Results 1 to 9 of 9
Reload Thread: high preoutputs for hu
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    Aite, i just wanna i guess get this stuff clarified
    eclipse hus, have 8v preouts, ni know that u gotta find amps that are able to have the input sensitivity up to the 8v in order to use the hu or the amp (whichever is right if any) to its full potential.
    if that's true, what happens if the amp can only handle up to 4V or 6V input sensitivity?
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    80_Cutlass_mn's Avatar
    80_Cutlass_mn is offline What needs to be here?
    Nov 2002
    Anderson,Al
    32
    1,809
    Re: high preoutputs for hu
    Then I would imagine you wouldnt be able to turn you h/u up very high. Thats the only down fall I can see. So if you have any speakers running off your h/u then you might as well be screwing yourself becuase they wont be able to get loud enogh to go over what is running off the amp. But if you have another amp running something else, then im sure you can adjust it out somehow.
    Arctic White 1995 Camaro 3.4L
    Hifonics BX2005D- 12" IA Death Penalty
    Premier prs-x220 - MB Quart DSD213 components
    Pioneer DEH-P7600MP - Scosche 4 Ga. wiring kit
    Aol Instant Messanger: CamaroMN1995
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    I've heard of folks using 8V HU's with 4V input amps with no problems. Worst case is you'd need to reduce the voltage a bit, but it'll probly be OK. If you get into trouble, we can help you figure something out.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    JLCivic's Avatar
    JLCivic is offline CarAudio.com Elite
    Mar 2003
    Maine
    49
    1,211
    I have seen very few people complain that their amps cannot take the 8 volts. Usually, I have seen people mention a 2:1 or 3:1 overlap. I have run 8 volt eclipse decks with eclipse and JL amps..no problems. The local shop has sold/installed many using a variety of amps without any issues.
    2002 Honda Accord SE sedan
    RF 8250
    Sirius
    Dynaudio 220 components
    JL Audio 12W6V2 sub
    JL Audio 300/4 amp
    JL audio 500/1 amp
    http://members.sounddomain.com/perryb
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    FYI, arc amps have an indication that they can only take up to 2V or something. For me, I screw the stupid numbering on them amps and adjust according to what I hear. Amp mftrs will tell you to do the same anyhow.
    8V = balanced line..well, that's the general idea that I got so far..
    I DID hear that amps should be able to take such high voltages too, and could cause a damage to the amp. There are devices out there that can reduce the voltage.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    68 Post(s)
    917 Post(s)
    by the time the signal reaches the Amps it will not be 8 volts anymore, you lose some signal in the RCAs
    CarAudio.com mod(original)
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by denim
    Wrong. RCA losses are near zero (no current). However, the voltage spec on HU outputs is at full volume, and since the volume control is logarithmic it drops off fast. My "2 volt" outputs actually measure 0.4 volts at 3/4 volume.
    dave
    denim's Avatar
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    68 Post(s)
    917 Post(s)
    lol um then in much of the installs and much of the headunits I have installed must have all ******, it does lose some signal espically when your driving 15+ feet
  9. #9
    jemorgan85's Avatar
    jemorgan85 is offline SPL Tactician
    Jan 2003
    Greenwood, IN
    33
    2,067
    22
    Quote Originally Posted by maylar
    You are basing this on mathematics only. You are not taking into account what an RCA wire rubbing up against bare metal and road noise factor into the "equation"...
    There is signal loss from HU to amp, unless you are going to install your amp right by your passenger's feet so they can kick it.
    Also, I doubt the signal loss is audible unless you run the RCA with your power wire.
    Team Gates
    Audio Answers Writer: www.mycarjams.com
    2002 SVT Focus
    Head Unit: Pioneer 8600
    Front stage: nothin
    Front Stage Amplification: nothin
    Low End: preparing for next season...
    AIM: jemorgan85
  1. Anyone Know Where I Can Get A High Power Alternator???? like 400amp??
    By AdidasRage16 in forum General Discussion
    Last Post: 10-27-2003, 08:00 PM
  2. road noise with high level inputs
    By BulldogSr04 in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2003, 01:14 AM
  3. MA audio big *** amp? thd too high for 13w7's?
    By d audio 450 in forum Amplifiers
    Last Post: 07-25-2003, 05:16 PM
  4. 39hz to high for daily?
    By SBLAZER in forum Enclosure Design & Construction Help
    Last Post: 07-20-2003, 09:02 AM
