Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 33
Reload Thread: New build. :) memphis mojo 15
  1. #16
    on1wheel01's Avatar
    on1wheel01 is offline Bang A Lang
    Aug 2008
    Mooresville nc
    2,742
    Re: New build. :) memphis mojo 15
    You can take what they recomment and throw it out the door. Do what the guys on here suggest thats how youl get really loud. Just sayin.......
    And yea u shoulda done some bracing.
    REFS
    bought from nismos14,lask48180,wu501,teamsolo,thegreatestpenn, 1phatclipse,lorilee8284,Louisiana_CRX,woofercooker ,97maxima,Bad4Health
    sold to sotogrip,bobby32,rgplayer,mxer657,deathpenalty18,C ahm Rohn
    traded with grimreper912003,5cr4ppy
    1999 Durango 2 Memphis Mojo 15's Audiopipe ap3k
    4 Date Safe 75 ah batts Alpine hu. Lots of wangin
  2. #17
    XORstatus's Avatar
    XORstatus is offline CAR audio IDIOT :P
    Aug 2011
    North Carolina
    136
    I can still do bracing, Is there a link or a tread where I can read some information about bracing?
    How often should one brace under what conditions?
  3. #18
    on1wheel01's Avatar
    Aug 2008
    Mooresville nc
    2,742
    I use bracing no matter what. I use 1" dowels in my boxes. What part of nc r u in. I may be able to lend a hand I'm near charlotte. I also have a mojo 15 but have 2 if u ever wanna hear what they sound like.
    REFS
  4. #19
    XORstatus's Avatar
    Aug 2011
    North Carolina
    136
    Im south of raleigh, you're pretty far away but I appreciate the offer!
    Ive had a MOJO previously but sold it when I got my FI BTL 18. For some reason I have become nostalgic recently and I just HAD TO HAVE another one.
    My first box was designed by RADIO ACTIVE in raleigh I have no idea what it was tuned to but the guy there DEF tuned it for SPL.
    I have different desires from my audio system now so I designed a different box, one that will be tight and clean while simultaneously delivering MOJO fabled power.
    Here are some pictures of the MOJO box and then the box that I built for the FI.
  5. #20
    XORstatus's Avatar
    Aug 2011
    North Carolina
    136
  6. #21
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    31
    2,196
    22 Post(s)
    this new box has a port area of 7.3"^2 per cu......... notice both those other boxes have a better port area?
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  7. #22
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Quote Originally Posted by XORstatus View Post
    Memphis recommends 30 sq in of port area. I made that decision on their recommendations.
    Im not saying that they are completely correct, just giving you and Idea of how/where I started.
    Why do you think the port is too small?
    Im not implying that your wrong, just interested in getting a more holistic ideal.
    I was thinking of supports but I don't know the rule or guide lines of their distribution.
    If you have any Ideas about it would you please share them?
    AS ALWAYS thank you for the critiques.
    I say this based on my experience building boxes and from what I have seen others do. On a higher excursion woofer (xmax > ~15mm) a bigger port will help to increase the amount of air moved. When doing a slot port you should aim for 12-16sq in per cu/ft of airspace. A woofer like yours would be towards the upper end of that. It looks like your box is somewhere in the 3.0-3.5cu/ft range so assuming that on the low end of that figure you should have 36-48sq in and the upper end would be 42-56sq in. By having a small port you are more at risk for port noise (whistling or chuffing) because of the higher air velocity, especially if you have hard edges at the port openings.
    I like to go excess with bracing because the box can never be too strong imo. I use 2x2 or 1.5in dowls. The 2x2s are cheaper but take up more airspace.
    Some examples of how I have done it:
    and when you add bracing you need to subtract its displacement or it will throw off tuning.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  8. #23
    Corey J.'s Avatar
    Corey J. is offline Not loud enough....
    Feb 2007
    Madison,Wi
    867
    You need a router bro. Other than that , some 45s in the corners, route the port and some sort of bracing top to bottom preferred. Enjoy that sub, the new ones are not even close to their level !
    Box I just built for 2 C3 15s in a Pontiac vibe.
    2008 and 2009 National Champion SS5+
    Certified score - 165.0 dash + 165.5 in kick
    Team Kinetik
    Memphis Car Audio
  9. #24
    XORstatus's Avatar
    Aug 2011
    North Carolina
    136
  10. #25
    on1wheel01's Avatar
    Aug 2008
    Mooresville nc
    2,742
    One recommendation I can make. Try firing forward and seal it off completely. I built a box for a local customer had a nightshade v2 18 and saz3500 in a cadillac. Was so stupid loud and cut down on rattle
    REFS
  11. #26
    elancohen92's Avatar
    elancohen92 is offline F**k yeah I drive a Soul! elancohen92 is a Supporting Member of the forum!
    Jan 2011
    Silverthorne, CO
    1,265
    At most they were off by 1/16 nothing that my sander couldnt hande
    Im gonna fiberglass resin the internals SHOULD make this baby SCREAM, its tuned LOW less than 33 Hz.
    Ill keep you guys informed.
    Nope, only way is you have like 8 sq in of port area per foot. or i would say your tuned about 44-48hz at the length of your port
    2010 Kia Soul Sport
    Pioneer FH-P8000BT
    3 Sundown SA-12"s
    Soundstream Rubicon 1600d
    refs? I have refs
    Quote Originally Posted by BayAreaBimmer View Post
    And the big three are subs, an amp, and head unit?
  12. #27
    Jan 2011
    Silverthorne, CO
    1,265
    if you had proper port area
    2010 Kia Soul Sport
    Pioneer FH-P8000BT
    3 Sundown SA-12"s
    refs? I have refs
  13. #28
    XORstatus's Avatar
    Aug 2011
    North Carolina
    136
    Quote Originally Posted by on1wheel01 View Post
    I dont know what this means?
  14. #29
    on1wheel01's Avatar
    Aug 2008
    Mooresville nc
    2,742
    Fire sub and port forward into the cabin and seal the sides off with t shirts or towels. U may like how it sounds.
    REFS
  15. #30
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Quote Originally Posted by elancohen92 View Post
    This....the port length is wayy too small, if you have 30sq in of port with 3 cu/ft then youd need about 20in of port length for 33hz, it drops to 16.5 with 3.5 cu/ft, yours looks like its more like 12-13in long
    RF T1500bdcp
Tags for this Thread
