Results 1 to 11 of 11
Reload Thread: Do i have enough poweR?
    Luminar's Avatar
    Luminar is offline Junior Member
    Mar 2004
    florida
    Icon32 Do i have enough poweR?
    I wanna get 2 rockford 10s that handle 100-500 watts RMS and 1000 peak at 4ohm, im getting a rockford amp to drive them that puts out 425 watts 4ohm stable and i wanna know if im putting enough power through to these subs, and will i need a 2nd alternator/battery?
    Pl8er's Avatar
    Pl8er is offline Can you solve it?
    Dec 2001
    Columbus, OH
    36
    4,893
    1 Post(s)
    Re: Do i have enough poweR?
    Sounds just fine to me. You could run it at 2 ohms and most likely get more power out of the amp. Just wire the subs different. Of course I'm assuming that these are dual coil subs. All kinds of ways to do it if so.
    As far as needing another alt/battery? Na, I really doubt it. Maybe if your car is really old or your alt/battery is almost dead you could replace with new but I'm running 350 rms to my sub and 200 to my comps and everything runs fine. I do have a cap but I have run without and was still just fine.
    I think you will be ok.
    NEVER buy from Dealer Cost Car Audio, ask me why
    Rainbow SLC+Tru 4.65 + RF 3sixty.2 = yum.
    Quote Originally Posted by IamDeMan View Post
    Draw away. It has already been proven with math that you are wrong. I believe math is > paint last time I checked.
    "5 midgets spanking a naked man covered in thousand island dressing, is this love too?"
    Quote Originally Posted by pitbull187 View Post
    FYI the blue wire was connected to something else. I know it was put in right b/c the guys at Circuit City put it in.
    "We never underestimate, the destructive power of change."
    Luminar's Avatar
    Mar 2004
    florida
    its a 1993 300ZX, alternator is no more then 3 years old, battery is new so i should be ok... im running it at 4 ohms kuz the subs are dual 4 ohm voice coils so why buy somethin u wont use eh? so thanks fo your input
    Pl8er's Avatar
    Dec 2001
    Columbus, OH
    36
    4,893
    1 Post(s)
    Yep, everything will work out just fine. You may want to add a cap if you see any dimming of your lights, but it seems like you will be okay. I went to JL's website and checked out your dual 4-ohm configuration possiblities and if your amp can handle it you could run 1 ohm.
    2 DVC drivers with Voice Coils in Parallel / Parallel
    Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
    Dual-6 Ohm Subwoofers: 1.5 Ohms
    Dual-4 Ohm Subwoofers: 1 Ohm
    Dual-2 Ohm Subwoofers: 0.5 Ohm
    You would run lots more power to the subs. Not sure if you can do a 1-ohm load though.
    Luminar's Avatar
    Mar 2004
    florida
    dont understand, but if my lights dim ill add a cap. they are Rockford subs and a rockford amp my stock components which are bose with teh stock stereo cept for my alpine headunit are running from the amp (50x4) in the head... as long as running it at 4 ohms wont rape my electrical system... worst comes to worst i can spend the extra what like 200? for a cap
    88k5blazer's Avatar
    88k5blazer is offline Senior VIP Member
    Jan 2004
    Texas
    30
    230
    200 for a cap? You can get them alot cheaper, i bought a lightening audio cap on ebay for like 50 bux and its a 1fared or w/e cap and i havent had ne problems with it. I think pretty much a capacitor is a capacitor but im a newb dont listen to me.
    Luminar's Avatar
    Mar 2004
    florida
    Quote Originally Posted by 88k5blazer
    well atleast i overshot, iwas expecting to pay more for it so thats good its not what i thought... save me money!!! lol ill try it out
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    It is only 450 watts, you won't even need anything bigger than 4ga wire. You will not need a cap, you will not need an alternator. Your sub will be very underpowered, so watch your gains closely and don't send the amp into clipping, if you don't know what it is go to www.bcae1.com and look around there. Good luck with your system, oh and do not wire it to anything below 4 ohms, your amp cannot handle it regardless of what anyone in this thread said to do.
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
  9. #9
    Pl8er's Avatar
    Dec 2001
    Columbus, OH
    36
    4,893
    1 Post(s)
    What is the model number on your amp? Despite what nosaj070 said, if your amp can handle a lower ohm load you will be able to get more power out of the amp. I'm not familiar with rockford amps so I am not sure how stable they are at lower ohms. I am going to go out on a limb here and say it won't be able to run a 1 ohm load though.
  10. #10
    Luminar's Avatar
    Mar 2004
    florida
    amp model number = Rockford Fosgate 851X its an 800x4 but im bridging it to 2 channel... and how underpowered is it going to be? all i want to acomplish is extremely loud... i dont give a rats *** about ghetto boom boom lookin like an idiot, i just want loud
  11. #11
    nosaj070's Avatar
    Feb 2003
    Chicago, IL
    32
    2,393
    Oh my mistake, i thought you were sending them 425 total, but its really 425 a piece, that Rockford amp should also be a little underrated, so expect about 450 a sub, it should get loud, good luck.
    AIM: nosaj070
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 07-01-2008, 12:33 AM
  2. Terminology - Please contribute
    By frozenfire89 in forum General Discussion
    Last Post: 02-12-2004, 11:06 PM
  3. Replies: 3
    Last Post: 09-24-2003, 10:37 AM
  4. Power Acoustik
    By anaranchi in forum Amplifiers
    Last Post: 08-18-2003, 12:58 AM
