Results 1 to 5 of 5
Reload Thread: looking for some noob advice
    hellz's Avatar
    hellz is offline Member
    Apr 2010
    Burnsville,mn
    113
    32 Post(s)
    Hello everyone.
    so, like the title says, im looking for a little advice.
    i have a 03' Hummer H2 with the Bose system
    i replaced the HU with a Pioneer AVH - P4000DVD that is connected to the BOSE amp and stock BOSE speakers that are failing.
    Pioneer AVH-P4000DVD DVD receiver at Crutchfield.com
    6.5 componete speakers in the front
    6.5 - 2 ways in back doors
    there is also a 5 or 6 inch "sub" hidden somewhere in my dash.. anyways...
    i would like to remove all traces of the BOSE system.
    replace the front stage area with decent speakers (Component)
    i would like back fill speakers for the rear seat area.
    Budget is $500 for atleast front speakers, and a Amp.
    what can you guys recommend?
    i listen mostly to Rock music, but with some techno, and rap thrown in there.
    if the song has bass in it, i want to know its there!
    below is the following items i have, but not installed. not sure if any of it is really worthwhile actually, but i got most of it for free, so cant complain.
    SUBS~
    ROCKFORD FOSGATE P210S4 10" SUBWOOFER
    Sensitivity: 85.8 dB
    Frequency Response 20-200 Hz
    Recommended RMS Power: 200W
    Peak Power Handling: 400W
    Impedance: 4 ohms
    Pioneer TS-SW301 12in 4-Ohm 250-Watt Subwoofer With Shallow Mount Design
    Product Features
    1000W maximum power handling (250W RMS)
    Composite IMPP with interlaced carbon fiber cone
    Includes a small mount design for tight spaces
    Flat subwoofer uses air suspension system to provide clear, powerful bass
    Impedence: 4 ohms
    AMP~
    2010 NEW! 4 CH 4000 WATT CAR AUDIO AMP AMPLIFIER AMPS
    PLA4478
    RMS Power @ 4 Ohms: 4x200 W
    RMS Power @ 2 Ohms: 4x320 W
    Bridgeable RMS Power @ 4 Ohms: 2x2000 W
    Maximum Power Output 4 x 1000W
    4 Channel Bridgeable MOSFET Amplifier
    Frequency Response 20 Hz-50kHz (3dB)
    Output Power @ 14.4v DC, 50Hz
    2 Ohm Stable
    MOSFET Power Supply
    PWM ( Pulse-Width-Modulation ) System
    Glass Epoxy PCB
    Silver RCA Inputs
    Custom Terminal Block for Speaker Connection
    Thermal / Overload / Short Circuit Protection
    Input Impedance: 47K Ohms
    Soft Turn On/ Off
    Advanced Protection Circuitry
    S/N Ratio: >90dB
    Dimensions:10.24''W x 2.21''H x 17.72''L
    6.5 Comp Speakers~
    PYLE PLG6C
    Standard 6.5" Sizes Fits OEM Locations
    Yellow Color Poly Injected Cone
    Non-Fatiguing Butyl Rubber Surround
    High Temperature Aluminum Voice Coil
    Yellow Coated Steel Basket
    40 oz. Magnet Structure
    Rubber Magnet Cover
    200 Watts RMS/ 400 Watts Peak
    Frequency Response: 50-5KHz
    Impedance: 4 OhmsOne Pair 1" Neodymium Dome Tweeter:
    1" Silk Dome Neodymium Magnet Tweeter
    3 Mounting Options: Flush / Swivel / Surface/Angle
    Frequency Response: 1.4-24KHz
    Impedance: 4 Ohms
    One Pair Passive Crossover Network:
    2-Way passive Crossovers
    12dB Octave SlopeAccessories:
    Curren$y's Avatar
    Curren$y is offline Member
    Apr 2010
    Dallas, TX
    58
    2 Post(s)
    Re: looking for some noob advice
    have someone on here build you a box for the p2
    install the four channel amp for the 6.5 comp speakers
    find a mono 1 channel amp for the p2
    hellz's Avatar
    Apr 2010
    Burnsville,mn
    113
    32 Post(s)
    i thought about using the Amp for some 6.5s, but at 200 RMS, wouldnt that be overkill for most good quality 6.5s out there?
    most i have seen are 50 to 75 RMS, that max out at 100 to 200w.
    wouldnt this amp be too strong for even those pyle 6.5s? 200rms/400w?
    just by word of mouth really, but arent they named "pile" for a reason?
    if anything, i was thinking of using the amp for the 12" sub..
    but then again, im not even remotely a expert on car audio. i just barely know enough to confuse myself.
    thanks, for the info and help btw
    nateberrier's Avatar
    nateberrier is offline ******
    Jun 2009
    Douche, Ohio
    4,641
    202 Post(s)
    no, just turn the amp down, head room is always good. that way youre not working the amp and youre not distorting the signal using all the power you need.
    Refs: mrmakinmoves[SCAMMER] AKA ICHASEPAPER2010, skydeaner, fukinmovin, mossberg385t, grimreper912003, LBC99, Dbeez, Michaellane, thegreatestpenn, truckstoy, ge_off_me, btr, cupid6969, johnprdeye, jh8909, tylerj, UMWDawg92, nu2spl, zerosktr111, SPLAUDIO, $LICK CALIFA$, jfroghobo
    http://www.execution-audio.com/
    hellz's Avatar
    Apr 2010
    Burnsville,mn
    113
    32 Post(s)
    what if i do not use the Pyle speakers, and decide on using something along the lines of these:
    Focal
    Focal 165A1 6 1/2" Component Speaker System NIB NR : eBay Motors (item 230465017007 end time Apr-28-10 07:44:31 PDT)
    orthese JBL
    JBL
    i understand turning the gain down on the amp, but wouldnt it still be overkill for these speakers since they are only 50 to 70 RMS?
    for what i always understood was that RMS = continous power at all times. you could turn the gain down to 0, and it will still put out the RMS rating per channel?
    im not looking for a competition setup, but not looking for ghetto either. so if i need to buy a new amp, thats fine.. just looking for recommendations.
    but if this amp will work, hey it saves money for other goodies. im not ignoring any advice, i just dont know, so sorry about the questions.
    thanks again!
