+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Amplifier output power vs. electrical system input voltage
  1. #16
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    Re: Amplifier output power vs. electrical system input voltage
    Quote Originally Posted by CAT MAN View Post
    I like when amps are rated @ lower voltages as well.. Prime example is DD. If ur electrical system is top notch then u will get even more power out of the said amp. If its rated at a higher voltage m say 14.4, youwill have a hard time keeping any car maintaining a 14.4 under full load conditions,
    his first post retard. i was explaining you wont gain anything from higher voltage from DD. maybe you should read first?
    you really dont kno wtf ur talking about thats it its official.....
    @TaylorFade .....
  2. #17
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Quote Originally Posted by BIGJEFF64 View Post
    i agree DD amps are somewhat impressive but by far not worth the money IMO
    this is where i would disagree.
    if i was doing a setup that needed the car off and i ran 14v batts. best believe DD is my ish. If i had a lil extra cash and wanted some good power for daily its my ish.
    ---------- Post added at 04:06 PM ---------- Previous post was at 04:05 PM ----------
    Quote Originally Posted by Imtjnotu View Post
    @TaylorFade .....
    yeah what do i know. im only fooling with DD on a daily basis.
  3. #18
    BIGJEFF64's Avatar
    BIGJEFF64 is offline CarAudio.com Elite
    Nov 2009
    GAINESVILLE, FL
    597
    10 Post(s)
    sh1t just got technical
    when someone has a 2k at 13.8V and only gets 1600 clean power at that voltage but he only is gettin 3V input signal voltage cuz teh amp like 5v or higher
  4. #19
    BIGJEFF64's Avatar
    Nov 2009
    GAINESVILLE, FL
    597
    10 Post(s)
    i dont think DD is worth the money i know they make a killer product but danm
  5. #20
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    its just like sa Dc aa blah blah blah . all have their own stronghold and outragious price.
  6. #21
    Imtjnotu's Avatar
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    supposedly fools with DD on a daily basis HAS AN MB QUART AMP
  7. Likes 05trailblazer liked this post
  8. #22
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    i cant afford to run hem and i love my mb 4 channels . but everyone in the franklin county cruisers run them and i help install/tune/seqs with them. you really have no clue what you're talking about now.
  9. #23
    emilimo701's Avatar
    emilimo701 is offline CarAudio.com Elite
    May 2010
    Boston, MA
    756
    Quote Originally Posted by Julian View Post
    there are two different types of regulation in amp power supplies and one type in the amp itself-----in the power supply there is input regulation and output regulation-----and there is degree of regulaton----input regulation means that the supply is designed to operate over a certain range of supply voltage---for example 10 volts to 16 volts----this means that the amp should perform well no matter what the supply is----now the degree of regulation determines just how good the amp stays within spec throughout that range----some amps are very tightly regulated and some are not at all and loose power at the lower voltages---as far as input regulation i would opt for good regulation-------power supply output regulation refers to the ability of the amp to maintain its rail voltages at a fixed voltage as the amp is called on to change from no load to full load----this factor determines more than any other thing the dynamic ability of the amp----if the supply is tightly regulated the amp will have the same continuous power as peak transient power----if it is loosly regulated the amp will have the ability to produce undistorted musical peaks much higher than its continuous rating----- for this spec i would always choose the least regulation if the continuous power was the same between two amps-----the problem is most people don't know the difference between the two and seldom is it specified------there is a third kind of regulation-----this is output signal regulation and it indicates the ability of the amp to maintain a constant output regardless of load------this spec determines damping factor------as long as this spec is 30 or higher it is more than adequate.......
    by the way---there are no totally unregulated amps in either of the three catagories if the amps have switching supplies (meaning over 50 watts per channel)--some amps are just more tightly regulated in some areas than others--- an unregulated amp would never work in a car at all
    This was exactly the type of answer I was looking for. Some of the stuff you said was familiar such as rail voltage, but for the most part it's all new to me.
    So what I'm understanding as the main takeaway is that although the output power might fluctuate slightly, it is the goal of most amp manufacturers to have the power supply input regulation to be as tight as possible. Right?
    Since it seems like most cars' alternators, mine included, seem to hover around 13.8 volts, I feel that companies should measure their advertised specs at that voltage.
  10. #24
    emilimo701's Avatar
    May 2010
    Boston, MA
    756
    Corollary to the takeaway: if you get x amount of wattage out of an amp at a particular voltage, say 13.8, you shouldn't really expect your music to be louder if you suddenly increase your voltage to 14.4 or higher.
    Right?
  11. #25
    TaylorFade's Avatar
    TaylorFade is online now I fail.
    Dec 2009
    Baton Rouge, La.
    2,627
    131 Post(s)
    thats what he said idiot....DD makes power on 12v and makes a crap ton more on 14v......do u even read or u just quote people saying garbage
    dd is under rated anyway from 12.8. so you may see an extre 5-600 and think its from voltage. im around alot of DD from the franklin county cruisers. i have some experience
    I'll chime in here.
    DD rating their amps at lower voltage is good for two reasons. First, it helps with competiton ratings And more importantly, it gives you a much better idea what you'll actually see on a 12v system.
    It is true that DD's (well, at least the M3a) don't like much over 15v, they certainly make more power at higher voltage. they don't open up like some *coughD5cough*, but obviously they benefit as evidenced by my testeing last weekend.
    DD M3a
    - 3,657w @ 11.2v
    - 4,088w @ 13v
    400+ watts isn't earth shattering, but that is only a 1.8v difference. If you can hold 14v, you're looking at a 1k difference. And in the world of SPL, that 400w was worth .8 on the TermLab.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  12. #26
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Quote Originally Posted by TaylorFade View Post
    I'll chime in here.
    DD M3a
    - 3,657w @ 11.2v
    - 4,088w @ 13v
    /dd TF im calling you
  13. #27
    Julian's Avatar
    Julian is offline CarAudio.com Elite
    Aug 2010
    KC,MO
    805
    7 Post(s)
    With the huge amplifiers that are out now a days can draw huge amounts of current without batting an eye. So most reputable companies will rate at 12-12.4 or so volts because dropping below that 13.8v is extremely easy. The good thing about rating at 12v is that if you can stand to stay above that the amplifier will have higher output.
    you can do some simple math to figure this out, however it's not 100% perfect because I am not account for efficiency
    lets say you have a 1500w amplifier
    Watts/volts = amperage
    so
    1500/12.4= 121 amps rounded up
    so we take the same amount of amperage times a higher voltage, say 13.5v and we get
    13.5v*121= 1633 watts
    1633-1500= 133 more watts..
    you see with the lower spec rated at 12v we get slightly more power.. and this can help a lot in the competition lanes. The gain can be much more but that's dependent on the amplifier.
    and we can use some more math to find out how much of a change that would be...
    L =10log (P/Pref)
    P=new power
    Pref= original power
    L =10log (1633/1500)
    10 log(1633 / 1500) = 0.368949257 dB change.. It's completely inaudible but could be the difference between a win and a lose.
    The difference in bigger amplifiers you will see a manageable difference... but overall in a daily situation it doesn't mean much.
    Oh and that's not account for power compression.. blah blah blah.
  14. Thanks emilimo701 thanked for this post
+ Reply to Thread
  1. Is this too much power for my electrical system
    By pudgewack in forum Wiring, Electrical and Installation Help
    Last Post: 02-24-2004, 04:14 PM
  2. Input voltage and amp output
    By badboyzx2 in forum Amplifiers
    Last Post: 01-05-2003, 12:14 AM
  3. Replies: 15
    Last Post: 12-20-2002, 08:10 PM
  4. Power vs Voltage
    By Phatillusion in forum General Discussion
    Last Post: 09-29-2002, 11:19 PM
Tags for this Thread
