Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Reload Thread: Alpine all the way! Suggestions please!
    jt34237's Avatar
    jt34237 is offline Member
    Apr 2010
    Sarasota, Fl
    72
    So I'm pretty new to the car audio world but have read massive amounts of info online to get me up to speed a bit. Now the system I want to put in my 95 Geo Prizm is ALL Alpine Type R equipment minus the deck and amps of course.
    Front speakers - 5 1/4 Alpine Type R Component set ( will be recieving 50 rms each from alpine amp)
    Back Speakers- 6 1/2 Alpine Type R Coaxial - (will be recieving 50 rms each from alpine amp)
    4 Channel amp- Alpine MRP-F300
    Now were I'm a bit confused is matching the sub with the amp... mainly in regards to the Ohms. This is what I have matched... does this look good?
    Alpine MRP-M1000 Amplifier -600 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
    Alpine SWR-1243D Subwoofer -:
    12" subwoofer with dual 4-ohm voice coils
    300-600 watts RMS (300 watts per coil)
    Chances are I'm going to have this sub in a sealed enclosure since I don't listen to rap and would like tight accurate sound. So yeah any suggestions regarding this setup would be greatly appreciated. Thanks everyone!
    Afrodeezyak's Avatar
    Afrodeezyak is offline Member
    Mar 2010
    Pullman, WA
    36
    Re: Alpine all the way! Suggestions please!
    Sounds pretty good, i use to run 2 1243D's off a PDX-1.1000 and it was a sick setup but you'll be fine wiring those at 2 ohms
    Savstyle's Avatar
    Savstyle is offline CarAudio.com Veteran
    Mar 2004
    Fresno
    31
    3,910
    4 Post(s)
    Whats your budget im sure we can find something better. Espically the speakers. The trpe R sets dont sound all that good IMO.
    Are you installing everything yourself?
    They Call Me DARKNESS
    Gamertag: Savstyle
    jt34237's Avatar
    Apr 2010
    Sarasota, Fl
    72
    No I'm going to have best buy do the install. I'm going to go with just 1 12 for now, until I can afford to get a better amp. My budget is 1300. I've carted all the items on cruthfield and it comes to about 1250.00, the install is probably going to run 500 or more. I would do it but have never done it and want it done RIGHT. Figure I should note that I listen to mostly electronic music which involves fast bass, if i'm not listening to Florida Breaks I'm listening to Rock.
    misfit138's Avatar
    misfit138 is offline a whole new type of aids
    Jun 2009
    Williamson, WV
    12,048
    19 Post(s)
    Quote Originally Posted by jt34237 View Post
    Well, the speakers and amps you want can be had for $750 if you don't buy them from Crutchfield. Also, I hope you plan to use some lube, because paying $500 for a basic install is the equivalent of being butt raped...
    I shot out muh mom's vag with bossing papers in hand.
    Mar 2010
    Pullman, WA
    36
    Pls dont buy from crutchfield, their **** is pretty expensive and you can find all that for way cheaper
    I use their site to do research and compare products but i never buy from them
    Im not gonna try to push you away from the products you've already choosen, but if you buy at retail you can get so much more for your money
    And having stuff installed by BestBuy is almost as bad as buying from them simply cause their ish is so expensive
    Take your time and install yourself, you'll learn a lot and save a lot of money
    LazyRider's Avatar
    LazyRider is offline CarAudio.com Veteran
    Dec 2006
    Internet
    3,982
    9 Post(s)
    Don't buy that stuff from crutchfield. If you don't mind buying used you can save a ton of money.
    misfit138's Avatar
    Jun 2009
    Williamson, WV
    12,048
    19 Post(s)
    Quote Originally Posted by LazyRider View Post
    The speakers and amps he's looking at can be had for around $750 brand new...
  9. #9
    jt34237's Avatar
    Apr 2010
    Sarasota, Fl
    72
    Wow! I'm feeling pretty dumb right now! Well thats why I posted to get some insight. So where do you guys suggest I buy from online? I want warranties as well so buying used is out of the question. I'm pretty set on alpine products for now. Someone said I could get all the products somewhere for 750 brand new. WHERE!?!?! That would f****** awesome!
  10. #10
    branham1127's Avatar
    branham1127 is offline Matt Branham
    Jul 2008
    Colorado
    29
    346
    Alpine Store at Sonic Electronix.. Great customer service and ship the same day if you pay early in the day. There's plenty of places to find the same stuff for better prices, just google it .. Amazon.com usually has low prices since they list things for sale from all sorts of companies.. Just look around.
    2003 Chevy Silverado Ext Cab
    Head Unit: DNX-9960
    Mids/Highs: (2) pair of ID CXS64 V.2
    Mids/Highs Amps: American Bass SQ-945
    Subs: Pair of DC Lvl 5 18s
    Sub amp: American Bass 700.1
    260 amp Iraggi alternator (6) neg/ (6) pos Kicker 1/0
    D2400 Under the hood (6) D3100s, XS Power VCM
    Refs: http://www.caraudio.com/forum/buyer-seller-feedback/463207-branham1127-feedback-thread.html
  11. #11
    misfit138's Avatar
    Jun 2009
    Williamson, WV
    12,048
    19 Post(s)
    - go to google
    - type the name of the product you're interested in
    - click the "shopping" tab
    - click "sort by"
    - select Price: low to high.
  12. #12
    Jul 2008
    Colorado
    29
    346
    Quote Originally Posted by misfit138 View Post
    - go to google
    - click "sort by"
    Should have just said this lol
    Head Unit: DNX-9960
  13. #13
    Bumpin' Goalie's Avatar
    Bumpin' Goalie is offline Magic 8 Ball
    Nov 2009
    TN & Travel
    3,163
    3 Post(s)
    Sonic Electronix and woofersetc are good places for CS and price.
    System Layout help available via PM.
    My system:
    Sounds good.
  14. #14
    jt34237's Avatar
    Apr 2010
    Sarasota, Fl
    72
    Thanks so much everyone. I did go to Sonic electronics site and the prices were awesome but all the Alpine amps were on backorder. This would be a problem for me when it does come time to by... I will pay extra to have now rather then later. I want my toys!!!
    Does anyone have any experience with the type R subs? The guy at best buy told me that these were best in a ported enclosure... I don't know certain subs were better in certain types of enclosures. I thought it had to do with the type of sound you were looking for.
  15. #15
    Savstyle's Avatar
    Mar 2004
    Fresno
    31
    3,910
    4 Post(s)
    Install it yourself its easy as pie.
    If your scared find somone to help u.
    as for the system
    Speakers- Rainbow SLC 230 - Sound Line 5 1/4" 2-Way Component System (250)
    Sub- Car Audio wholesale distributor Alpine Pioneer HID Lights Clarion Hifonics Kenwood Boss - Ikesound.com - Alpine SWX-1243D 12" Dual 4 ohms Subwoofer (230)
    Sub Amp- XT-2000D - US Amps 1 Ch 2000 Watt Power Amplifier (320)
    Back speaker- KX 165 - Rainbow KX 6.5" Coaxial Speakers (135)
    Way better than the setup u listed i found all the stuff in a couple mins. You look around you can find it cheaper and from better sites.
    And with the music you listen to id reccomend the type x over the r. X sounds waaaaaay cleaner. The R doesnt sound nearly as good. The r just gets loud. Im speakin from experience ive owned both.
    Read up some more you can find better stuff than what ive listed. If i remeber ill check when i get home and try and build somthing better.
    And for god sakes dont get the stuff installed at best buy
    Gamertag: Savstyle
