Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Build me a system!!
  1. #16
    Lowflyin's Avatar
    Lowflyin is offline Sit on my face, B*tch
    Dec 2010
    FU JOSE, PA
    1,121
    1 Post(s)
    395 Post(s)
    Re: Build me a system!!
    Quote Originally Posted by mylows10 View Post
    what year s10,i also have a s10 mines the loudest street truck [no wall or cut thru] with 2 batts i can tell you almost any thing about s 10s.also i may have an alt for you
    02, whats the stock alt size on the 4.3?
    Sold To: Epic0318, Alpine-Accord Bought From: JL Audio, SPLAudio, JS UltimateSounds, ShoelessJake
    This guys a winner...
    Quote Originally Posted by darron016 View Post
    I want to trade my amp but it is currently mounted to my trunk, how do I go about posting a picture with the date etc with it mounted? I can barely get to it
  2. #17
    Lowflyin's Avatar
    Dec 2010
    FU JOSE, PA
    1,121
    1 Post(s)
    395 Post(s)
    What kinda front stage for around 200-300 should I run?
  3. #18
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    In the newer 4.3 motors like you have you can get an alt off of a fullsize and go. I did that to my extreme and it worked great for a while. I used an alt off of a fully loaded hummer when tested it was doing 220 amps which.
    I don't see you having the room to do a bandpass with a 18 in the truck though. It is possible, but would be difficult to build because of various restrictions. I have helped with 160+ s10s in stock class...they can get loud and quickly. I'm not a fan of 18s in them, but to each their own. It will be loud regardless.
    You will need around 6ft3 net or so depending on what 18 you eventually decide to get. AQ is a great option for the budget, but SPL makes some crazy subs with great parts.
    If you need some help with a design just hit me up would happy to help you out.
  4. #19
    Lowflyin's Avatar
    Dec 2010
    FU JOSE, PA
    1,121
    1 Post(s)
    395 Post(s)
    I would like a single sub set up to keep it pretty simple. What would you suggest for sub and amp? And I will definitely hit you up when it's box time.
