+ Reply to Thread
Results 1 to 3 of 3
Reload Thread: Are 3 ports better than 2?
    95Prober's Avatar
    95Prober is offline CarAudio.com Elite
    Nov 2004
    Canada
    1,180
    Before I get criticized, please let me explain
    Im not an expert in the science of boxes, but my box is on the smaller/average size for the 15" subs Im using. I have two 6" ports at the moment tuned to around 34Hz. I was hoping to go up to a single 8 or 10" but a custom made port shipped up here to Caanda is gonna cost me $150 plus!
    So if I added a third 6" port, which can be had up here easily for cheap and had the box tuned the same, eventhough Im losing internal space by adding another port, would I feel a difference in the bass having a different effect since more air would be exiting the box with 3 aeroports instead on 2?
    I judt feel that I could get more from the subs. They pound pretty good right now, but when I get to a certain level of volume, it feels/sounds like they peaked. Not sure the exact audio term for that
    It could be worthless to do, but I thought Id ask
    Thanks!!!
    MY SET-UP :
    Head Unit :Pioneer Premier P660 w/ card remote
    Subwoofers :4-12" Pioneer Premier TSW-1241 (Dual-Voice Coils)
    Sub Amps :2 Zenon ASB-2200.1
    Speaker Amp:Soundstream Rubicon 604 (4Ch.)
    Rear Speak Fill:6x9 Infinity's
    Front Speak:CDT (CL-641 3-Way Comps in custom kickpods)
    Wires/Cables/Installation :2 runs of 0/1 guage, Knukonceptz RCA's, battery terminals, fuseholders, and 12,14 guage speaker wire and.. The Big 3
    Sound deadening : 30sq.ft of Secondskin & 150 B-Quiet Extreme for doors etc., 200 sq.ft of Edead v.2 for floors and trunk
    Box:6 Cu.Ft @32Hz
    Refs:scottyk,Fuknmovin,Bavarian3,Blados,Blazrgreg, juckstapose,
    acousticguitar,IonSQL,SQBubble,dragnix,02parkave,
    DUMPED
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Re: Are 3 ports better than 2?
    You could use a Sonotube as your port, then add wood accordingly then "flare" it out with a router, very simple and easy to do, if you have homedepots in your area or any construction supply store, they have 6, 8 and 10" "concrete sonotubes" easy to work with I use them.
    Just a thought.
    References: BigSix,
    This industry is about innovation and setting your own path
    95Prober's Avatar
    Nov 2004
    Canada
    1,180
    Thx! yeah thats an idea too
    But for an amateur builder like myself, installing another 6" aeroport would be preferable depending if its worth the hassle over two 6" ports
    MY SET-UP :
    Box:6 Cu.Ft @32Hz
    DUMPED
+ Reply to Thread
  1. Are these better than Cvr's?
    By Bass911 in forum Subwoofers
    Last Post: 05-02-2010, 05:33 PM
  2. why are aero ports better than any other?
    By memphis_vette in forum General Discussion
    Last Post: 02-14-2008, 01:13 AM
  3. Replies: 2
    Last Post: 03-07-2004, 01:19 PM
  4. Are two woofers better than one?
    By sneekerfreek in forum Subwoofers
    Last Post: 11-08-2003, 01:05 PM
  5. Are HC's better than JBl GTI's?
    By TJD15HC in forum Subwoofers
    Last Post: 05-26-2003, 10:46 PM
