Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Line Drivers.....
  1. #16
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: Line Drivers.....
    Quote Originally Posted by hegar817 View Post
    They make a world of difference. Your amps run cooler and get more power at a lower gain. I would stick with audiocontrol products if you are going with a crossover or line driver. I forgot to mention it cleans up the signal as well.
    Wrong, and wrong.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  2. #17
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    Quote Originally Posted by bgowdy31 View Post
    yea i guess i did. but just from reading and searching alot of ppl say they are pointless. but that was my theory tho. putting those in order they did made since to me even tho ppls say other wise. **raising pre-outs = decrease in amp gain making amp work less to make power = a tad better voltage(due to amp not working as hard)**
    is this theory even remotely correct?
    I think of it the same way as HU outputs. All they determine is where you set your gain. Different pre out voltages help prevent noise IIRC.
    So, unless you're splitting a low ouput signal to a ton of Amps (in which case you'll never reach rms before clipping) you don't need higher voltages. They likely won't help U get louder or help your amps run cooler even with a lower gain setting. Gain is not volume control. If you want your amps to run cooler, given u have proper electrical, turn the volume down. Of course that's pretty useless for competition but u get the point.
  3. #18
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    <snip> but i figure adding a line drive to bring the pre-out up alittle would let me come down on the gain and the amp wouldnt work as hard to make power, which would also in theory make my voltage drop a tab better. would that be correct theory
    Nope. That's a car audio fallacy / myth. How hard the amp works and how hot it gets depends on the power level, not the gain knob position. The amp could care less if the gain is 10% or 90% to get to that power level.
    Line drivers have low output impedance and high signal voltage which makes them less susceptable to picking up noise. In a real SQ install they can be a benefit if used correctly. But for typical installs if your amp can get to full power on whatever the preout voltage is you won't notice any improvement.
    dave
  4. #19
    BassAddictJ's Avatar
    BassAddictJ is offline CarAudio.com Veteran
    Apr 2005
    FL
    12,949
    1 Post(s)
    1 Thread(s)
    153 Post(s)
    Quote Originally Posted by d77543020 View Post
    2volts is fine for almost all new amps a line driver will only help if your running lots of amps
    yes and no.....my avic n5 has something along the lines of 2v or less preamp output. My old xx-cyclops did fine at like 2/3rds gain, my audiopipe ap3k needed the gain even lower, yet my ax3200de needs the gain maxed to achieve the desired output....all in direct swap outs. Even with gain adjustments some amps are just more sensitive than others. I plan on getting a line driver for my substage with this ax amp. To be honest with you Audiocontrol is nice but not worth the premium price. I picked up a used Cache line driver w/ a clipping indicator. As long as you can see that you're not clipping you should be fine with anything.
    the flip side is now with the increased input signal, you would have to have to be more aware of where you amp level is at (assuming you use the remote like me) to avoid clipping. Alot easier to red line you amp if you've got a solid 8v signal going to it.
    so most of the time no, you don't need a line driver...unless you have alot of background noise or get lucky enough to have an amp that won't do the trick with maxed gain on a low signal.
    Past:
    Pioneer Avic N5 Navi + CD-UB100 USB Adapter. Circa '96 PPI Ax606.2 in BLACK with 2 black graphic spacers.
    CDT DRT-25 1'' Silk Dome Tweeters / CDT ES-04 4'' Midranges / RE Audio XXX 6.5'' 2ohm Neo Mids In Glassed Kick Pods
    American Power Systems 240amp H.O. Alty / (2) Deka 8a31, 1/0 front to back.
    Random Prototype 3k @ 1ohm. TRF/PSI 8 layer 4in coil Monster 15 in 3 cubs @ 33Hz / Raammat 40sqft in the trunk.
    NEW SETUP IN THE WORKS
    Quote Originally Posted by Haunz View Post
    You could put 12V to my balls and clamp my dick to get 3kW+.
    Quote Originally Posted by Slayerx View Post
    Glad this got bumped so I could fap to it again.
  1. SQ Setups - EQ's, Crossovers, Line Drivers - what to do??
    By Mark_ab in forum General Discussion
    Last Post: 02-09-2003, 12:53 PM
  2. Line Driver?????
    By iceman112 in forum Amplifiers
    Last Post: 10-23-2002, 12:42 AM
  3. Line Driver?
    By Moocow16 in forum General Discussion
    Last Post: 09-30-2002, 06:44 PM
  4. line driver? would i need 1
    By qxfosgatesvt in forum General Discussion
    Last Post: 08-15-2002, 12:08 AM
  5. Is A Line Driver Necessary?
    Last Post: 05-23-2002, 12:42 AM
