I am wanting to use a couple of aftermarket amps with my factory head unit. I have to use factory because of the digital climate control. What I need to know since the tuner and antenna is located in the trunk is where is a good place to run my remote and constant from my eq? I had the remote going to the power antenna switched and it was grounded to a bolt on the front seat since the eq is right by the seat. The problem was it kept draining the battery with no constant hooked up. Where can I run me power wires to turn everything on. I'm no beginner but this is the first time working with this kind of setup.
