Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: engine noise, not ground, please help!!!
    SuckMikeHawk23's Avatar
    SuckMikeHawk23 is offline #1 Laker Hater
    Jan 2002
    626 California
    702
    ok, i installed my components and my relay today and now i'm picking up engine noise. i checked the ground, its all fine, what could the problem be? my rcas?? anything else. please list all possible causes of this so i can check it out tommorrow. it wasnt like this til today, so it had to be something i did or installed right?
    Team Caraudio.com
    2000 Honda Civic Coupe:
    Alpine CDA-7892
    MTX81000D
    US Acoustics USX4085
    Crystal Mobilesound CPE60S
    Crystal Mobilesound CSC60S
    2 E12KD2's
    4.7 cubic foot ported box
    AIM: TeamVicious23 and FishermanSteve23
    cfurtick's Avatar
    cfurtick is offline Member
    Mar 2002
    SC
    45
    1 Post(s)
    did you just put in a set of components and a relay for what? we need more info.
    i will help if i can
    Jan 2002
    626 California
    702
    i just added components in my front stage and added a relay to control my remote wiring. since i have 2 amps, i was told to ground the 2 amps to the same point. is this what i should be doing? also, i have a lightning audio cooling fan that worked fine a couple days ago, then i dropped my amp and had it repaired, and now the speakers make noise with the fan. how do i get rid of this? i would like to continue using the fan since summer is coming up. if anyone can tell me how i should run my wires from my amps and fans, then i'd appreciate it. thanks
    Team Caraudio.com
    Alpine CDA-7892
    MTX81000D
    2 E12KD2's
    Nolesman's Avatar
    Nolesman is offline Member
    Feb 2002
    Tallahassee, FL
    38
    75
    A few things I can think of. First double check that ground. The slightest bad connection can be overseen. Two, if your RCAs are close to the ground that can cause engine noise. Three, I see you have an Alpine running your mids/hi but if you changed that to the Fosgate watch out. Fosgates, unfortunately I have found, give you a good amount of feedback when running to your mids/hi. If the problem persists you can always buy a feedback thingy (sorry the name escapes me at this time). It hooks right onto your amp (very small about the size of a jewlery ring box) and is relatively cheap (about $15 bucks). Unfortunately it is not a cure all and can take away some of the crispness of your sounds. Hope this helps.
    HU: Kenwood CD w/ Kenwood Chg
    FRONTS: Kenwood DB+ Excelon 2-way 6.5"
    REAR: Kenwood 3-way
    MID/HI AMP: 400x4 Fosgate Punch
    SUB: 12' Kicker VR
    SUB AMP: 250x2 Fosgate Punch
    **Soon to come... anything but those front Kenwoods, possibly Infinity Perfect Seperates
    Jan 2002
    626 California
    702
    im stillin using an alpine to run my mids and highs, just a different model, the mrv-f400s. i guess i'll check my rcas tommorrow, but is there anything else that can be causing this prob?
    thanks
    Team Caraudio.com
    Alpine CDA-7892
    MTX81000D
    2 E12KD2's
    cfurtick's Avatar
    Mar 2002
    SC
    45
    1 Post(s)
    I think the feedback thingy nolesman is referencing is a Ground Loop Isolator. This should be used as a last resort though b/c as stated it will rob you of some voltage. Not so important on your sub amp but very important on your mid high amp. Also try grounding your relay at the same spot as you amplifiers. Just run a wire outside your carpet etc to check and see if this works.
    Hope this helps
    Jan 2002
    626 California
    702
    i think i've come to the conclusion that its a problem with the amp. is this possible? because i hooked up my sub rcas and wires to my mids and highs, and my mids and highs rcas to my sub amp, and the problem still existed in the mids and highs rcas and wires. how much should this cost to get fixed? and what exactly is the problem? anyone know?
    Team Caraudio.com
    Alpine CDA-7892
    MTX81000D
    2 E12KD2's
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Is this the amp you had fixed? If so they might have neglected to put back some shield or internal ground or something. Exactly what kind of noise are you getting, and is it there even with zero volume on the HU? How about with the RCA's unplugged? Does it change with the amp gain?
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  9. #9
    installerfreak's Avatar
    installerfreak is offline Junior Member
    Apr 2002
    arkansas
    32
    17
    just a suggestion but where might you have your amp mounted if you have it mounted to something that is also grounded to your first ground then you will pick up ground noise i hope i have been of some assistance bye
  10. #10
    Jan 2002
    626 California
    702
    to maylar: this is the amp i had fixed. the noise does happen when i have my head unit at 0 volume. with the rcas unplugged, theres no noise. and i haven't tried the gain thing yet, but i sure will soon.
    Team Caraudio.com
    Alpine CDA-7892
    MTX81000D
    2 E12KD2's
  11. #11
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    OK, if the noise goes away with the RCA's unplugged it's either ground loop noise (through the shields) or something getting into the cables (unlikely). You said it's alternator whine, so it's gotta be power/ground related. I'd try relocating the amp ground to another spot in your car. Worst case, maybe one of those isolator thingies. Might be worth asking the service people if they've ever seen that happen before.
    dave
  12. #12
    beastyle's Avatar
    beastyle is offline Senior VIP Member
    Mar 2002
    Holland, Amsterdam
    39
    272
    You should look at my post about engine sounds from last week.
    What to do when hearing engine sounds:
    1. Check (and clean) ground points (especially original car ground point)
    2. Check bobine hood (its on top of your dynamo)
    3. Place caliber LT2 filter
    If 1 and 2 dont solve your problem then place the filter otherwise DONT. The filter must be applied on each rca connection from the HU, if you experience problems of sound loss (subs might become a bit powerless) then place the amp that gets losses through the rear speaker ends of your HU
    This is (i think) the only good way to solve the problem (assuming you wired the rest ok)
    Humanity my mirror,
    Madness what I see
  13. #13
    beastyle's Avatar
    Mar 2002
    Holland, Amsterdam
    39
    272
    He's completely right btw, the LT2 is a Ground loop isolator which is exactly the device he described, i dunno if others have it, caliber has it for one and you should expect to pay around 20 bucks for it.
    GL
    Humanity my mirror,
    Madness what I see
  14. #14
    beastyle's Avatar
    Mar 2002
    Holland, Amsterdam
    39
    272
    Sorry bout all these posts but i dun like changing.
    YES: i'm for 99% sure thats its ONE amp that causes it. If you also hear a bit of scrambling sounds when you simply turn on your radio even when the engine does not run then you can be for sure its the amp. The only thing you could try (and this might sound stupid) is grounding your engine hood.
    You should have it even if you would put the volume towards zero
    Humanity my mirror,
    Madness what I see
  15. #15
    blaupunk's Avatar
    blaupunk is offline Junior Member
    Jun 2002
    Medina, OH
    36
    26
    Caliber LT2
    Where can i get the caliber lt2.
    Sweeeeeeeet
  1. cd player not working please help
    By craigmb in forum General Discussion
    Last Post: 02-27-2009, 08:47 PM
  2. Viper 791 Door Locks Not Working! Please Help out
    By yz_gt69 in forum Car Video, Security and Electronics
    Last Post: 01-23-2009, 07:21 PM
  3. INstall...ground...PLEASE HELP
    By jkafkazo in forum General Discussion
    Last Post: 03-25-2004, 02:31 PM
  4. Engine Noise On Amp, Please Help!
    By rucanunes in forum Wiring, Electrical and Installation Help
    Last Post: 04-16-2002, 02:59 PM
