Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 48
Reload Thread: Why you need an oscilloscope
  1. #16
    akillj's Avatar
    akillj is offline Senior VIP Member
    Sep 2012
    CA
    311
    118 Post(s)
    Re: Why you need an oscilloscope
    Quote Originally Posted by West View Post
    Personally I would rather be able to see the signal than trust a box with an idiot light.
    That's what I was thinking. I just didn't know which one would be preferred. What about the V2 version of this o-scope, looks a little cleaner aesthetics wise IMO. Worth the extra few bucks?
  2. #17
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by BrownVanMan View Post
    it has abuilt in test signal but you are still able to play your own through the HU right?
    Yes you need to provide a sine wave source. The test signal is a square wave, not very useful in audio.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  3. #18
    tat2bass's Avatar
    tat2bass is offline CarAudio.com Elite
    Aug 2011
    Cali
    1,680
    614 Post(s)
    You willing to rent it out along with whatever you used to produce the test sine wave?
  4. #19
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Sorry mang, not considering renting it. I use it for work as well as for my CA hobby. The source I used was just test tones on a CD.
    dave
  5. #20
    Joe89's Avatar
    Joe89 is offline Senior VIP Member
    Dec 2007
    Northern California
    268
    44 Post(s)
    Awesome... I think I will be picking one of these up A.S.A.P. I had no idea they could be so affordable.
  6. #21
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by maylar View Post
    I had a chance to play with my little DSO Nano digital 'scope and I thought I'd share what it told me about my system.
    First I wanted to find the maximum volume setting from my HU. I monitored the front speaker outputs and input a 100Hz 0 dB source in the CD player. Classic clipping at 34/50 volume. With a -5dB source I could get to 38/50. I decided that 32/50 was my max setting. Note the voltage is 24v p-p which is battery rails. This is with engine off:
    Next I checked the output of my David Navone LOC at 40 Hz and volume 32/50:
    Well now, that's a funky waveform. It cleaned up to a nice sine wave at 100 Hz but I think I'll send this to David Navone and ask him wtf.
    My final revalation was when setting the gain on my sub amp (bridged rear channels) at 40 Hz volume 32/50:
    The revalation is that with engine not running I only get 22.9 vrms = 131 watts before clipping. I started the engine and at 13.5 vdc I could get 200 watts. I did not expect that much difference. And no wonder my G3 sub barely moves...
    What a useful tool this is. Worth the 80 bucks.
    Still using this bro? Just wondering how it's holding up. Going to pick one up for my new build. Quite a bit of power, so I want to be sure I'm setting things accurately. Does the x1-x10 switch work well?
  7. #22
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    I've had he same scope for almost 2 years now and set I don't know how many amps. The 1x probe is good for ~ 80V p2p which is around 3kw. If it's got a 10x switch, you can set some big ass amps just fine. My buddy sets his 8k's with the same scope no problem.
    When I first got mine, I set my amp to "about half" like most people who don't know any better would just to see. I got this...
    No bueno. A little turn of the gain and bingo...
    I decided right then and there that it was maybe the best money I've spent in CA.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  8. #23
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Imma hafta git one of dees...
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  9. #24
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by TaylorFade View Post
    That's exactly what I was thinking. Good to see it's not something that's going to take a dump in 6 months. Was thinking about a DD-1 but I'd much rather actually see what's going on. Have you used it to test HU's? Fairly easy to use?
  10. #25
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by gckless View Post
    Yep, it's a keeper. Mine came with a nice velvet carrying pouch that keeps it safe & cozy. My only concern for durability is the tiny connector on the probe wire. It's a little coaxial plug that I've never seen before, and I dunno how it'll hold up with time so I keep it plugged in all the time. I've noticed that probes are sold separately on eBay now, so even if it gets fugged you can score a new one.
    Much easier to tote around than my old Tektronix analog scope. It goes with me anytime I'm working on my system.
    dave
  11. #26
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Good to hear man. Definitely picking this up. I want to learn more than just looking at a couple lights on a DD-1.Maybe it's just me, but I want to be more educated than that and know as much as possible about the things I am doing. I don't have the cash for a Tektronics, not to mention I don't need the accuracy it offers. I'll only be using this for car audio. I definitely feel as though this will be the most important thing I will spend a little amount of money on.
  12. #27
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    That place you got yours from still has them right? If so I'm getting one...
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  13. #28
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by Bettr n' Revrse View Post
    Amazon, Newegg, there's a bunch of places that carry them now. Just google it, you'll get a bunch of hits. Just make sure the probe comes with that x10 switch on it, but I'm pretty sure they all do.
  14. #29
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Also be aware that the DSO's firmware has been updated by third party developers (it's open source) for bug fixes and new functions. The firmware that ships with the 'scope works OK for most people, but the enhanced version is even better.
    The DSO Nano hangout...
    Seeedstudio Forum • View forum - DSO nano
    dave
  15. #30
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,448
    1499 Post(s)
    I'm gonna buy one of these
    People complained about my sig so I changed it.
  1. Replies: 6
    Last Post: 11-20-2010, 07:38 PM
  2. Second Battery, dont you need an isolator?
    By silenkiller in forum Wiring, Electrical and Installation Help
    Last Post: 05-14-2008, 02:16 AM
  3. do you need an H.O. alternator
    By jaco in forum Wiring, Electrical and Installation Help
    Last Post: 05-12-2007, 12:11 AM
  4. How do you use an oscilloscope??
    By whtxblazer02 in forum General Discussion
    Last Post: 03-09-2006, 06:19 PM
  5. Do you need an amp kit for the CDA-9815???
    By quiimari in forum General Discussion
    Last Post: 04-13-2003, 10:51 PM
