm)
Run higher ohms if you can.
depends on the power of the amp
Quote:
Originally Posted by
falcons03079313
why would i want to run higher ohms? im about to recone my sub to a d1 regardless because my amp is .5ohm stable. running higher would defeat the purpose of me having the 3.4k amp.
not trying to argue or be smart with you by the way
mylows10
they would be 1700 to 2k rms each for example
bgowdy31
less power more efficient
mylows10
Exactly. The higher impedance you run, the cooler and more efficient your system runs. And that makes your equipment last longer.
mylows10
this is true but again im wanting it to be loud lol. i have the amp at 1ohm right now. and the amps rated at 3.4k @ .5.
bgowdy31
if you get two 1500 wattt amps and strap them you can run 3k at 2 ohms
falcons03079313
this is true. but honestly i dont run my system hard at all daily(about 1/4 or 1/2 power tops even for a demo). comps i run full tilt for about 1min 25secs tops
bgowdy31
what amps are you thinking of buying?
falcons03079313
this is know. thats what i meant in the first post. stap to amps to 2 ohm(1ohm each). and the question being which would be less strain on elec. .5ohm or 2 amps strapped to 2 ohm.
the reason i was confused was i know .5ohm is harder on elec, and strapped to 2 ohm is a higher imp, but with 2 amps
falcons03079313
not going there because it will start a argument and i dont feel like arguing. but i will say its no audiopipe
If you make the same amount of power at either ohm load I don't see a difference in current draw. Running at a higher ohm load should place less stress on the amp though
well if you have the same power at .5 ohm as 2 ohm then your electrical will be better.
