Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Do I want...
  1. #16
    Moble Enclosurs's Avatar
    Moble Enclosurs is offline Box Designer/Builder
    Jul 2011
    Ledyard, CT
    1,388
    34
    133 Post(s)
    Re: Do I want...
    Hey guys. It's always good to get an amp that can produce more than the subs can hold. That way you can set the gains and lower distortion at the same time. I don't know about that exact amplifier, but at the correct resistance, if the amplifier is able to produce more than the subs at rms, that is a good thing. So, say the amplifier puts out [email protected] Then, to get close to possibly 1200w out of it, the subs need to be wired as close to 1 ohm as possible. If they are wired at 2 ohms, you will get around a nominal power of half that 1200 total, not to each sub. So, at ohms n you may get about 300w to each sub on a 1700w amplifier.
    Now, regarding the SA12s taking that amount of power, say 800 each, that is possible, but the amount of time it will take that will depend on electrical rise and mechanical limits of the sub in a given enclosure. Free air is obviously less likely and sealed is more likely, to a point, while a proper ported will likely do it more justice thermally.
    All of that being said, I cannot recommend ever going over an rms spec of any driver. Hope that helps.
    Contact me for more info:[/COLOR][/I][/B]
    Mobile Enclosures:http://mobileenclosures.com
    Facebook:http://www.facebook.com/pages/Mobile-Enclosures/134158593281463
    YouTube Channel http://www.youtube.com/user/TheMobileenclosures
  2. #17
    IAD-Zak's Avatar
    IAD-Zak is offline Team IDGAF
    Sep 2012
    Florida
    406
    168 Post(s)
    Re: Do I want...
    youll fall in love with those 2 12s on that amp. i would run 6 10s though on like 3 1500s.
  3. #18
    matt_bennett05's Avatar
    matt_bennett05 is offline mattchoo!
    Aug 2009
    South Westerly Georja
    3,472
    312 Post(s)
    Re: Do I want...
    Sixteen 8" ...
    370A Alt, 220ah of AGM, 4.5K on two 8".... 300W on four 6.5".... 30W on two 1"...
    Traded with : norrizzle9, BassAddictJ (x2), TWiZTid859, btr, btdickey, mylows10, Sour_Deez, El_Weenie;
    Bought from : NeilBarber, kurtbeast, bubbagumper, cd6551,
    mistergrubbs, gbo559, ltr450racer690, nismos14, ptcmarty,
  4. #19
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Re: Do I want...
    Just remember - number of subs isn't always as important as your box/build quality. Like some others said, start small 'ish'..maybe just run 2 SA-12s like you planned and work your way up. "You live and you learn" is a huge aspect in Car Audio..the first amp I fried was a cheap Crunch amp. Looking back, I'm actually really happy about it. I'd be pretty upset had I fried a Nightshade or something of the sort.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  5. #20
    Omgstupidlag's Avatar
    Omgstupidlag is offline Junior Member
    Sep 2012
    Canton, Ohio
    14
    3 Post(s)
    Re: Do I want...
    The sub displacement (VAS) is usually on sundowns website. It's usually in Liters as well, you'd need to convert it to cubes.
    Quote Originally Posted by Montana View Post
    Well, I'm about to find out. Going to build a 5Cube box tuned at 35Hz, to run my two SA-12 D4s, (2nd SA on the way in the mail)
    I got two full sheets of MDF laying outside, and a lot of liquid nails. ;-P
    Edit: Do I want about 4.5 Cubes? They call for 2 Cube each, what about Subwoofer displacement. How much do I account for.
  1. Do I want a motorized head unit?
    By 1meanZ in forum General Discussion
    Last Post: 03-11-2003, 08:25 PM
  2. Looking for SQ~ what do i want?
    By QuadPioneer in forum Subwoofers
    Last Post: 02-17-2003, 07:33 PM
  3. Adire,Blueprint or DD. Which do I want?
    By jester73440 in forum Subwoofers
    Last Post: 07-02-2002, 07:08 PM
