Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 46 to 60 of 169
Reload Thread: SPL with a single 8" Sub... More sound with less.
  1. #46
    thevic24's Avatar
    thevic24 is offline my silence is deadly...
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    Re: SPL with a single 8" Sub... More sound with less.
    Quote Originally Posted by SPLluminator View Post
    Or u could sell her to me
    I am going to keep the little fella....ya never know......
    I ended up going with .7cuft with 19" of port tuned to 45hz and had it running on a clamped 1600 at the time. (for burps)
    Silently stalking you through glass....
  2. #47
    thevic24's Avatar
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    In the process of building a smaller box with a bigger port . This sub is unloading extremely quickly but I did not mention that im throwing almost 2/3's of the power from a 20.1 at 1 ohm. Which is approximately what SPLaudio had rated it at (roughly 1000rms). This sub should wang with a few tricks. Ill keep you guys posted!
    8's will unload faster....smaller cone area...
    you could try using a loading wall and try and load the port some if you can. My 1508 in the above [email protected] would play good down to about 35ish...
    after that not so well at higher levels.
  3. #48
    SPLluminator's Avatar
    SPLluminator is offline CarAudio.com Veteran
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    I hear ya, I wish my cvl was a D2 so I could see the potential in it. But this new sub should be really close to where I wanna be. I just can't wait to see the look on peoples faces . Thats what its all about. My box was very similar to yours but my sub isnt liking the size so im going to be playing around with it. Im not going to spell out how im getting loud on here after that. Ill just post the numbers im achieving.
    Equipment for sale-220A alt, Eminence Delta 10" speakers, BNIB MB Quart Q4.80, (2) IA 20.1's (Newest Version), SI BM Motor w/ Basket, (2) Deka Intimidator G31 Batts, 2 RD Sonance 15's with baskets (need recone).
    Refs: Scott S, hornedfrog1985, dsmdan, Newageking, DBboom, R/T Pimp, SQcrewcab, Bumpin Buick, tangelo95, fearof85,
    coma_toast, Blackga, spy, LouisianaCRX, Oxsign, etc...
  4. #49
    thevic24's Avatar
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    The looks can be priceless!!
    The last time I had it installed, I embarrassed a fellow co-worker that had a 10w7. I am now running a 3512d1 on twice the power!
    Think its time to do something for the wife's (my car) car....
  5. #50
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    Quote Originally Posted by thevic24 View Post
    Yup, my box that was similar had very similar results as far as sound, not punchy at all, but certainly loud. Range was only probably from 35-60 that I could play tho with any reasonable power.
  6. #51
    thevic24's Avatar
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    believe it or not, it was quite punchy and actually sounded great. Just not much below 35hz.
    Keep us posted!
  7. #52
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Hey OP do you have any of your old boxes? I may try and run my single 8 for now...
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  8. #53
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    I have for sale 1.0 cubes tuned to 40hz. The most recent design show on here, I can cut off the battery tray if you wouldnt want it
  9. #54
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,633
    1275 Post(s)
    I think pete kulicki did 150 in his crx with a soundsplinter RLI 8
    getting loud with a small subs isn't that hard only problem is when you have the room for a creative enclosure people usually go with a bigger sub.
    edit: I'm also using a loading wall with my 10's to play down to single digit freq full tilt.
  10. #55
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    Single digits is totally unnecessary but im sure you get some flex. And thats impressive to get low without bottoming out.
  11. #56
    May 2007
    4,633
    1275 Post(s)
    it was just a goal, I have very little flex actually. I have the voids in my uni body filled with insulation to try and absorb as much as possible. I only wanted to play all freq with my enclosure right now it's only at high 140's on music with a DD m2 at .5 2 type r 10's
  12. #57
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    Your playing all frequencies with 2 type r 10's and your ONLY at high 140's. Sounds to me like you should be pretty happy with that.
  13. #58
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    Got the new sub in with the new sized box, ordered some aero port extensions as this one isnt gonna cut it . Pretty loud and sounds like ****, need to lower tuning a bit. Will keep you guys updated!
  14. #59
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
    when ur interested in a monster 8" let me know.
    with more work can use a 6.5" spider and taller basket and have almost 50% more usable throw...
  15. #60
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Quote Originally Posted by SPLaudio View Post
    I know a lot of org's only count subs that are 8" or larger..you should play around with 6.5" and see what you can make lol
