Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 74
Reload Thread: TC Sounds Motor's
  1. #31
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: TC Sounds Motor's
    Quote Originally Posted by audio_phill View Post
    If magnets had the same charge, Q shifts should be minimal, and I'd like to point out that the LMT from the RL-s line has a tc9 top-plate and a qts over 1.00 lol. My Old school TC3LM 4K's have the exact same Q as my tc9 lms drivers
    Gen 1 post-break in
    Re = 2.8222 ohms
    Fs = 22.8900 Hz
    Zmax = 27.3518 ohms
    Qes = 0.6362
    Qms = 5.5296
    Qts = 0.5706
    Le = 0.8308 mH (at 1 kHz)
    Diam = 208.2800 mm ( 8.2000 in )
    Sd =34071.0096 mm^2( 52.8102 in^2)
    Vas = 47.2054 L ( 1.6670 ft^3)
    BL = 10.3802 N/A
    Mms = 168.8843 g
    Cms = 286.2579 uM/N
    Kms = 3493.3530 N/M
    Rms = 4.3926 R mechanical
    Efficiency = 0.0836 %
    Sensitivity= 81.2408 dB @1W/1m
    gen 2 pre-break in
    Re = 2.9618 ohms
    Fs = 26.6445 Hz
    Zmax = 25.0854 ohms
    Qes = 0.7603
    Qms = 5.6789
    Qts = 0.6705
    Le = 1.0287 mH (at 1 kHz)
    Diam = 209.5500 mm ( 8.2500 in )
    Sd =34487.7765 mm^2( 53.4562 in^2)
    Vas = 25.9976 L ( 0.9181 ft^3)
    BL = 12.2980 N/A
    Mms = 231.8929 g
    Cms = 153.8644 uM/N
    Kms = 6499.2305 N/M
    Rms = 6.8362 R mechanical
    Efficiency = 0.0608 %
    Sensitivity= 79.8554 dB @1W/1m
    The reason I chose to compare the SW8000 and the LMS4000 is the coil, it's exactly the same between the two. The same can't be said for the LM10D2. Coil and soft parts are the same on the 10" SW8000 and the 10" LMS4000, only difference is the motor. Gaps and top plates are the same between the two motors, the SW is a TC9 and the LMS is a 3LM. Q is much higher on the SW8000.
    The LM10D2 uses a TC9 but it has more coil density as the Mms will show when compared the the LMS4000. Compliance on the LM10D2 shows this as well, it's stiffer to counteract the added mass. It's also got a higher BL product, again more coil. Can't really compare the two in that regard. Different beasts. More like the new offerings than it is the LMS4000.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  2. #32
    audio_phill's Avatar
    audio_phill is offline Walking TSP Encyclopedia
    Dec 2008
    Small Town VA
    1,531
    68 Post(s)
    Quote Originally Posted by ciaonzo View Post
    Glad you brought up the sw8K, heres tsp's from mine pre-break in
    Re = 3.1166 ohms
    Fs = 27.5399 Hz
    Zmax = 26.1917 ohms
    Qes = 0.8713
    Qms = 6.4508
    Qts = 0.7676
    Le = 1.1552 mH (at 1 kHz)
    Diam = 206.3750 mm ( 8.1250 in )
    Sd =33450.6109 mm^2( 51.8486 in^2)
    Vas = 28.5486 L ( 1.0082 ft^3)
    BL = 10.7285 N/A
    Mms = 185.9532 g
    Cms = 179.6025 uM/N
    Kms = 5567.8506 N/M
    Rms = 4.9881 R mechanical
    Efficiency = 0.0643 %
    Sensitivity= 80.1007 dB @1W/1m
    Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, tristanmay
    Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, ntfish, nate56
    Traded With: HiloDB1, ciaonzo, tristanmay, Jh8909, fritosaregood, eCrack.net
  3. #33
    Dec 2008
    Small Town VA
    1,531
    68 Post(s)
    If the lms4K gen 2 wasnt in my scion I'd get pics of the top's beside one another and some micrometer measures of WW, Coil ID/OD and Gap's. I'll try to get them from my 3LM and SW8K and LM10d2 asap.
  4. #34
    hrtbrk1's Avatar
    hrtbrk1 is offline 1ManWreckinCrew
    May 2008
    Boomer Sooner, OK
    5,788
    14 Post(s)
    Re = 3.1166 ohms
    Fs = 27.5399 Hz
    Zmax = 26.1917 ohms
    Qes = 0.8713
    Qms = 6.4508
    Qts = 0.7676
    BL = 10.7285 N/A
    Mms = 185.9532 g
    Cms = 179.6025 uM/N
    Kms = 5567.8506 N/M
    glad you posted this...i will be using this sub for my set up soon
    If you ever dealt with me in the past...please post how our transation went here...-->http://www.caraudio.com/forum/showthread.php?p=5274098<--...i greatly appreciate your support
  5. #35
    Dec 2008
    Small Town VA
    1,531
    68 Post(s)
    Quote Originally Posted by hrtbrk1 View Post
    2.2 sealed is awfully nice when fully stuffed and near golden ratio!!! lol.
  6. #36
    hrtbrk1's Avatar
    May 2008
    Boomer Sooner, OK
    5,788
    14 Post(s)
    fully stuffed?? 2.2?? darn i was gonna use .7 lol
    the original manual thing on the box said 1.0 max sealed.
  7. #37
    Dec 2008
    Small Town VA
    1,531
    68 Post(s)
    Manuals??? people use those fraudulent listings still lol.
  8. #38
    hrtbrk1's Avatar
    May 2008
    Boomer Sooner, OK
    5,788
    14 Post(s)
    lol it was on sonixelectronics.. and yes i believe it cuz i dont wanna break anything..what do you mean fully stuffed?
  9. #39
    Dec 2008
    Small Town VA
    1,531
    68 Post(s)
    3/4-1lb acoustuff or polyfill per cube.
  10. #40
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re = 3.1166 ohms
    Fs = 27.5399 Hz
    Zmax = 26.1917 ohms
    Qes = 0.8713
    Qms = 6.4508
    Qts = 0.7676
    BL = 10.7285 N/A
    Mms = 185.9532 g
    Cms = 179.6025 uM/N
    Kms = 5567.8506 N/M
    That's the Qes I was expecting to see with a TC9. A bit different than the .6362 on the LMS4000 with the 3LM. I know you could take a TC9 and a 3LM and give them the same amount of charge, I realize that. But I do believe the whole point of the extra slugs in the 3LM was to add B so as to bring Q down, though, and not to allow for more stroke. You can get the full 3.5" stroke from a TC9 with 1" slugs, I've demonstrated that over and over. Anyway, not huge deal. They all sound phenomenal when implemented correctly. They love their airspace, lol.
  11. #41
    hrtbrk1's Avatar
    May 2008
    Boomer Sooner, OK
    5,788
    14 Post(s)
    oh lol that stuff!!! lol...gahh youre making me spend a lot of money lol! you do know this is going in a car right!?
  12. #42
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,586
    42 Post(s)
    1424 Post(s)
    You can get a bag of 16 ounces at Walmart for $2.97+ tax.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  13. #43
    Go2Sleep's Avatar
    Go2Sleep is offline CarAudio.com Veteran
    Jan 2008
    Bay Area, CA
    30
    3,447
    98 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    This.
    Phill has this pretty much down to a science considering he pulls actual tsps and graphs them.
    I'd definitely wouldn't trust what sonicelectronics "suggests" but that's just me lol.
    It's all up to you but i'd atleast give it a try and see how it turns out.. if you don't like the performance than switch things up.
    * (2) Morel Ultimo 12's * Hybrid Audio Legathia SE 3-Way Active Front Stage * RF 360.3 DSP * (2) Arc Audio XDi 1100.1 * Arc Audio XDi 1200.6 *
  14. #44
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    In case anyone is doubting this... Both use the TC9.
  15. #45
    hrtbrk1's Avatar
    May 2008
    Boomer Sooner, OK
    5,788
    14 Post(s)
    cool! whats it called at walmart?
    Quote Originally Posted by Nickatina View Post
    This.
    yeah im sure ill go with what he says
