Results 1 to 7 of 7
Reload Thread: Best glue for carpet to plastic?
    BassAddictJ's Avatar
    BassAddictJ is offline CarAudio.com Veteran
    Apr 2005
    FL
    12,949
    1 Post(s)
    1 Thread(s)
    153 Post(s)
    i have some carpeted door pods. I plan on putting another layer of carpet over the edge of the pods over to the door panal to cover the small gaps here or there bwteen the two.
    What is the best kind of glue for the carpet to plastic joint? ideally something affordable and available at home depot or lowes.
    Past:
    Pioneer Avic N5 Navi + CD-UB100 USB Adapter. Circa '96 PPI Ax606.2 in BLACK with 2 black graphic spacers.
    CDT DRT-25 1'' Silk Dome Tweeters / CDT ES-04 4'' Midranges / RE Audio XXX 6.5'' 2ohm Neo Mids In Glassed Kick Pods
    American Power Systems 240amp H.O. Alty / (2) Deka 8a31, 1/0 front to back.
    Random Prototype 3k @ 1ohm. TRF/PSI 8 layer 4in coil Monster 15 in 3 cubs @ 33Hz / Raammat 40sqft in the trunk.
    NEW SETUP IN THE WORKS
    Quote Originally Posted by Haunz View Post
    You could put 12V to my balls and clamp my dick to get 3kW+.
    Quote Originally Posted by Slayerx View Post
    Glad this got bumped so I could fap to it again.
    45js45's Avatar
    45js45 is offline Senior VIP Member
    Nov 2010
    lost.....again
    274
    Re: Best glue for carpet to plastic?
    Look at the 3M line at either store and check the tubes for applications.Make sure to rough up the plastic with sand paper to aid in the adhesion.
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Quote Originally Posted by 45js45 View Post
    3m77 or 99 will work and do like he said and rough up the plastic. Also make sure you clean the plastic part thoroughly to remove any residual armor all,grease, oil or anything of the like
    5 % equipment
    90 % install
    5% beer
    Apr 2005
    FL
    12,949
    1 Post(s)
    1 Thread(s)
    153 Post(s)
    definitly doing some roughing.
    they had some locktite 2 part expoxy made for plastics on sale so i picked up some of that (hadnt seen yalls posts yet). we'll see how that goes...
    Past:
    DonH's Avatar
    DonH is offline .....
    Jun 2008
    So Cal
    6,023
    190 Post(s)
    do not buy the 3m ****. its beyond over priced!!!!!
    do you have a autozone close by? they have a GREAT bottle of spray glue for about $6. has a white cap and orange body. chk it out. good stuff on the cheaps to
    Quote Originally Posted by chillin View Post
    How do you bridge a mono?
    Quote Originally Posted by snoopdan View Post
    throw it off one.
    feedback thread:
    http://www.caraudio.com/forums/buyer-seller-feedback/402726-d-man1s-official-feedback-thread-2.html
    Apr 2005
    FL
    12,949
    1 Post(s)
    1 Thread(s)
    153 Post(s)
    already got so,e plastics epoxy. seems to be making a good hold so far....
    Past:
    neonblack's Avatar
    neonblack is offline Member
    Jun 2006
    Devon PA
    97
    23 Post(s)
    3M spray adhesive works with lots of different materials and works well. Cover both surfaces to be mated and wait for a minute or so until it gets a little sticky. Some of the other spray adhesives do not work as well. Only problem with these adhesive cans is when not being used the nozzle gets clogged so you have to pull out the dried glue.
    I covered my kick pods with exterior cabinet cloth and 3M did the trick.
