Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Tri-way should i or not
    95RAM's Avatar
    95RAM is offline CarAudio.com Elite
    Nov 2003
    Jensen Beach, Fl
    31
    605
    I am going to buy a kenwood h/u with 2 preamps (front and rear). I will also put a us acoustics 65 watt by 4 channel amplifier that will power four 6 and 1 half inch speakers, also putting on a triway to the rear speakers to power an 8 inch sub. I would like to know if that is a good way to do it?
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    33
    5,152
    Re: Tri-way should i or not
    ya, it's not a bad way to do it if a seperate amp is not an option , so long as your amp can handle it.
    MSN - [email protected]
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
    95RAM's Avatar
    Nov 2003
    Jensen Beach, Fl
    31
    605
    Thanks second amp is not an option. I dont even think I can afford the first one.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Quote Originally Posted by Wonderbread
    Any typical 2 ohm stereo stable amp can handle it as long as the 3rd speaker is 8 ohms.
    95RAM's Avatar
    Nov 2003
    Jensen Beach, Fl
    31
    605
    would it really matter how many ohms the 3rd speaker was as long as you wired it to so it is a 4 ohm load
    Feb 2002
    Vancouver BC
    33
    5,152
    yes...
    it's got to be quite specific....
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Quote Originally Posted by 95RAM
    It HAS to be 8 ohms (DVC 4 or SVC 8 works) unless you have a bad *** amp. If it's less than 8 the amp will see less than 2 ohms stereo.
    Just look at the sub - (Assuming it's 8 ohms) if it's running in tri mode you're just running the sub from the bridged channels - since each channel effectively sees half the load that's the same thing as running in 4 ohms stereo. When you add to that the other two speakers already running in 4 ohms stereo - the result is your amp is seeing 2 ohms stereo.
    If you drop that sub to 4 ohms that means your amp is already running at 2 ohms stereo and when you factor in the other 2 speakers you get a 1.33 ohm load on each channel.
    95RAM's Avatar
    Nov 2003
    Jensen Beach, Fl
    31
    605
    oh, ok thanks for the knowledge. so it has to be 8 ohms. Thank you very much.
  9. #9
    95RAM's Avatar
    Nov 2003
    Jensen Beach, Fl
    31
    605
    Icon6 Re: Tri-way should i or not
    I am buying a Kicker Comp VR 03CVR84 eight inch sub( 4 ohms) can be wired to eight ohms. Is this a good idea?
    oh yea its a dual voice coil too.
  10. #10
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Hold on man. You can run 4 speakers (2 on each side in parallel) from channels 1 & 2 of the amp, then bridge the other 2 channels to the sub. You just wont get fading between the 2 sets of 6.5's. You don't want to run 4 channels to separate speakers and then also use 2 of them for a sub. You won't be able to lowpass the sub, or adjust sub power independantly of the speakers. Bad idea.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  11. #11
    Mar 2003
    Preston Ct.
    86
    you could use passive crossovers to block highs from subs and lows from mids and tweets, couldn't you CC
  12. #12
    Feb 2002
    Vancouver BC
    33
    5,152
    passive crossovers are never reccomended to be used on subwoofers... but yes, you could... or you could pick up a cheap active crossover to put inline.
  13. #13
    Mar 2003
    Preston Ct.
    86
    Hey Wonderbread my manual that came with my usx-4065 recommends just that for triway config. They recommend a 15.9mH lowpass filter inductor for the sub and high pass passive crossover network for your satilite speakers. Now I'm no expert but the manual says. Also 8Ohm sub is required. Thanks CC
  14. #14
    95RAM's Avatar
    Nov 2003
    Jensen Beach, Fl
    31
    605
    satilite speakers????
  15. #15
    Feb 2002
    Vancouver BC
    33
    5,152
    it says a passive for the SATELLITE speakers (in other in cabin speakers... not the sub.
