Results 1 to 2 of 2
Reload Thread: amp for mids and 6x9s
    KARLEON's Avatar
    KARLEON is offline Livin' Legend
    Mar 2002
    Chattanooga, TN
    32
    1,993
    13
    how important is it for an amp to be on mids and 6x9s? Right now im in the process of buying some things. Do i need to wait to see if i like how it sounds without the amp or is it a must for the mids and 6x9s to be on an amp?
    ULTIMATE SOUNDS & PERFORMANCE Presents TWO DUDES SPL SHOOTOUT - 1st Place Champion
    REFERENCES: Bigbassman, Rangerman, Deserheat, Bavarian, Req, Vosschs, George, Mountaineer Man, NGSM13, Kingpin_jeffie, Harrison, Dustin19, Iceteebone, Electrodynamic, Memphis4L, RaiN, Mikemareen, Omietrice, Suleman36, Jmanpc, Kickerlivinloud, ibanender, massiveaudiocw, phoenix88, polecat, j3bus2k3
    cwzilly's Avatar
    cwzilly is offline Hates distortion
    Oct 2003
    Where I'm sent
    256
    3 Post(s)
    Re: amp for mids and 6x9s
    I suppose you could try running your mids (and twetters right, you do have twetters along with the mids?) off the reciever; but only if its a good power reciever, because i know that some factory recievers only do 4-5watts--yuck. As for the 6x9's, i suppose a amp could help, but where are they mounted? More than likely the 6x9's are on the rear deck in "free-air" style (no enclosure), so the bass response may not be "quality". The amp would boost the 6x9's midrange and twetters, but bass wont improve much without an enclosure, and more than lickly neiather will your fronts (thats where the sub comes in to play). Try improving your front midrang speackers enclosure; where are they mounted? Door locations are somewhat sealed enclosures, but they are resonant. Baffles, and sound-deadening materials help reduce resonant and lower road-noise that interfers with your speacker. The enclosure will affect your mid-range, so i would try improving the enclosure (baffles are cheap and easy to install). Personally, i prefer the rear speacker (6x9) to be used as "fill", and have a subwoofer do the lower frequencys, but if your expecting the 6x9's to do bass without an enclosure then i wish you luck?
    If you want to get the "most" out of your front midrang, then i personally would get an amp (that is if the front speackers are good in the first place). Amplifiers improve the sound from the midrange, and make the twetters shimmer more lifelike, but they basically have to be good speackers in the first place; amps on front speackers are only "necessary" if you come into distortion problems when you turn it up, or if thers no "loudness/fullfillness", so i would try running it off the reciever first, and try to improve the midranges enclosure...then see if you want more power.
    i don't know, maybe someone else can give better advice, or share there own experinces. I've never had a car with a good front speacker locasion; my car has the "unenspiring" dash mount small wimpy 3.5" speackers, so i cant really do much and cutting a hole in my door is a risk i dont want to tack.
    Calling us NO GOOD; you are the social enemy, us people change day to day...
  1. Replies: 10
    Last Post: 12-21-2003, 02:39 AM
  2. my 6x9s are clipping
    By BLACK12 in forum Speakers
    Last Post: 10-23-2003, 04:54 PM
  3. hwat amp should i get
    By Shetheid 069 in forum Amplifiers
    Last Post: 10-12-2003, 05:53 PM
  4. amp for a set of speakers (?)
    By Chamoru in forum Speakers
    Last Post: 10-05-2003, 06:06 PM
  5. 6x9's clipping
    By adr531 in forum Speakers
    Last Post: 09-02-2003, 01:33 AM
