4000 watt electrical upgrades?
I know i need the big 3. but what else do i need what size alternator? and batteries?
Re: 4000 watt electrical upgrades?
new alt for sure. good batt in front and back
200a and like 3-4 bats. what amp do you have?
2 Hifonics Brz@2400. 2400 watts @ 1ohm 1700 watts @ 2ohm
yeah 200a alt would work well and have at least 2 deka's in the back. excessive amperage can make up to a 200a alt for me without having an extra bracket, i'd hit them up. their prices are pretty good
Quote:
Originally Posted by
double deez
other than adding about a mile of 1/0 i couldnt have said it better myself
and Nathan from excessive amperage is awesome to deal with.
Phoenix Risen
lol yeah the 0g is gonna kill you. go with welding wire, you'll save quite a bit of $$. AFAIK weld wire is OFC as well
double deez
who says that... lol
95saturn
don't give me sass, feg. groan for you
I got away with 4 extra batts on stock alt, voltage drops to mid 12's at full tilt at idle tho...
double deez
groaned back
Dcpower engineering is good. Got mine from there hsd to wait a bit tho. Mechman I hear makes good Alta, nate a excessive amperage is a good Guy very helpful. Nate along with stan from DC helped me on non alt related questions. An a Guy sells dekas for cheap in the classifieds. 200a an 3 bats should be fine.
I'd say 300aH of batteries and a 200amp alt. is a good start.
Ditto, good battery up front, minimum 2 good ones in the back and HO alt, or 4-5 batteries in the back and stock alt....depends a bit on your listening habits, the amp, and what you're running it at. Also had good experience with Excessive Amperage building my alt.
