Re: AQ2200D will I need more?
Originally Posted by
Ninesvnsicks
I just love the way these sundowns sound, my first system ever I had 2 RF Power HX2's in my 92 Buick then in my Saturn they sounded good and these honestly keep up with them in fact they hit some lows my power hx2's couldn't. I actually just won an eBay auction for the aq2200d for $300 so I'm super excited about that however, I did have some questions.
#1 I have #1 welding cable rated at 350 amps and a 200 amp circuit breaker before the firewall, the aq2200d uses 200 amp fuses alone and I do also have a small 4 channel running my highs which has a 30 amp fuse so that makes it a total of 230 amps. Do I need to upgrade my circuit breaker? Will I trip the circuit breaker with the 230 amps?
#2 Would it hurt anything If I hooked up the aq2200d to use until I get my 2nd battery? I will probably order my xs power 1200 on Friday when I get paid, so do you think using the aq2200d for about a week with just the stock alt and 1 yellow top would hurt anything?
Thanks everyone for your help I appreciate it I also really have to start paying my credit card down now I just couldn't wait to hear what these subs can really do rofl.
Why do you have 4 batteries is the aq2200d the only amp you have atm? I can get a ho alt eventually and hopefully my friend can install it he is a mechanic at Firestone, it's not in the best location in my jeep I wish it was on the top
You should be too bad with a pair of stout batteries on that alternator, it's a better stock than most, that's for sure. If you wanna hook up the AQ2200 right away, I'd just recommend keeping the gain really low, or wiring it at a higher ohm load (4ohm instead of 1ohm) until you get that second battery in. To see full power, you're probably going to need a HO alt, which you can save up for over time. But you should be ok with 2 stout batteries for the time being.
2009 Hyundai Elantra - Budget Sound in Progress
HU- Kenwood eXcelon KDC-X994
Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
Bought from: Inferno333, select127, treesive, Kangaroux, DonH
Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
Bookmarks
