Results 1 to 9 of 9
Reload Thread: Newbie question.. amp/sub compatibility..
    flu3ncy's Avatar
    flu3ncy is offline Junior Member
    Jan 2004
    West Linn
    13
    Hey.. I'm completely new to car audio, but wanted to get a cheap system that bumps fairly hard. I already have a Panasonic head unit in, as well as Eclipse/Focal speakers.. so now I just need to get an amp and some subs.
    I was looking at Sony Xplod, since it seems like they do some decent damage for a pretty low cost. Money -is- an issue for me. But I had a couple questions about compatibility.. I wasn't sure how it worked. Can a mono amplifier power 2 subs in a box?
    The amp I was looking as is this:
    http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
    500 watts RMS x 1 at 4 ohms
    900 watts RMS x 1 at 2 ohms
    1600 watts peak power
    And then I was thinking of getting 2 of these subs..
    power range 90-350 watts RMS
    peak power handling 1200 watts
    Honestly, I have no idea if that stuff will even work together. I know mono is only one channel, but I figured it may be able to power two subs, I don't know.. and do the power ratings match up okay? The ohmage?
    Thanks.. any info would really be appreciated.
    Also.. out of curiosity.. would these sound decent, or does Xplod ****? lol.
    green_slip's Avatar
    green_slip is offline Senior VIP Member
    Jan 2004
    Utah
    30
    472
    Re: Newbie question.. amp/sub compatibility..
    Sony ***** period, and yes mono amps are usually used for subwoofer systems. How much money do you plan on spending?
    flu3ncy's Avatar
    Jan 2004
    West Linn
    13
    Does that mean the mono amp could power two subs?
    With the amp, the two subs, and a bandpass enclosure.. going through ebay.. I'd get it all for around $400, including shipping.
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    31
    5,170
    1 Post(s)
    Quote Originally Posted by flu3ncy
    yes a mono amp can power as many subs as u want wired together. so buying all that stuff for 400, would basically be the same as taking ur money and flushing it down the toilet.
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
    flu3ncy's Avatar
    Jan 2004
    West Linn
    13
    Wow.. are we a bunch of elitest bastards here, or what?
    I know Sony stuff is considered low-end.. but Jesus, I thought I made it clear that I was going for a bargain setup. I don't need anything competition-level.. it just needs to bump. And when I listened to an Xplod sub/amp combo at Best Buy, it did. It even sounded better than some of the more expensive **** that was right next to it.
    So I fail to see how $400 is flushing my money away. I know I asked for opinions about it, but if you think it's such a waste of money, you could recommend me a different setup that I can get for the same amount of money that will sound better, and hit harder. That would actually be helping me..
    buchel's Avatar
    buchel is offline Veteran n00b
    Feb 2002
    Ontario, Canada
    32
    356
    LMAO, you tell 'em... j/k
    ~ Kyle ~
    Quote Originally Posted by Gauntlet
    Your father should have pulled out.
    flu3ncy's Avatar
    Jan 2004
    West Linn
    13
    Sorry. :\
    I just get frustrated when people say "It *****", but don't suggest anything different.
    Bavarian3's Avatar
    Mar 2003
    Nor*Cal
    31
    5,170
    1 Post(s)
    for 400 dollars u will not only get a bargain setup but u will get a very nice sounding/hard hitting system. U have a nice deck and nice speakers so why put sony crap in there.
    u can pick up 2 12" ED K's that would be 240 bucks. and leave u with 160 for a 600 watt amp. http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796 and there ya go. that will give u 300 watts per channel at 4 ohms. so ud get the DVC 4 ohm ones and wire em up to 4 ohm load.
    With that setup u will blow out any sony crap out the water.
    edit - i noticed the 10's are 125 a piece and the 12's are 135 a peice, so after shipping for the amp and subs ud probly be spending about 450. tthen ull need another 50 bucks for a supplies to build a box and a wiring kit. Any wiring kit from walmart or ebay will be perfect.
    www.edesignaudio.com for the subs.
    -Eclipse cd8053
  9. #9
    flu3ncy's Avatar
    Jan 2004
    West Linn
    13
    1) My head unit is Panasonic, not Pioneer-- just edited my first post. I dunno what I was thinking when I typed that.. I guess I wasn't thinking at all and just slipped up. lol. Oops.
    2) Thanks man.. sorry about the name calling. I could go a bit over my budget.. $500 is probably the very most I could spend though, including all supplies and shipping. I'm gonna look into what you recommended.
  1. Amp wiring question
    By Dookie in forum Amplifiers
    Last Post: 11-13-2003, 10:36 PM
  2. stupid newbie question...
    By plainzwalker in forum Amplifiers
    Last Post: 11-03-2003, 12:55 AM
  3. cd changer question
    By Matador in forum General Discussion
    Last Post: 10-18-2003, 02:36 PM
  4. Dumb question from newbie
    By Mash Jetta TDI in forum Wiring, Electrical and Installation Help
    Last Post: 10-17-2003, 01:10 PM
  5. Amp ground question
    By Jbarbier in forum Amplifiers
    Last Post: 08-22-2003, 09:22 PM
