+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 57
Reload Thread: Mono-block amplifers fact and fiction
  1. #16
    cal's Avatar
    cal
    cal is offline CarAudio.com Elite
    Mar 2011
    38
    761
    23 Post(s)
    Re: Mono-block amplifers fact and fiction
    Quote Originally Posted by whitedragon551 View Post
    Class D are more efficient at lower ohm loads than Class AB, but at high ohm loads that isnt true. Also Class D amps sound just as good as Class AB if you buy a quality Class D amp.
    well, ive been doing some research and have not seen many of these amps you speak of with less than .1 thd and before the class d most amps were .05 or less . again its just a simple comparison and not saying newer amps are not as good. for example my audiosystem amp is considered a higher quality amp and its @1. thd so go figure .
  2. #17
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    21
    2,519
    6 Post(s)
    Quote Originally Posted by cal View Post
    and this is why u buy an amp with head room
    an amp that puts out 100w at .1%thd isnt really bad spec wise if u are using 50w which could possibly be the .005%thd you are talking about if you remember in the past alot of amp were seriously underrated and since they were rated for 50w at .005% but actually push and were used at 500w what do you think happened to the amps thd when it was driven harder? it when up of course
    2012 Nissan Versa Hatch
    Going back to stock
  3. #18
    Jan 2007
    any wet spot i can find
    3,282
    50 Post(s)
    The advancement of technology in the power supply switching devices is just beginning to allow the best Class D's to approach so so Class A/b THD levels at higher frequencies. There again it depends on how the manufacturer presents the rating. Example: .08% at 1watt/4ohms or <1% at rated 4ohm power ...I interpret that little <1% as meaning they had rather not discuss that aspect of their design.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  4. #19
    cal's Avatar
    cal
    Mar 2011
    38
    761
    23 Post(s)
    Quote Originally Posted by winkychevelle View Post
    nope i dissagre do you remeber when fosgate and a few others had birth sheets? if they did not meet the thd they did not pass . i have a few old birth sheets that show true power not underated and meet thd ratings . im not going to argue this as it does not help op and this is the 3rd time i say it newer amps are not bad just not the same thd as older class ab is all .
  5. #20
    Jan 2007
    3,282
    50 Post(s)
    What do you think of the Class G/H ?
  6. #21
    Jun 2009
    Ponchatoula, La
    21
    2,519
    6 Post(s)
    and yet the birthsheets where measured at 4ohm on a perfect 14.4 electrical and with a resistor load. i agree the old amps were built like tanks but look at the money paid for them back then and now factor in inflation and look in that price range.
    personally i wont run a high current amp in my car from the 90s but to be fair the fosgate powered 12 i just put in my car has a 300w high current amp built in its running at .5 bridged straight from fosgate
    Going back to stock
  7. #22
    cal's Avatar
    cal
    Mar 2011
    38
    761
    23 Post(s)
    Quote Originally Posted by quackhead View Post
    to be honest ive been doing more research on my mono amp so i dont know what that is . also when i look to buy something i do alot of research. dont get me wrong im no engineer, i just goggle before i buy and do alot of reading . back in the day when class ab was the only thing around and most decent amps pretty much carried the same price tag what seperated them was the the thd and rms ratings .
  8. #23
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,751
    90 Post(s)
    what amp is this?
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC XL D4 12s
    Sub amp - DC 5.0K
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 1 C&D 400mr
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  9. #24
    cal's Avatar
    cal
    Mar 2011
    38
    761
    23 Post(s)
    i agree 100 percent as every amp in my car is korean built . as for the price tag u cant compair american made with korean labor. also caraudio in the 90,s was more about low power, these days its all about big power and low cost .
  10. #25
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,406
    28 Post(s)
    Not sure what your "friend in the business" was talking about. But a mono amp, is an amp with 1 channel. Most tend to be Class D. And most modern ones tend to be 1 ohm stable. It's all stated in the specs.
    Was there something you had a question about specifically?
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  11. Thanks Jaguar thanked for this post
  12. #26
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    2,605
    48 Post(s)
    Quote Originally Posted by DCtC View Post
    The good full range class Ds are good. JL HDs, ZED, Alpine PDX, Hertz to name a few. I feel something is missing but most audiophiles love them
    I have a Kenwood Excelon XR-4S (it's a 120X4 class d) that I let sit around for months without ever hooking up (other than to test when i bought it off craigslist). Figured it would sound like crap on the highs. I finally hooked it up.... and was blown away. Sounded as clean as my Eclipse, and has 3x's the power. And it's tiny, to boot.
    HU: KDC-X994
    Front stage: Phd FB 6.1PRO KIT, Active
    Sub stage: 1st gen RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: Mmats D300hc
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  13. #27
    Jun 2009
    Ponchatoula, La
    21
    2,519
    6 Post(s)
    Quote Originally Posted by rebelfromva View Post
    what amp is this?
    its the amp built into the p300-12 and p300-10 loaded enclosures i popped the sub out to set the gain and was surprised to see a .5ohm voice coil and a two channel amp bridged still is pretty efficient though 30amps of fusing and im only using 10guage knu speaker wire for power and ground run straight to the batt for no bad ground problems
    Going back to stock
  14. #28
    Jun 2011
    VA
    3,751
    90 Post(s)
    hmmmm. I'd like to see pics of this
    09 Cobalt LT
    Sub amp - DC 5.0K
    TEAM DC AUDIO
  15. #29
    Jun 2009
    Ponchatoula, La
    21
    2,519
    6 Post(s)
    if i happen to take it back out soon which hopefully the car will be getting a headunits shortly and i will need to reset the amp anyway ill take a pic of it. its literally just two pcb boards with transformers and such on it no heat sinks. i suspect the amp would blow before the sub.
    the loaded enclosure isnt really loud but its ok for my daily driving im planning on a ia flatlyne in a custom ported box and an ia 5.1 and 3.4 with the ia comps but the 3.4 is still in the works so this is just to hold me till then
    Going back to stock
  16. #30
    srb's Avatar
    srb
    srb is offline Senior VIP Member
    Jun 2011
    Lake County, Florida
    292
    Why are all the op's posts in bold?
+ Reply to Thread
  1. Replies: 15
    Last Post: 05-28-2008, 11:36 PM
  2. Replies: 24
    Last Post: 02-19-2002, 11:34 AM
