+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 48
Reload Thread: Why you need an oscilloscope
  1. #31
    SWEETMUSIC's Avatar
    SWEETMUSIC is offline CarAudio.com Elite
    Apr 2008
    Buena Park
    1,799
    1 Post(s)
    Re: Why you need an oscilloscope
    Me too. Seems like a handy tool.
    02 4-Runner-Knwd X896-Acntrl Matrix-CDT SQA 4075 on Crssfre Separates-Massive Audio N4 on-2 RE Audio SE 10s
    90 300zx-Knwd X496-Acntrl Matrix-JBL GTO504EZ on Crssfre Separates-JBL GTO751EZ on 2 Kckr CVR 10s
    REFERENCES: BEATNOUTDAFRAME, VIVEET, CX-7HEAVEN, GMAN42, SUNDOWNZ, ZERMELO, M3NTAL, GAM3OVR, HEMI=22s, PROJECTPECKIN, KRISFNBZ, WHEELIEKING71, MR. RONIN-2U, ROBERTQ, DJM4RSHM21LOW, BLACKBONNIE, GYMFREAK101, STUCKINOK, SIACARMAN, ONEINTHESAC, 97SRAD750, ETC AND MANY MANY MORE[/FONT]
    Formerly cleansoundz
  2. #32
    calebkhill's Avatar
    calebkhill is offline Senior VIP Member
    Dec 2012
    Phenix City, Alabama
    387
    2 Post(s)
    im getting one. Someone post a link to so 0db test tones please. I cant find any.w
  3. #33
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,393
    23 Post(s)
    Quote Originally Posted by calebkhill View Post
    Make your own here:
    Online Sine Tone Waveform Generator
    These are good go-to 0dB tones:
    Realm of Excursion
    Also,
    Test Tone Collection
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  4. #34
    calebkhill's Avatar
    Dec 2012
    387
    2 Post(s)
    awesome
  5. #35
    calebkhill's Avatar
    Dec 2012
    387
    2 Post(s)
    What should i set the sample rate to on the generator
  6. #36
    marc2112's Avatar
    marc2112 is offline Senior VIP Member
    Oct 2012
    Montreal, Qc
    163
    So many assholes... so few bullets.
  7. #37
    marc2112's Avatar
    Oct 2012
    Montreal, Qc
    163
    double post... forum is laggy
  8. #38
    gckless's Avatar
    Aug 2011
    San Antonio
    3,393
    23 Post(s)
    The default (44.1kHz) is fine, or go 48kHz. Shouldn't matter too much, it's only a test tone. But for music, the highest you can get is what you want.
  9. #39
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    MI
    12,522
    81 Post(s)
    How does this prove you need an O Scope over using the DMM method? You only provided data for 1 solution.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  10. #40
    gckless's Avatar
    Aug 2011
    San Antonio
    3,393
    23 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    This thread may not show an oscope vs. a DMM, but we all know a DMM is only a guess. You just looking to improve the thread? I could see what you mean, showing an assumed 2k out of an amp vs. what it actually does via oscope, for example. That's what I plan on doing once I finally get my new build up.
  11. #41
    Mar 2009
    MI
    12,522
    81 Post(s)
    Quote Originally Posted by gckless View Post
    Just curious. This thread doesnt prove anything other than an O Scope does work. It doesnt show alternative methods do or do not work. You cant compare 1 thing against another and say that option A is better without providing data for both options.
    The DMM method is more than a guess. Its an educated guess with mathematical equations involved.
    Id like to see data from the OP using the DMM method on the same setup or from TFade.
    CA.com FAQ's
    Forum Rules
  12. #42
    Mar 2009
    MI
    12,522
    81 Post(s)
    Dbl post
    CA.com FAQ's
    Forum Rules
  13. #43
    trumpet's Avatar
    trumpet is online now Supporting Vendor trumpet is a Supporting Member of the forum!
    trumpet is a Supporting Vendor of the forum!
    Jan 2011
    Langdon, ND
    32
    1,945
    49 Post(s)
    The DMM method is OK, as long as you're aware it makes you rely on your ears to know if the signal is clipped. Both the DMM method and the oscilloscope method depend on what you use for test tones. The argument has been made a hundred times against using 0 dB tones for subs and mids. It results in disappointment because your music will sound too quiet, which is why every time this discussion comes up someone has to suggest -10 to -5 dB attenuated tones instead of 0 dB tones. Of course if all you listen to is compressed music with no dynamic range that needs to be considered as well. Use your head.
    Neither method is safe to use for setting gains on tweeters in an active setup.
    Small town service, family owned and operated.
    Click for my CDT Audio dealer store, Clarion, JBL, Precision Power, Massive Audio, Diamond Audio, Metra, and much more
    my system: Clarion CX501, JBL MS-8, Massive Audio NX4, Xtant 1.1i, CDT DRT-26A, ES-020, ES-6MO, CL-62SL, JBL MS BassPro SQ
  14. #44
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    The point of my post wasn't to compare a 'scope against a DMM. I wanted to show the kind of information that you just can't get from anything else. Look at the 2nd waveform in my first post - a DMM won't tell you something's wrong with that signal.
    I don't have DMM data because I don't use one. The 'scope gives me voltage and much more. If I had tried to set my sub amp gain with a DMM the output would have been badly clipped. My amp doesn't make rated power at less than 14.4V and my car doesn't get up that high.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
  15. #45
    Mar 2009
    MI
    12,522
    81 Post(s)
    Quote Originally Posted by maylar View Post
    Thats my point. You dont know it would be badly clipped. You have no evidence to support it and havent even tried that method.
    CA.com FAQ's
    Forum Rules
+ Reply to Thread
  1. Replies: 6
    Last Post: 11-20-2010, 07:38 PM
  2. Second Battery, dont you need an isolator?
    By silenkiller in forum Wiring, Electrical and Installation Help
    Last Post: 05-14-2008, 02:16 AM
  3. do you need an H.O. alternator
    By jaco in forum Wiring, Electrical and Installation Help
    Last Post: 05-12-2007, 12:11 AM
  4. How do you use an oscilloscope??
    By whtxblazer02 in forum General Discussion
    Last Post: 03-09-2006, 06:19 PM
  5. Do you need an amp kit for the CDA-9815???
    By quiimari in forum General Discussion
    Last Post: 04-13-2003, 10:51 PM
