Results 1 to 11 of 11
Reload Thread: Need help from the pros...amp power vs. head unit power
    mopower440's Avatar
    mopower440 is offline Member
    Jan 2012
    chapel, TN.
    52
    6 Post(s)
    long story. I have a small 4-channel kenwood amp i always used in 2 channel bridged mode for a sub and ran my door speakers straight off the radio being it was a single cab truck i didnt need much power for the door speakers. Well, i recently bought an extended cab truck and planned to use this same amp in 3 channel mode, the front channels for the door speakers and bridge the rear channels for the sub. So it would be 16 watts to the door speakers and a bridged 45 watts to the sub.. all good except my new pioneer head unit is rated at 16 watts rms also! so, is there any point in running my door speakers off the amp then since the head unit is rated at the same wattage as the amp or would the amp still help for some reason? Here is the specs on my amp,,
    KENWOOD KAC-644 4 CHANNEL AMP
    Specs:
    Max Power Output (4 Ohms)
    4 Channel Mode: 40w x 4
    3 Channel Mode: 40w x 2 + 90 W
    2 Channel Mode: 90W x 2
    Rated Power Output (4 Ohms)
    4 Channel Mode: 16w x 4 (20HZ ~ 20 kHZ less than 0.08% THD)
    3 Channel Mode: 16w x 2 (20HZ ~ 20 kHZ, 0.08%) + 45 W x 1 (1 kHz 0.8%)
    2 Channel Mode: 45w x 2 (1 KHZ, 0.8% THD)
    Rated Power Output (2 Ohms)
    4 Channel Mode: 25W x 4 (1 KHZ, 0.8% THD)
    This amp always seemed like it put out more than its rated at, it will thump a 10" sub quite well!
    VWBobby's Avatar
    VWBobby is offline PG and SS nuthugger
    Jul 2010
    Nibiru
    36
    1,377
    170 Post(s)
    Re: Need help from the pros...amp power vs. head unit power
    Personally I like Kenwood equipment. A lot of people hate them on this forum, but I have had all good experience. I would recommend installing the amp. If nothing else, it will give you a little more control over the sound.
    '65 VW Bus
    MA Hippo 122, (2) Aura Sound 8's, (2) SoundStream 6.5 coax, (2) Alpine Type-S 6x9's [rear fill], MBQ DSC1500.1D, RF 501X
    '12 Nissan Altima - Bone Stock - Sounds good, but adding subs soon.
    '02 BMW 330xi (AWD coupe), every option - SOLD
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    I had an 1800 watt Kenwood for 3 **** years! Got 900 rms @ 2 ohms out of it. Got sick of looking at it and sold it to a buddy a couple years ago who's stil using it! So Kenwood is ok in my book. What sub are you going to run at 45 watts by the way? Seems a little anemic.....
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    The specs you've quoted are basically the same as a typical HU: 45-50 watts peak, 16-20 wrms. I wouldn't expect the amp to be a big improvement over the HU.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    mopower440's Avatar
    Jan 2012
    chapel, TN.
    52
    6 Post(s)
    hmmm, i wonder why they even would make an amp that low power when the head units are already that powerful...??? I know when i had it bridged at 45 watts to my mtx 10" it hit quite hard, sounded good..
    neonblack's Avatar
    neonblack is offline Member
    Jun 2006
    Devon PA
    97
    23 Post(s)
    45W to a sub in a car won't push a sub especially with all the road noise, etc. My $40 PC speaker sub produces more power than that.
    BnGRacing's Avatar
    BnGRacing is offline Senior VIP Member
    Oct 2004
    Chicago
    415
    22 Post(s)
    Quote Originally Posted by maylar View Post
    The IC in a HU will start to clip pretty hard at 5w. The amp will be supplying 4x that amount of power before it too starts to clip. All in all, it'll be a HUGE improvement.
    J31Rob's Avatar
    J31Rob is offline CarTune Netwerk
    Nov 2006
    Indiana
    11,243
    397 Post(s)
    Sit back and watch the blind lead the blind.
    the FUNK / facebook.com/The.Funk.765
    CarTune Netwerk / facebook.com/cartune.netwerk0
    Alpine / Sundown Audio / Sound Solutions Audio
    Audio Technix / CT Sounds / Execution Audio
  9. #9
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Quote Originally Posted by J31Rob View Post
    no shlt !!!
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  10. #10
    mopower440's Avatar
    Jan 2012
    chapel, TN.
    52
    6 Post(s)
    what is this comment refering to? Just trying to learn..
  11. #11
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    The HU amp is, as mentioned, going to sound poor above around 5W. The Kenwood amp will sound much, much better. Power ratings are generally misunderstood and misrepresented.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  1. no power to head unit
    By mjj79000 in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2008, 01:27 PM
  2. Amp or head unit? What to power with?
    By rlwingerjr in forum Speakers
    Last Post: 03-08-2005, 08:20 PM
  3. Head unit not getting power
    By pelco in forum Wiring, Electrical and Installation Help
    Last Post: 02-13-2005, 01:46 PM
  4. Too much power to HEAD UNIT?????
    By Gilliz in forum Wiring, Electrical and Installation Help
    Last Post: 11-05-2004, 08:58 PM
  5. Head unit won't power on... help!
    By subcons in forum Wiring, Electrical and Installation Help
    Last Post: 03-25-2003, 11:52 AM
