Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 64
Reload Thread: Not as Loud as I expected....
    ssj2xxgotenxx's Avatar
    ssj2xxgotenxx is offline The Chan Man
    Nov 2003
    Bay Area
    26
    2,618
    Ok heres what Im running
    HiFonics Brutus Bx1500D
    4 gauge B+/Grounds
    Twisted RCAs
    12 gauge speaker wire
    2 Solobarics 12" L7s
    12 gauge wiring
    In series @ 1 ohm
    6 Cubes Ported @ 35 Hz
    3/4 MDF
    JVC Sh-707
    2 volt preout =(
    No Deadner =(
    Okey like the title says its just not getting as loud as I expected .. From what I hear in the forums the L7s are suppose to get ungodly loud but it ain't cuttin it for me. It's loud but not to the extent where it pounds the hell out of my chest. Im guessing the problem is the amp settings, 2 volt preouts, alternator/battery not at 14.4 volts. Im not putting my HU up to 3/4 level cause thats just to loud and hurts my ears [speaker wise not subwoofer wise]. It starts to get loud and then it starts to get distortion.
    grizzjwill's Avatar
    grizzjwill is offline Beatin down the block
    Apr 2003
    nashville,tn
    26
    1,504
    38
    Re: Not as Loud as I expected....
    well its not gonnqa cave your chest in. Maybe you just expected to much from it. Do you have someone wh oyou can compare your system to and see if it really isnt getting loud. Play with the settings on the HU and the amp.
    h/u-Kenwood exceleon kdc-x591
    6x8-kenwoods
    6x9-kenwoods
    sub-15" AQ Hd3
    box-5.2cu @ 34hz
    amp-Cadence zrs-8
    Wiring-knukonceptz 1/0 gauge
    electrical-Big 3
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    Quote Originally Posted by ssj2xxgotenxx
    4 gauge B+/Grounds
    Twisted RCAs
    12 gauge wiring
    In series @ 1 ohm
    3/4 MDF
    JVC Sh-707
    2 volt preout =(
    No Deadner =(
    it says you have them run in series if that is so they could be dual 4 ohm and you have a 4 ohm load which is only 500 watts rms total. if they are dual 4 ohm run them in parallel and you will get a 1 ohm load which would be 1500 watts
    Nov 2003
    Bay Area
    26
    2,618
    Quote Originally Posted by grizzjwill
    well I have alot of friends with subwoofers and one of them has two 12" comps [non VR] with a punch 700s and that **** pounds hella hard [hurts my chest] and my drivers are way more superior to his.
    Quote Originally Posted by iceteebone
    http://www.rockfordfosgate.com/rftec...x=24&image.y=6
    I have it wired like the diagram above.... I know it can hit way harder cause it isn't even even reach Xmax.. only reason is b/c when I can't get it up that loud without getting massive distortion.
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    4 gauge B+/Grounds
    Twisted RCAs
    12 gauge wiring
    In series @ 1 ohm
    That link ain't working.
    How many ohms are you subs.(DVC)
    If they are 2ohm DVC, then the final load could be 4ohms or 2ohms.
    If they are 4ohm DVC, then the final load could be 4ohms or 1ohms. In this case, for a final load of 1ohm, you need to wire the subs VC's in a series-parallel configeration.
    looks like thisagain, the link you gave above wouldn't work for me. I'm just trying to help.)
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    Quote Originally Posted by DBfan187
    the link worked for me. if you wired them like the first diagram then you should be getting the full 1500 watts to them subs but if it's like the second then there would only be 500 watts rms.
    EarDrummin.'s Avatar
    EarDrummin. is offline Is this my Brahma?
    May 2002
    Wanaque, NJ
    31
    1,302
    DBfan, that's a parallel config, not a series/parallel config. I think Goten just made the mistake of saying he wired it in series, when he actually wired it in parallel. Unless, Goten, you did wire it in series. If you have 1500 watts going to those drivers, you'll know there's 1500 watts, lol.
    Audi A6
    Alpine 7897
    MBQuart discus
    JBL bp1200.1
    Brahma 15
    AOL: Rav3Cultre
    http://www.sounddomain.com/id/eardrummin
    xjmadness's Avatar
    xjmadness is offline The beauty of green
    Dec 2002
    ATL
    1,708
    Let me guess. Your gain is at Min??? Turn the GAIN UP. That hifonics 1500 input sensitivity goes from 9v-200mv. Best thing would be to make the gain to about 4-5v and see how you like it there. If you need more output, put it up to around 2v. I'm sure it'll be pounding like hell.
  9. #9
    Dec 2003
    Austin, TX
    29
    86
    should've got XXXs
  10. #10
    Below 30's Avatar
    Below 30 is offline Video Games Fo Life
    Jan 2004
    Ontario, Canada
    43
    175
    Does nobody realize that the Rockford diagram for parallel wiring is wrong, also I believe JL uses same. Rockford shows the both red on one side and both black on another. Its supposed to be RED to RED and BLack at top, then RED to (diaganol) RED at bottom BLACK to (diaganol) BLACK at bottom.
    When I first worked with DVC subs I followed the RF diagram too and couldn't figure why the subs were so low, till I rearranged the wiring. I seriously can't believe people don't realize that very large diagram mistake.
    When Skills Ruled
  11. #11
    ghs_wrestler189's Avatar
    ghs_wrestler189 is offline CarAudio.com Elite
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    I think he should upgrade his power and ground cables, didn't it say he was using 4 guage, I would only use 4 guage for systems under 1000w.
    AIM:ghs wrestler 171 - hit me up anytime.
    My Sounddomain Page
    1998 Oldsmobile Intrigue
    RE SX 15" D4 is here with a 5.0 cuft box tuned to 46 hz for comps.
    Port plug for 32hz daily.
    MTX 81000d give it 1225 rms at 2 ohms.
    143 on the new termlab (old box...5.1@36hz).
    Quote Originally Posted by jemorgan85
    ^I wish I were a woman .
  12. #12
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    doesn't hifonics only allow for 4 gauge wire?
  13. #13
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    I don't know about that but my MTX 81000d is about the same wattage and it is 1/0 guage.
    My Sounddomain Page
  14. #14
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    28
    16,625
    20
    28 Post(s)
    Quote Originally Posted by Below 30
    Huh?? Not quite getting you. If you are wiring in parallel, all you have to do is hook up all the positives together and all the negatives together. I don't see whats wrong with the diagram.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
  15. #15
    May 2002
    Wanaque, NJ
    31
    1,302
    There's nothing wrong with the diagram.. I can't respond to anything else he said, because all I understood was "Does nobody realize that the Rockford diagram for parallel wiring is wrong".
    Audi A6
    Alpine 7897
    MBQuart discus
    JBL bp1200.1
    Brahma 15
    AOL: Rav3Cultre
  1. Everything you need to know about every sub
    By Gauntlet in forum Subwoofers
    Last Post: 08-08-2004, 01:27 PM
  2. How loud is loud?
    By sumone in forum General Discussion
    Last Post: 01-27-2004, 11:49 AM
  3. +3 db = 2x as loud????
    By maniackilla in forum General Discussion
    Last Post: 10-03-2003, 03:33 PM
  4. could a brahma get as loud as a HCCA
    By DbRufus1234 in forum Enclosure Design & Construction Help
    Last Post: 09-06-2003, 04:19 PM
