Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Reload Thread: Recommend sub size based on application
  1. #16
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Re: Recommend sub size based on application
    GCON-12 Sound Solutions Audio 12" 750W GCON Series Subwoofer - SSA STORE DVC 4ohm ,and a good amp to push it,and should sound really clean in a good sealed box/or ported
    (-NEW-) American Bass VFL 80.1 Competition Mono Amp 1000 Watts RMS W/ Bass Knob | eBay you should have the funds to get a nicely made box to keep within your budget
  2. #17
    perferd's Avatar
    perferd is offline Senior VIP Member
    Aug 2012
    windsor
    298
    127 Post(s)
    That is almost exactly what I was thinking...
  3. #18
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Quote Originally Posted by perferd View Post
    Would sound great, and you will/should be able to get the amp/sub/well,made enclosure/and wiring kit,all within your budget.Should sound fantastic, and getting your moneys worth,and if you decide to resale later, you shouldnt have any issues in my opinion
  4. #19
    perferd's Avatar
    Aug 2012
    windsor
    298
    127 Post(s)
    Probably going with the 10" gcon for box size and that vfl is one of like 5 I am looking at...
  5. #20
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    should sound great..id do a 2.0 cuft. tuned to 32 hz,will be awesome for that ten
  6. #21
    perferd's Avatar
    Aug 2012
    windsor
    298
    127 Post(s)
    Thanks...
    What exactly is the tune at 32hz? How does that change the sound compared to no tune or higher35/lower28 numbers?
  7. #22
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Thanks...
    Port tune /Different sized port tuned to hit @ lower Frequency/lower notes is my understanding.Higher Htz,louder higher pitch.if a subwoofer hitting lower than 30 htz all day, is just fantastic,imo.If you can get it tuned/ported from 30-35 htz, it should sound /hit clean and low and sound very nice
  8. #23
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    If you go with a sealed enclosure,you are not going to have to worry about that,the size of the enclosure sealed will determine the Htz range,mainly.im sure that Prorabbit/Buck,and others can give you more detail as to tuning/porting/htz/and proper spacing ect for a good sub box, as they build professionaly,as I do not.I try to go by specs, and build accordingly and get close, or for what has worked for me in the past,and still does.Ive always ran tens,they can be a quick punch ,and hit some lows as well.I generally like to see anywhere from 1.4-2.6 cu ft per 10in sub ported, and like to see anywhere from 1.0-2.0 on a sealed enclosure for a single ten.I think/feel like the sub you are getting will do excellent ported
  9. #24
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Sealed Eclipse SW8200.
    2,500+ designs since March 2011
  10. #25
    perferd's Avatar
    Aug 2012
    windsor
    298
    127 Post(s)
    Yeah I need to get some more info from the pro builders here or other sites. I don't think there are any places local to me...
  11. #26
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    These guys on here are professional, and do for a living, so you are going to get the best for your hard earned money,you may even get a cut out sheet, and build for yourself as well
  12. #27
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Quote Originally Posted by Chriszle View Post
    One of the biggest myths about woofers is that 8's and 10's are "tighter" and "cleaner" than 15's or 18's. Nothing is further from the truth. What tends to happen is that the smaller drivers have lower Q's because manufactures tend to put large cones on smaller motors to increase SPL and sensitivity but not BL product. Well unless the motor can compensate for the extra mass it has to push, then the Qts will not be the same as the smaller drivers and ultimately the driver may not be suited for the same kinds of alignments and could ring too much and compromise the perceived sound quality. Having said that, high Qts drivers are not any less "tight" or "musical" than well dampened drivers, it's just they require larger boxes and less internal pressure to prevent ringing. Ultimately there becomes a point where a driver really should be used in an infinite baffle where its actual Qts and Fs becomes the system Qtc and Fc. As enclosure volume decreases, Qtc increases and it will take a driver with a low Qts to make for an average Q system. So in conclusion, the only reason to use a smaller bass driver is for space, weight and potentially power considerations, but likewise, it is inappropriate to try and fit a larger driver into a space smaller than it is ideal for.
    Ahh, the power of CTRL + C and CTRL + V.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  13. #28
    perferd's Avatar
    Aug 2012
    windsor
    298
    127 Post(s)
    Quote Originally Posted by audiobaun View Post
    You know how much a box like that will cost and I would hate to know how much it would be to ship...
  14. #29
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Man sure dont..I either build my own, or have a local do it.Might run a thread to see what builder could do for you shipped on here, be the best bet.
  15. #30
    FlexnInLa's Avatar
    FlexnInLa is offline Huggin Them Nuts!
    Jul 2010
    Middle of Nowhere, Louisiana, USA
    45
    1,243
    232 Post(s)
    Appreciate it bit no thanks brotha...
    ---------- Post added at 03:46 PM ---------- Previous post was at 03:46 PM ----------
    That seems way too big...
    Would sound great though
    New ride... new system...
    2012 Jeep Compass Latitude
    18" Obsidian Audio Sub in a Reverse Tapered Transmission Line Box
    Box Design by Mobile Enclosures http://mobileenclosures.jimdo.com
  1. recommend me a sub based on...
    By Simek4life in forum Subwoofers
    Last Post: 12-31-2006, 01:47 AM
  2. Replies: 0
    Last Post: 07-09-2005, 03:45 PM
  3. Fuse size based on wire gauge or the amplifier's fuse rating?
    By ryanwiggum in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2005, 07:27 PM
  4. Sub choice based on musical tastes
    By Down in forum Subwoofers
    Last Post: 02-08-2005, 01:10 PM
