2012 Nissan Versa Hatch
head unit/processing: 80prs
Speakers: ????
highs amp:American Bass PH4100fd
bass amp: American Bass PH4000md
sub:American Bass HD 12d2
wiring: knu all around
batts: soon to be XS d1200 and 2 D5100s
Alt: DC Power maybe gotta cross reference some stuff
WHY THE F DOESNT AMERICAN BASS MAKE COMPONENTS???/
Thanks. I decided to re-word the original post more carefully in hopes it might help anyone who may find this thread in the future understand the question
originally posed. The issue has been cleared. I believe there was some confusion on my part believing that a mono-block had to be 1 ohm stable in order
for optimal performance, but it was more likely in reference to the particular class d mono-block he was suggesting I need... Whether some mono-block
amps are better or ''work out'' the operation of single channel processing more efficiently than others, I'm going to have to assume he meant that in
reference to higher grade models on the same token as to avoid lesser grade ''questionable'' less expensive models. Thanks again everyone.
I just prefer it. I don't think I'm anymore important than anyone here, most people here are more knowledgeable than me and I also look up
to them for advice. If it annoys anyone I apologize. Actually I have a 26" monitor and it's easier for me to read. End of story, pretty much.
James 1:2-5 2 Count it all joy when you fall into various trials, 3 knowing that the testing of your faith produces patience. 4 But let patience
have its perfect work, that you may be perfect and complete, lacking nothing. 5 If any of you lacks wisdom, let him ask of God, who gives to all
liberally and without reproach, and it will be given to him.
He may have been referring to amps, such as the MRX-M100 which states that it is 1 ohm stable, but only produces 500w @ 1ohm where at 2 ohms it produces 1000w. I don't know, all i know is that mono block = 1 channel.
Nicholas Frazier | MECP Advanced
iNNovative Concepts
Why does amplifier distortion matter since on average most speakers have 3%, or more, distortion due to their design? 1% is a CEA standard designed to level the playing field whereas .00000001% THD+N is a marketing standard designed to sell amplifiers.
What next, are we going to start an argument about damping factor?
I used to swear by old school car audio gear, now I swear at it!
I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
2004 mercury mountaineer
Hu Kenwood excelon x996
Fronts Incriminator audio comps
Front amp Aq 120.4
sub amp Aq2200d
subs 2 sundown sa 12's @ 32hz
wiring knu 1/0 ofc
gunz4me2 liked this post
Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
HU:Eclipse CD7200 MkII
Subs: Fack Skar Audio
Front comps: HAT Clarus C61-2 off Sony ES 7547
Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
Damping: 60mil FG panels over holes, full worx from SDS
@NFrazier
Hmm..the wording in this little article is surely similar to the questions that have been raised in this thread....google monblock car amplifier:
Monoblock Amplifier - The Enthusiast's Choice in Car Audio
"Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
we have not even began discussing 4ohm THD vs 1 ohm thc, i mean d. IIRC, industry standard measurements stop at 2ohms due to the levels of distortion present at low power levels at 1 ohm. I read someplace where a common class D monoblock can produce 25+% THD at 1 ohm power I am asking, as not spread dis info, but to know if anyone has benched and can confirm.
Mono=single channel.(does not require a certain ohm, even if it has multiple + and - outputs it is still 1 channel)
There are several variations of them from Class A/B to D to X. Each has their own pros and cons.
Different manufacturers build their amps to be "safe" at different ohms. Some will be 4, others are 2, others are 1, and companies like MMats have some rated for .5 ohm.
Their topology and materials/parts used will influence the amount of efficiency they have at any given voltage or ohm.
What if C A T really spelled dog?
Front amp Aq 120.4
sub amp Aq2200d
wiring knu 1/0 ofc
Lol. No but it owns the dog.
Front amp Aq 120.4
sub amp Aq2200d
wiring knu 1/0 ofc
@ewadz3006 , did you understand the original question in this thread?
Most cats do run the show, from my experience...kinda like a woman. When you pet them, they can be purring one minute and bite you the next.
Quackie I don't know if op had a question, a statement, or a relapse. Fact is i cant make heads or tails from any of it, like i said in the other thread i feel dumber after reading it.
As far as women go, i dont usally get them to purr i just get bit. But i guess i like it.lol
Front amp Aq 120.4
sub amp Aq2200d
wiring knu 1/0 ofc
brooklynjoy2008 liked this post
Stop typing in bold, only @denim ; can do that
welcome toWhere b-stock is the new a-stockTEAM WEST
denim thanked for this post
Bookmarks
