Hell, even when I heard it, it was plenty loud for me lol, would take me a while getting used to that. I couldn't imagine it on 8k. I wanna trade my car in soon for something better on gas and a bit more space. My car has a huge trunk but tiny opening which *****.
I'm looking forward to seeing what these skar vvx 10s will do, get my box for them on Saturday.
Stupid Loud.
if I ever go for loud again I'd like to be in the 155-156 region with single 12''
I am protesting Skar by giving them added exposure in my signature.
Kangaroux disliked this post
yes I have already been into the 150's single 12'' on music. I held the record here till I went sq and a walled Astro took me out.
I loled at playing music at 156 with a single 12.
Cone area X cone excursion = displacement potential. Does either one of those factors dominate the other in that equation? No, not when looking at the situation so vaguely. If you halve cone excursion, you can double cone area and still arrive at the exact same air displacement potential. But, there are other factors that affect perceived loudness, either to the human ear or to a mic.
Other factors would include the enclosure, how its alignment affects freq response of the speaker, and in the case of a ported enclosure, how its efficiency affects total air displaced. Another factor is speaker/enclosure efficiency versus power available.
There is one simple reason cone area tends to be viewed as more important than excursion, its potential is always maximized. With cone excursion, your sub might have a 30mm xmax potential (or xmech if we are talking raw burps here), but you may not have a system capable of achieving 30mm of excursion. This could be because you dont have the wattage required to overcome the compliance of the suspension and enclosure. It could be because the sub does not have the motor force (BL) to overcome the damping factor the enclosure places on the cone motion at a given frequency. Or it could be because your sub does not have the cooling capability to dissipate the heat required to be generated in order to get that full 30mm in the enclosure you've placed it in. But, cone area is a constant, its potential is always at its maximum. You do not have to consider your amp size or box alignment or tuning frequency in order to get the full 18" of cone diameter out of your 18" sub. So without necessarily even realizing why many times, people tend to perceive more cone area as an 'easier' way to achieve higher air displacement.
BL. AKA, motor force. This plays the most significant role when using a ported enclosure, to burp at or very near tuning (for maximum efficiency potential). As the signal moves closer and closer to the enclosure's tuning frequency, enclosure efficiency rises, but excursion damping also increases. This is why the seemingly odd situation of the speakers moving less, but get louder, occurs. Obviously an SPL guy wants to burp very near tuning, again because over all system efficiency is at its peak. But it also means cone damping is at its peak. So more motor force is require to overcome this maximized damping. Ideally the SPL competitor will strike the perfect balance between power available, cooling capability to dissipate the heat from that power, while reaching something just slightly less than xmech of the speaker. Again since that balance occurs near tuning, a lot of motor force is required.
When we move away from discussing SPL competitions, and simply discuss what is 'louder', as in what our ears think is louder, the frequency of the sound also becomes important because our ears do not have the same sensitivity to sound at all frequencies (unlike a mic). Some guy with a single 10 tuned high might have a system that seems louder than another guy with an 18 tuned lower, because our ears are more sensitive to higher freqs than lower ones (in terms of subbass, not in general).
The resonating frequency of the vehicle itself will also affect perceived loudness intensity, to the ear and to the mic.
Multiple motors versus single motors being used. No, there is no inherent addition of perceived loudness merely because there are 'more' subs. You are not 'doubling the signal' when you have two subs. The main advantage having more motors than less is, you have more potential for cooling. More motors means better cooling means less output lost to power compression.
That's all the points I can recall discussed in this thread I wanted to clear up. But the situation is even more complex than this post implies, as I barely even touched on power compression, how it affects output, and how speaker efficiency, frequency played, and excursion affect it. I also didnt mention the space the speaker resides in also affects output. Air temp and air pressure also affect it. Speaker FS versus the desired freq to be played affect it. The location and positioning of the speaker system within the vehicle will affect it Even the levels of background noise affect the perceived output potential of a speaker system. There are not so many factors that predictions are impossible, as someone suggested earlier in this thread. But there are far more than simply comparing excursion versus cone area.
Hope this reply helps.
No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
traded-pickup1, power-fanatic07, fbi90909
sold to-superspank, dumple, JoeRa22, sub-FATHER, TrlcKed_OuT, rosrock, dcole18, RaiN, BassAddictJ, tommyk90, MANTI5, Micah_Jones, mrflamboynt, g6ryder, rebelfromva, n8skow
Yeah, and Im going to find someone to pay me $250,000 for my Avalanche. I guess I can dream as well.
i have heard 160s on music and its INSANE!
Bob P old blue van....
wow... lots of bad info here and I skipped the second pageI don't think adding up the Bl spec of the different subs is a very good indicator of anything. Bl^2/re is a much better indicator of what is really going on.
2007 Honda Pilot 2008 Nissan Maxima
2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
2 Sundown Nightshade V.2s 2 10" Atomic APX
Sundown SAX-125.2 x 2 Sundown SAX-100.4
Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
RIP Taylor aka NewAgeKing, you are missed!
I've got a shirt trick vid and pics some place I just have to find them. shocker sig and about 6000rms
of course you would, you couldn't even do it with 6 15's oh yeah that's right you didn't even break 150.
---------- Post added at 05:05 PM ---------- Previous post was at 05:05 PM ----------
wasn't he at 170 on music before he quit?
Bookmarks
