Results 1 to 9 of 9
Reload Thread: 1995 Dakar Yellow M3 Coupe SQ Install Build Log
    MrFriskles's Avatar
    MrFriskles is offline Member
    Mar 2011
    San Diego, CA
    55
    Decided that since I'm driving a coupe 2 Coaxial HAT Imagine series 6.5" drivers will be a nice match for the cabin area. No rear fill, only 2 seats in the car anyway.
    Going to be building a box that gives some room for a second ID10. Have a professional carpenter friend working on it. Pictures next week probably. Each sub will have approximately 0.7cuft. which is 0.1cuft larger than the approx "normal" size listed on the box. Large was 0.80cuft.
    Doing a rear seat delete and placing the box between the front cabin and the rear strut brace. The space is somewhat trapezoidal so it will have a facia raised about 1" off the box with a border around 2-4" thick to disguise the parts where box doesn't exactly meet with edges of the pass through. Box edges will be packed with some sort of insulation to fill it in, carpet on both sides to make it look good later
    Components
    Front
    $220 - HAT Imagine Coaxial in Kickpanels
    Front Amp
    0$ - Alpine 3555 Bridged to two channels
    Had from previous installation
    Sub
    $159 - ID10D4V3
    Sub Amp
    $110 - Audiopipe APSM 1300
    Sub Box
    $65 - Materials - 3/4 Birch Ply
    Carpeting
    Glue
    Wiring
    $194 - KnuKonceptz
    Big 3 in 1/0
    Konfused Positive Terminal
    Negative Terminal (from Parts Express)
    Konfused Digital Power Distro Block
    16 awg Karma SS for Front Coaxials
    12 awg Karma SS for Sub
    4 awg KLMX power for Amps
    6m Krystal RCA's 4 channel
    Misc connectors, terminals etc
    The Whip
    1995 BMW M3 Coupe Dakar Yellow - 90k Miles
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    Re: 1995 Dakar Yellow M3 Coupe SQ Install Build Log
    Phase One
    Rear Seat Delete
    Temporary Install of Coaxial RCA
    Temporary Install of Kick Speaker Wire
    Install Microphone for Head Unit
    Find a Conduit for 1/0 Power Cable Upgrade
    Clean Up Old Wiring and Remove Old Speakers
    Fix Rear Deck Rattling Issue
    1/0 Negative Terminal Upgrade
    Rear Seat Delete
    Pretty simple here. I'm putting the box in the pass through space in front of the bracer bar so need to remove the seats. Pins in the middle of the seat allow the seat backs to slide out. The seat bottom just pulled out. Sides also pulled off. Removed the seatbelts in the bucket.
    This is actually the next day after I buttoned everything up. You can see the wires coming in from each side of the trunk. The wires were run through factory wire harnesses and I zipped them to the brace bar to keep them from slapping around this next week.
    Temporary Install of Coaxial and Speaker Wires
    Was going to put the KnuKonceptz Krystal RCA up the side, but decided that I am taking the seats out anyway for the 1/0 Power cable upgrade so I might as well use factory wire conduit under the seats. I wanted to get a basic idea of length so I laid the cables down the side and left plenty extra. The conduit runs underneath and is only accessible by taking the seat off. Removed the passenger under dash to get to center console and the door sill flashing... what a ***** that was to get off. Kick Panel also.
    Removing door sill flashing
    Coaxial and speaker run up left side between frame and carpet
    This is the rear of the driver side. I ran the coaxial and speaker wire through the factory harness to the rear. All of this will get covered up nice.
    This is the old RCA, but mine was run in the same fashion
    Passenger side run the same way
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    Head unit has built in Bluetooth and those things you wear on your ear make you look like a ******* tard plus probably give you cancer. Unit came with a microphone to mount into vehicle. Decided on the driver side A pillar. Ran the wire in between the dash and the pillar, not the hole pictured, but where the two come together. The run is probably temporary since Im going to take the dash out to install the 1/0 and probably do a better job on the Coaxial RCAs as well.
    Found it. Apparently the main conduit that runs from front to back is under the seats on both side rails. The old speaker connections run through the driver side while the power cable was routed on the passenger side. Removal of seats and dash is definitely going to be necessary to get what I want accomplished. Should look great when everything is routed cleanly away down there.
    Removed the older RCAs, older speaker system, several wiring harnesses related to the speakers etc.
    Everything pulled out
    Whats wrong with this picture?
    All of the older stereo stuff and wires I pulled out. Look @ the harness on the right, previous installer cut and pasted to wires into an insane arrangement to save himself some time running speaker wire to the front.
    RadioShack?
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    Mostly just exploring to see how I could fix a rattle back here. Looks like others fixed it by putting foam in the spaces between the ribs on the deck. Probably try to do the same thing.
    Got a 1/0 Terminal from partsexpress.com for like 5 bucks. Terminal seems to be of good quality, heavy duty metal and decent connections. Allen key holds the wire in there. Not sure how I like that, but if it becomes an issue I will just solder it in. This was my first solder ever. I have to do several for the 1/0 power cable upgrade so this was a good test. I installed it on the factory location until later. Today I picked up some metal screws for it so I can mount it properly onto the chassis.
    I also cleaned up the rear tire area. Looks like a fire extinguisher leaked out in here or something, all this white stuff. Could have been acid from a previous battery as well, washed it with water and baking soda to neutralize anything left behind.
    The old battery connection
    Raw Materials
    Gotta twist the end to get it in
    MMMMmmmmmm Fire....
    Finished Joint
    Clean Up
    Put everything back for the week. These wires are factory speaker and CD changer wires. Decided to roll them up and put them behind the seat since I cannot get at their entire length, they run down into the side rail conduit.
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    COMING SOON!
    Phase Two
    1/0 Power Upgrade
    Permanent Coaxial and Speaker Wire Placement
    HAT Imagine Speaker Install
    Installation of Amp Power Board
    Subwoofer Box Fitting and Tweaking
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    Saving For Phase 2 - 2
    MrFriskles's Avatar
    Mar 2011
    San Diego, CA
    55
    Saving For Phase 2 - 3
    BlactimusCrime's Avatar
    BlactimusCrime is offline NUT HUGGERS UNITE!!!
    Jul 2010
    Your mom's port, OH
    27
    3,061
    77 Post(s)
    if you take too long and too many people post in here you wont be able to edit your reserved spaces up there
    Quote Originally Posted by loudrc View Post
    fuck you eddie.
    Quote Originally Posted by dbeez View Post
    Judge me not by what i've done but the amount of haters on my balls.
    Quote Originally Posted by CRXBMPN View Post
    you have the best user ID on teh site playa
    Refs: NateBerrier, Thegreatestpenn, mossberg385t, mfenske, plugitin, retroaudioinc, michaellane, Ge_off_me
    Feedback- http://www.caraudio.com/forum/buyer-seller-feedback/489798-bumpinboats-feed-back-thread.html#post7273394
  9. #9
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    year 1995 ftw!
    oh nice stuff btw
