Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Reload Thread: First post...Need help picking out my new system
  1. #31
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    Re: First post...Need help picking out my new system
    Quote Originally Posted by graydodge14 View Post
    why should i not get the heat ring? no offense or anything just wondering what makes me not need it since i dont know?
    and i should get the dual 2 ohms correct and not the 1 ohms?
    dual 1, heat ring makes the sub play higher notws and gets rid of the lower notes, when u select cooling it inluded everything else.
  2. #32
    graydodge14's Avatar
    graydodge14 is offline Member
    May 2010
    Midland, TX
    115
    and a 1 ohm stable amp and i would be set correct? should i go 2500 watts or 3000? and besides changing out the electrical i.e. altanator, battery, etc.
  3. #33
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    if ur upgrading cooling etc id get the crescendo defen its a better amp then the saz-2500d for 25 dollars more and navid gives amazing customer service as does jacob but u might as well get the extra power
  4. #34
    May 2010
    Midland, TX
    115
    k either amp i get will need to be 1 ohm stable right?
    if i get dual 1 ohm subs plus a 1 ohm amp and run them parralel am i running them really at .5 ohm im lost
  1. Help picking a system
    By manslayer in forum General Discussion
    Last Post: 11-10-2008, 12:18 AM
  2. Need Help Picking System
    By Danimal in forum General Discussion
    Last Post: 06-04-2008, 09:04 PM
  3. Help Picking Out System
    By TRANSAMCHARGER in forum Subwoofers
    Last Post: 12-16-2002, 06:26 PM
  4. Help Picking System
    By TRANSAMCHARGER in forum General Discussion
    Last Post: 12-16-2002, 02:55 PM
  5. need help picking out a SQ system..
    By qxfosgatesvt in forum General Discussion
    Last Post: 10-29-2002, 09:28 PM
