Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 41
Reload Thread: Subwoofer sounds different after 10 hours of use problem?
  1. #16
    bumppinKota's Avatar
    bumppinKota is offline Banned
    May 2012
    Center Colorado
    589
    153 Post(s)
    Re: Subwoofer sounds different after 10 hours of use problem?
    Quote Originally Posted by eclipse3130 View Post
    He said check the coils and to do that you gotta open up the box, to see the wire connections I don't even have to move anything all I gotta do is look and yeah they're connected good lol.
    does he know something i dont? lol
  2. Likes TheUnderFighter liked this post
  3. #17
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    wtf are you talking about? To check the coils, you have to unscrew the sub from the box, and pull it out. Takes about a minute. To check the wire connections on the sub, you have to unscrew the sub from the box, and pull it out. Takes about a minute.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  4. Likes bumppinKota liked this post
  5. #18
    May 2012
    Center Colorado
    589
    153 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    earlier he said he would have to redo the box if took the speaker out.... now he can see the coils are fine with out a dmm?
    i need to get my eyes checked i guess. i cant read coils with out a dmm
  6. #19
    eclipse3130's Avatar
    eclipse3130 is offline Member
    Jul 2012
    Seattle, WA
    54
    37 Post(s)
    Guess you guys don't understand.. I can see the wire connections without taking the box apart. I would have to take the box apart to check the coils obviously
  7. #20
    Mar 2011
    27
    3,488
    862 Post(s)
    I guess you don't understand... you obviously would not... Unless you have some sort of very crazy box? You can SEE the wires, which leads me to believe you have a plexiglass window? But you can't CHECK the coils with a DMM, which would be the proper thing to do. 95% of subwoofer installs I've seen, it's as simple as removing the screws that hold the woofer into the enclosure, and then removing the woofer. Perhaps you do have a unique and complicated design? But I doubt that, since you said it's a simply sealed enclosure. Perhaps a picture of this complication might help us all?
  8. Likes splwj47 liked this post
  9. #21
    Flex68's Avatar
    Flex68 is offline dilligaf
    Jan 2012
    The Backroads
    1,613
    558 Post(s)
    What is your Head Unit?
    Does it have muting/attenuation settings u inadvertently changed?
    Quote Originally Posted by Spider Monkey View Post
    Romney will [fornicate] me less than Obama already has and WAY less than what Obama has planned.
    Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
    HU:Eclipse CD7200 MkII
    Subs: Fack Skar Audio
    Front comps: HAT Clarus C61-2 off Sony ES 7547
    Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
    Damping: 60mil FG panels over holes, full worx from SDS
  10. #22
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    man there's nothing wrong your like me you always listen to it loud and are very accustom to how it should sound but come winter or cooler days the air is denser and therefore heavier so output is reduced and to some a lot especially by ear.
    electrical: Optima yellow top X 2 big 3 in monster OFC 1/0g high output alt by maniac electrics
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 1 Sundown ZV4 12"
    sub amp: Rockford T2500.1BDCP
    Enclosure: ported (by JayDubb757 )
  11. #23
    Jul 2012
    Seattle, WA
    54
    37 Post(s)
    I can't remove the screws that hold the woofer into the enclosure because I have already used the box twice and I don't want to use the same holes again. And all you gotta do is pop off the wire connector cap on the side of the box to see the connections inside. Ta-da!
  12. #24
    Flex68's Avatar
    Jan 2012
    The Backroads
    1,613
    558 Post(s)
    Ta-da!
    lmao
  13. #25
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    fvck u are an idiot!
    2003 JEEP Grand Cherokee
    HU- pioneer 80prs
    Front Stage- Tantric HD comps.
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 4.5^3 32hz
  14. #26
    Jul 2012
    Seattle, WA
    54
    37 Post(s)
    Quote Originally Posted by B2WJ4.7 View Post
    Ok. Lol. Don't see how.
  15. #27
    May 2012
    Center Colorado
    589
    153 Post(s)
    do you own a dmm?
  16. #28
    Jul 2012
    Seattle, WA
    54
    37 Post(s)
    no
  17. #29
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,683
    15
    35 Post(s)
    3859 Post(s)
    Probably broke a tinsel or burned a coil.
  18. #30
    Jul 2012
    Seattle, WA
    54
    37 Post(s)
    Quote Originally Posted by hispls View Post
    Guessing it's just the colder weather last week and the density of the air like other people said, because If I broke a tinsel or burned a coil the mirror would not have the same movement, but my ears don't hear that it's as loud because of the temp/air but in reality it's still hitting the same.
  1. my subwoofer starts to smell after extneded period of use
    By Cody Is Cool in forum General Discussion
    Last Post: 05-01-2012, 08:54 AM
  2. Speakers stopped working after 3 hours of use?
    By RoachForLife in forum General Discussion
    Last Post: 08-27-2008, 10:02 AM
  3. My 2 15" hdc3 alum are blown after 3 hours of use!
    By da box king in forum General Discussion
    Last Post: 08-15-2008, 12:53 AM
  4. Panasonic CQ-C7301 turns off after 10 minutes of use
    By mutti_wilson in forum Head Units
    Last Post: 08-23-2007, 06:36 AM
