+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Kicker L7 cutting out at higher volumes?
    lrwilson27's Avatar
    lrwilson27 is offline Junior Member
    Aug 2012
    Iowa
    Icon33 Kicker L7 cutting out at higher volumes?
    I have a 12 inch kicker L7 DVC 4 ohm wired to 2 ohm in a ported box hooked up to a alpine mrx-m100. It is cutting out at higher volumes. I have messed around with the amp (reducing gain, bass boost, etc) and it cuts out at higher volumes no matter what. I have 0 gage wire running to my amp. I have absolutely no idea whats wrong with it. I have taking all the wires out of the sub, made sure there were no bad connections or corrosion, and same with the amp. any help would be appreciated. Also i had this hooked up to my alpine mrp-m450 and it hit harder with that than my alphine mrx-m100. also my head unit is a Kenwood - KIV-BT901. please help.
    Could it have something to do with the ground?
    token1er's Avatar
    token1er is offline CarAudio.com Elite
    Mar 2011
    California
    27
    1,343
    20 Post(s)
    Re: Kicker L7 cutting out at higher volumes?
    check the audio settings on ur HU
    Ca & Caco Refs: its_bacon12, acex3a, boilermaker-744, howyadoin, Ajax_6154, Pro-Rabbit, jr711, Starky, Ledoux289, AKHeathen, Dirtrider4eva, mast240, gumby688
    ThatChevyGuy's Avatar
    ThatChevyGuy is offline i heart Jager
    Jul 2006
    Arkansas
    11,799
    11 Post(s)
    got any upgrades to your electrical?
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by Spider Monkey View Post
    eat my asshole you insignificant bastard child of a retarded dingleberry cunt wrinkle fuck toy
    Quote Originally Posted by subzero View Post
    her pussy better be that nicest pussy you ever ever ever had. she better suck, swallow, jack off, eat ass and snatch, make sammiwich, do yard work and fix the vehicals while nude. Because a bitch like that is definately gonna cause alot of stress in your life, even thou she keeps your wallet and your balls drained.
    Quote Originally Posted by 05fronty View Post
    bitch you better swallow and not make a mess
    lrwilson27's Avatar
    Aug 2012
    Iowa
    Quote Originally Posted by token1er View Post
    i have. the bass is turned almost all the way down and i can barely hear the sub but it still cuts out at higher volumes
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,405
    28 Post(s)
    Are you certain it's wired properly as a 2 ohm load to the amp? Checked with a DMM?
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
    lrwilson27's Avatar
    Aug 2012
    Iowa
    nope. no electrical upgrade. i have a 2005 impala.
    Jul 2006
    Arkansas
    11,799
    11 Post(s)
    you might need a 2nd batt like a shuriken or kinetik
    REFS:
    lrwilson27's Avatar
    Aug 2012
    Iowa
    Quote Originally Posted by TheUnderFighter View Post
    yep. it is wired properly. i used the kicker diagram to make sure. and yes, i have checked it with the meter.
  9. #9
    lrwilson27's Avatar
    Aug 2012
    Iowa
    also i know that everything i have is wired properly. i dont know if to much power is going to it or what. it only does this at higher volumes. i need your help.
  10. #10
    Mar 2011
    22
    3,405
    28 Post(s)
    All bass boosts should be off, always. Make sure the gain is set appropriately, do you know how to set your gain, with a DMM? If not, google it, and do it.
    It's weird that even when you have everything turned real low, and the sub is super quiet, it still cuts out as you turn up the volume. Leads me to think something is wrong with the amplifier. If it were the sub, I think it would not be playing at all.
    And I don't think it's related to a weak electrical system. It's only 1kW, and a rather efficient amp, it shouldn't be any problem.
    What head unit are you using?
  11. #11
    VWGolfMKVI's Avatar
    VWGolfMKVI is offline StarrMountainSoundNutHugr
    Oct 2005
    Minot, North Dakota, United States
    972
    2 Post(s)
    Sounds like a bad ground. Recheck your ground on the amplifier.
    StarrMountainSound Nuthugger Team Member #1
  12. #12
    lrwilson27's Avatar
    Aug 2012
    Iowa
    Kenwood - KIV-BT901
  13. #13
    DbDesigns's Avatar
    DbDesigns is online now CarAudio.com Veteran
    Nov 2011
    mora minnesota
    4,317
    69 Post(s)
    troll?
  14. #14
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,046
    360 Post(s)
    sounds like an amp issue not sub
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  15. #15
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    Amp problem
+ Reply to Thread
  1. Kenwood Amp cutting out at higher volume
    By lindeman in forum General Discussion
    Last Post: 07-30-2011, 09:31 AM
  2. sub cuts out at higher volume
    By couragewolfe in forum Wiring, Electrical and Installation Help
    Last Post: 12-29-2010, 11:42 PM
  3. HELP kicker L7 cuts out at medium volume and buzzes
    By wanderlust22 in forum Subwoofers
    Last Post: 07-19-2009, 11:52 PM
  4. subs cut out at higher volume
    By pvtrobtoy in forum Wiring, Electrical and Installation Help
    Last Post: 05-02-2007, 06:11 PM
  5. Why is my sub cutting out at higher volume??
    By 97JeepTJ in forum Subwoofers
    Last Post: 06-20-2005, 05:36 AM
