Results 1 to 7 of 7
Reload Thread: 2 subs wanted, higher SPL than w7
    maniackilla's Avatar
    maniackilla is offline cout<<"c++";
    Jul 2003
    McKenzie, TN
    804
    im gonna be adding 2 more 12s in a 5 cube sealed box *2.5 cubes per chamber* and i want to add something LOUD. im thinking of anything 1kwrms or more for each sub. afterwards ill buy an amp to push them.
    im thinking of going audiobahn so i can reverse the subs and show off some chrome sinc ei have a bed cut. they have hella good power handling for the price and look dead shnexy. im not worried about how they sound, my box will take care of any rubbish sound some people complain about.
    subs in mind:
    1500wrms - http://www.cardiscountstereos.com/Ca...ct+%23=AW1208Q
    2kwrms *little weary of THAT many watts for so cheap* - http://www.cardiscountstereos.com/Ca...uct+%23=awis12
    1100wrms - http://www.cardiscountstereos.com/Ca...ct+%23=AW1206Q
    1kwrms - http://www.cardiscountstereos.com/Ca...ct+%23=AW1205Q
    what do you guys think? go ahead and throw in some of the RE and ED subs as im sure you will just keep in mind im wanting some loudness, my box will pickup the low and mid 30hzs like you cant believe!!! im thinking of getting the 1500D also, or the 1800watt avionixx(sp?) if ED still had it listed. anyone know the specs to any of the TRU amps and if they are any good?
    as far as price goes, im not really on a budget b/c i have plenty for 2 subs and an amp. im also buying new tires for my 18s and doing some suspension work so i need to save as much as possible.
    open to suggestions
    cobra65427289's Avatar
    cobra65427289 is offline CarAudio.com Veteran
    May 2003
    IL
    31
    2,341
    Re: 2 subs wanted, higher SPL than w7
    actually for spl it is kind of hard to beat a digital designs system if it is set up properly. check out the 9500 series.
    al
    Fact 1: 79,000,000 people are engaged in intercourse right now.
    Fact 2: 58,000,000 are kissing.
    Fact 3: 37,000,000 are relaxing after having *** .
    Fact 4: 1 lonely bugger is reading forums...- You hang in there sunshine!
    drkodin's Avatar
    drkodin is offline CarAudio.com Elite
    Sep 2002
    Gainesville, TX
    34
    581
    Quote Originally Posted by maniackilla
    as far as price goes, im not really on a budget............ so i need to save as much as possible.
    open to suggestions
    so which is it? :p
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    That is a HUGE sealed box. Ever consider just making it ported? 5 cubes tuned to ~35 hz would wang with some high power subs.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Quote Originally Posted by cobra65427289
    al
    In a daily driver with about 1kw to each woofer there are a lot of subs I would take over any DD...they don't displace all that much.
    For pure SPL purposes they shine...but daily drivers there are better out there-especially if he's going sealed.
    Jul 2003
    McKenzie, TN
    804
    Quote Originally Posted by drkodin
    so which is it? :p
    lol, i meant but* im getting 1500 cash back. i was thinking of using around 500 for 2 subs and an amp .... thats just an aim price :P
    i think one of my subs blew today on the way to work :-\ all of a sudden a big pop and then an aroma. but they played fine home, i gotta check em out afte ri get back from the orthodontist.
    id love to slap in 2 flame Qs in a sealed box with a bx1500D and 2 more in the ported box with another 1500D ..... mmmm tasty
    tobz's Avatar
    tobz is offline Independant Thinker
    Nov 2003
    MN
    36
    507
    I have a DD 9512 e series in a 3.33 cu^ft box ported to 28hz. It's **** loud. They make some of the loudest subs around. Also, it sounds great. Most of the time, you don't listen to your system at 100% volume, so nearly all subs will have similar SQ IF they are installed correctly. Granted, some subs can get much louder and still sound clear, but do you value your hearing?
    I know that I do. I hurt my ears listening to my DD9512e while it had great SQ. I didn't feel a need to turn it up and hurt my ears more. I'd be interested to see what mine hits in my 4 door sedan, I bet it's pretty high.
    Anyways, two 9515's can hit close to 170's in a correct install. Great subs, and my setup is clean enough for daily listening all day long.
    I highly recommend them.
    If anyone wants a 9512e series, I'm selling mine. $350 + shipping takes it. MSRP $609
    Peace.
    T.J.
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 06-30-2008, 11:33 PM
  2. Everything you need to know about every sub
    By Gauntlet in forum Subwoofers
    Last Post: 08-08-2004, 01:27 PM
