Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: 05 Mustang SQ + Low Weight Questions
    nickk678's Avatar
    nickk678 is offline Senior VIP Member
    Sep 2006
    livonia, MI
    181
    1 Post(s)
    Hey guys,
    Couple quick questions for you. To preface, here is my last SQ build thread: The Build - Car ripped to shreads!
    I'm putting a system in my toy car - see below
    I have a built motor and a Procharger D1 sitting in the garage, so let me start by saying I'm trying to balance speed and sound (aka keep weight down).
    Going in to the vehicle (most from the thread above):
    Pioneer AVIC-D3
    Kicker SS6.5 Components
    Kicker zx650.4
    Kicker zx750.1
    JL W6v2
    I don't want to add 100 pounds of weight to the vehicle, so I'm trying to keep it as simple as possible. That being said, my questions are:
    1) Do any of you have experience with the 05-09 Mustangs? How much to they rattle? Where do I need to put sound deadner? I'm not tearing out the headliner and floor like I did on my last build, but I don't want a **** load of rattling (both inside and out), so would like to know where to look. I have always used Raamat in the past. Anything better value out there nowadays? Where do I need to focus on in the Mustang?
    2) I haven't found a definitive answer in all the research I have been doing on whether or not a 6.5" speaker will fit in the stock 6x8 location in the front doors. I want to use my Kicker SS's and will chop the metal on the doors if need be (as well as fabricate rings), but am curious if they will fit with no work.
    3) On my last car (similar to the Mustang, 2 door non-hatchback), I didn't run rear speakers as the front fill sounded perfect with the glass work I did to mount my tweeters. Are these Mustangs similar? I don't want to do anything other than mount the SS components in the stock locations and leave it at that. Not the best for imaging I know, but I think the D3 has time alignment and I can cheat and compensate with that.
    Thanks for any help you guys can provide.
    Nick K.
    Alpine 9855
    Kicker SS 6.5 Comps
    2 12" JLW6V2's
    Kicker ZX1000.1
    Kicker ZX650.4
    150Sqft. Raamat
    Moofs's Avatar
    Moofs is offline Senior VIP Member
    Apr 2011
    Chicago, IL
    235
    17 Post(s)
    Re: 05 Mustang SQ + Low Weight Questions
    Just a suggestions. You can probably get better components for the money. And as for the sub, why not get a 10 or an 8. Something like a DC level 2 or SA-8/10?
    that should cover your bass needs well in a good box. Or a TC sounds 8, in a small sealed box. The JL just costs so much lol.
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,016
    109 Post(s)
    7709 Post(s)
    you W6 are duel 4s and that amp is only 2ohm
    nevermind your only talking about 1
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    nickk678's Avatar
    Sep 2006
    livonia, MI
    181
    1 Post(s)
    Quote Originally Posted by Moofs View Post
    I already have the parts so I'm using them. Have already built a box as well that sits behind the passenger wheel well.
    Alpine 9855
    Kicker SS 6.5 Comps
    2 12" JLW6V2's
    Kicker ZX1000.1
    Kicker ZX650.4
    150Sqft. Raamat
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    deadener helps any car by lowering resonance. but it adds weight. for the most damping and least weight, try Second Skin Damplifier, maybe see if Ant has some Lite leftover. to squelch rattles, use CCF foam like Ensolite (the stuff with a PSA works very well). you could just coat the panels and contact areas in foam and eliminate rattles with very little weight.
    the most important thing to do to the doors is create a good seal between the front and back of the cone. sealing the holes with sheet metal is probably the lightest weight way to do that. more foam around the Kicker speakers to seal against the door panel.
    basically, closed cell foam is your friend. 1/8" thick sheets.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    BlactimusCrime's Avatar
    BlactimusCrime is offline NUT HUGGERS UNITE!!!
    Jul 2010
    Your mom's port, OH
    27
    3,061
    77 Post(s)
    shut up. kicker SS comps are really nice, (arent they the ones that come in the suit case?)
    but id focus the deadener on the deck lid and rear quarter panels, and doors
    Quote Originally Posted by loudrc View Post
    fuck you eddie.
    Quote Originally Posted by dbeez View Post
    Judge me not by what i've done but the amount of haters on my balls.
    Quote Originally Posted by CRXBMPN View Post
    you have the best user ID on teh site playa
    Refs: NateBerrier, Thegreatestpenn, mossberg385t, mfenske, plugitin, retroaudioinc, michaellane, Ge_off_me
    Feedback- http://www.caraudio.com/forum/buyer-seller-feedback/489798-bumpinboats-feed-back-thread.html#post7273394
    Moofs's Avatar
    Apr 2011
    Chicago, IL
    235
    17 Post(s)
    Quote Originally Posted by BlactimusCrime View Post
    Yeah I think they are. For some reason I thought they were the 150$ set.
    Deaden all u can. Buy stuff on the cheaper side like 2nd skin and fat mat. I think half price car audio even sells some cheap deadener. Thats where I'm prob gonna get mine. As for the mustang rattle. My friend had a sub in his 05 and the trunk didnt rattle terribly. Nothing could be heard from the inside but the outside it was obvious as soon as you got out the car.
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    You could get away with a 12 as long as you build small sealed, birch box. Wouldnt weigh much at all.
    Just deaden and seal the doors. Id probably add some deadener to the rest of the car, too. The Damplifier Pro is the best deadener out there, but the Audio Technix isnt bad either... Just a good bit harder to work with. All deadener is heavy though. Sort of a necessary evil though if you want a quiet car.
    As for components up front, as long as the doors are sealed, and the tweets are up high in the pillars or sail pannels (or even maybe in the top of the door pannel), you should be just fine without running rear speakers.
  9. #9
    nickk678's Avatar
    Sep 2006
    livonia, MI
    181
    1 Post(s)
    Hey guys,
    Thanks for the responses. I will look into audiotechnix and see how I like their product. I would realllllllly love to hear from someone who has first hand experience with this type of car though. I want to know specifically where the low points are so I know where to focus.
    Alpine 9855
    Kicker SS 6.5 Comps
    2 12" JLW6V2's
    Kicker ZX1000.1
    Kicker ZX650.4
    150Sqft. Raamat
  10. #10
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Why are you worried about weight? It's a Mustang, it's not gonna go fast anyways.
    lol, j/k
    ---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
    j/k about j/k'ing
    Get taken down to funky town
  11. #11
    slim2fattycake's Avatar
    slim2fattycake is offline rolling right along
    Jun 2008
    In the Stars
    2,192
    158 Post(s)
    check out sounddeadenershowdown.com and talk to Don there. He can guide you in the right direction with what you need. Using the right deadener for the right reason is better than just added weight. And if I was you, I'd put the audio in and listen and see if you actually need the deadening instead of going ahead and guessing.
    SPL-Lab REP
    Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and support? PM me.
  12. #12
    gunz4me2's Avatar
    gunz4me2 is offline Bat Country
    Aug 2009
    Louisiana
    45
    1,650
    93 Post(s)
    Let me think of some problem areas in my car...
    The dashboard. There is no padding under the dashboard and the dash cover will rub up against the AC vents. I recommend putting some closed cell foam under there. You can pull the instrument cluster to get to the vents on that side, but you need to pull the passenger side airbag to remove the center part of the dash. I still haven't finished foaming my dash, and I have some rattles that annoy me.
    Next, I'd recommend putting some closed cell foam in the switches in your door panels. I used 1/4" foam to stop my window up/down switches from rattling due to the bass.
    Another area to address will be your rear dash cover because that tends to resonate to the beat of the bass.
    For products, SDS as mentioned above is a great place to get deadening tiles and closed cell foam from. Don will also answer any questions you may have.
    Here is one of my prior build logs: 2006 Mustang GT Shaker 500 Replacement
    Sadly, I have no current photos of how my trunk sits because it is in a temporary setup, yet again. I was hoping to start on amp rack #4 over the holiday weekend, but that hasn't gone too well thus far.
    Lastly, you can PM me if you have any specific questions.
  13. #13
    gunz4me2's Avatar
    Aug 2009
    Louisiana
    45
    1,650
    93 Post(s)
    Quote Originally Posted by FOURocho View Post
    lol, j/k
    j/k about j/k'ing
    lol, I've been trying to source a crashed 2011 5.0 to slap in my 2006 GT... Sadly, they go for major bucks at auction.
  14. #14
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Excellent information regarding foam.
  15. #15
    nickk678's Avatar
    Sep 2006
    livonia, MI
    181
    1 Post(s)
    Thanks for all the responses guys.
    I'm very familiar with sounddeadnershowdown and made my decision on RaaMat previouslt based on that. I assumed I would dampen the doors with deadner and ensolite and maybe the decklid or parts of the rear of the vehicle. Gunz my last Mustang (also an 05) had the shaker500. The door trim panels were very annoying. I deadened the exact spots you mentioned. I left that system stock though, and I know I will find more rattle spots once I throw in the W6.
    I am not going to run rear fill - going to pick up an active crossover and run my front stage active off the zx650.4 (any recommendations? Just need something cheap that works). This vehicle doesn't have the shaker500 (no subs in doors) so I'm just going to mount the tweeter on the midrange up high in the door and hope that sounds good. If not, I can fab something up to move the tweeters up in sail panel I suppose.
    I'll post some pictures when I start working on the car this next weekend.
    Alpine 9855
    Kicker SS 6.5 Comps
    2 12" JLW6V2's
    Kicker ZX1000.1
    Kicker ZX650.4
    150Sqft. Raamat
