Results 1 to 10 of 10
Reload Thread: Fitting an AQ 18" in a trunk properly
    JoeK's Avatar
    JoeK is offline CarAudio.com Elite
    Apr 2012
    Ringtown, PA
    23
    1,055
    412 Post(s)
    Is this doable in a 2003 Pontiac Bonneville? All i know right know is that my trunk height is about 18" for the box.
    My goal is to fit the AQ+box into $500 all properly specced.
    HDC3 18" copper coil
    jolly_26's Avatar
    jolly_26 is offline Senior VIP Member
    Sep 2011
    New Zealand
    432
    103 Post(s)
    Re: Fitting an AQ 18" in a trunk properly
    at a guess I would say it probably won't fit.. an 18 takes a lot of airspace, and I know that in my car with quite a large trunk I can only just do a proper ported 15" or pair of 12s.
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,692
    29 Post(s)
    1135 Post(s)
    Well, go measure your trunk out and I can tell you.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    skylineTT's Avatar
    skylineTT is offline bass=sekz
    Jun 2007
    Houston/Dallas
    4,187
    715 Post(s)
    It can be done.
    Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    IF, it wont work how much you want for the sub seeing im scrapping my 4th order wall project and go with 2 hdc3 18s? lol
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
    mazdakid's Avatar
    mazdakid is offline CarAudio.com Veteran
    Oct 2004
    illnoise
    34
    11,428
    7 Post(s)
    1345 Post(s)
    I have an 18 in my civic and only have about 15.5" of height for my box. I use 3 or 4" of my spare tire well to fit the extra height needed.
    06 altima sedan
    Alpine 9887
    Sax 125.4 selenium 6.5s SEAS Prestige 27TAFNC/G
    Dd m4 2 15" fi n2
    traded-pickup1, power-fanatic07, fbi90909
    sold to-superspank, dumple, JoeRa22, sub-FATHER, TrlcKed_OuT, rosrock, dcole18, RaiN, BassAddictJ, tommyk90, MANTI5, Micah_Jones, mrflamboynt, g6ryder, rebelfromva, n8skow, crxbmpn, xr650jkallen, thewes
    assassin1840's Avatar
    assassin1840 is offline CarAudio.com Elite
    Aug 2011
    mi
    1,214
    161 Post(s)
    Quote Originally Posted by mazdakid View Post
    been thinking about doing my two 12s in a fourth but if i cant get that to work. i wanna do a sundown z3 18. glad to see you can do an 18 in a honda trunk lol
    97 civic ex new build coming soon. head unit poineer premier 690 fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp dc 5k? maybe 7.5k sub stage 2 diamond audio d9 15d2s lwire stinger zero gauge & 4 gauge 3 c&d 102ah batts, kenitik 800,200 amp alt mechman
    http://www.caraudioclassifieds.org/forum/itrader.php?u=12942 http://www.caraudio.com/forums/itrader.php?u=1010415 and many more
    JoeK's Avatar
    Apr 2012
    Ringtown, PA
    23
    1,055
    412 Post(s)
    18"H (top to bottom)
    55"W (left to right)
    56"D (front to back)
    My trunk isnt a square though, its wider at the back but only about 20 inches in, for example.
  9. #9
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    either upfire or do angle front face.
    I run a single HDC4 18 in the trunk of my altima, had to cut out some metal to make it fit...
  10. #10
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    If you fire the sub up and port to the side it will work.
  1. Would an AQ HDC318-A in 14.4 cuft trunk using IB work?
    By mcsoul in forum Enclosure Design & Construction Help
    Last Post: 07-08-2008, 01:32 PM
  2. 18" BL in a trunk
    By mikey060 in forum Enclosure Design & Construction Help
    Last Post: 06-23-2007, 01:39 PM
  3. 3 ED 19ov.2 18's in lincoln trunk?
    By DeViOuSoNe in forum General Discussion
    Last Post: 12-08-2006, 12:22 AM
  4. Replies: 11
    Last Post: 08-04-2006, 01:29 AM
  5. 18" mt in civic trunk?
    By Chriscivic in forum General Discussion
    Last Post: 06-29-2006, 09:44 PM
