Results 1 to 10 of 10
Reload Thread: does this sound right?
    bass maniak's Avatar
    bass maniak is offline Team Poundin Sound
    Aug 2002
    Faust, Alberta ( CANADA )
    30
    3,182
    113
    a box for 2 magnum d2s does it sound right?
    3.91319 subic feet before any displacment
    port tuned to 32 hz which is 14 inchs high and 3 inchs wide and 21.47 inchs long.
    if i am correct the port will take up .6523 cubic feet and each mag takes up .10 cubic feet which would add up to .852300 cubic feet.
    so including displacment the box would be 3.06089 cubic feet.
    did i calculate this box right?
    also does this sound right for a pair of mags b/c i think i might have screwed up with the sub parameters?
    if it helps any i am using winisd.
    Chuch AKA Tha Mad Scientist
    Team Poundin Sound
    Joker Kustoms
    Boost Junkie Motor Sports
    Street Poetry Productions
    Wreaking Havoc Records
    Aug 2002
    30
    3,182
    113
    Re: does this sound right?
    comone isnt there anyone that can tell me?????????????
    Team Poundin Sound
    Joker Kustoms
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    The only thing I see different is I got a port length of 22.75". But even if you go with 21.5" long you still get 32.5Hz (or so). To make thing a little bit easier for your self, just carry out to one decimal place. Often time you will find out even if the port is .25" longer, it may not make that big of a difference...maybe only like 1/8 of an Hz or something.
    Example: your box 4cu'
    [email protected] port should be 24" L
    [email protected] port should be 22" L
    [email protected] port should be 20.5" L
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Aug 2002
    30
    3,182
    113
    thanks for the help man. all i need to know now is if it sounds right for a couple of magnum d2s b/c im not 100% sure i got the parameters right on the d2.
    so if somone can tell me if this is right im ready to make the box.
    these are the parameters i got
    qts: 0.37
    vas: 38.5 liters
    fs: 32 hz
    re: 3.6 ohm
    le: 0
    xmax: 24 mm
    z: 0
    qms: 4.05
    qes: 0.41
    spl: 88.4 db
    pe: 600
    bl: 18.60
    dia: 12 inchs
    sd: 0.050 m^2
    are these parameters right for the magnum d2?
    once again the program i am using is winisd
    Team Poundin Sound
    Joker Kustoms
    Aug 2002
    30
    3,182
    113
    cant any one out there tell me????????????????????
    Team Poundin Sound
    Joker Kustoms
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    [email protected] your impatient!! LOL
    If you were to go with what you are saying, then your box after all displacement, would be 3.06089cu' after all displacement. I get 22.87" long for the port wich is 14" X 3" tuned to 32Hz. 24.4" L after sub displacement.
    To make things easier, let's only go to on decimal place...
    a 4cu' box with a port that is 14" X 3" needs to be 22" long. Using 3/4, the total port displacement will be 0.8. sub displacement you said is 0.1 per sub...so 0.2.
    4 - (0.8 + 0.2) = 3.0cu' of air space.
    Pretty much the same as you got.
    2006 Jeep Liberty
    *Vb = vol. in cu"
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    i would go larger for 2 magnums ported man...optimal should be pretty close to 2 cubes each AFTER all displacement. I'd look for about 1.9-2.1 cubes each...so 3.8-4.2 cubes after displacement. If you can get a lil more space for the box...i got exact plans for a magnum box at home that is 4 cubes after displacement and exact port that utnes it to 32hz exactly. LMK, and i'll get the measurements for you when i'm at home. peace
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    Aug 2002
    30
    3,182
    113
    i dont know if i can go much bigger man, thats why i am going to specs.
    but ill check out ur box anyway i just might be able to fit it.
    so 3 cubes tuned to 32hz wont be that good for a couple mags?
    Team Poundin Sound
    Joker Kustoms
  9. #9
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    i'd give them at least 4 cubes for two man. My AIM name is ngsm13...hit me up on there. peace
    NG
    nG - BSEE
  10. #10
    Aug 2002
    30
    3,182
    113
    i dont have aim
    and i dont have much more room then 36 by 15.5 by 15.5
    maybe the box shape u have would work tho pm me or just post it up.
    Team Poundin Sound
    Joker Kustoms
  1. Sub making strange sound
    By er1kkull in forum Subwoofers
    Last Post: 08-08-2005, 04:16 AM
  2. whi is my amp making this sound????
    By Juice in forum Amplifiers
    Last Post: 12-05-2003, 12:05 PM
  3. best sound blocks away
    By mr_f4ke in forum Subwoofers
    Last Post: 10-24-2003, 11:06 AM
  4. sound deadener
    By mrmafioso04 in forum General Discussion
    Last Post: 08-29-2003, 06:35 PM
  5. Subs hit no sound tho
    By paul83085 in forum Subwoofers
    Last Post: 07-31-2003, 10:44 PM
