Results 1 to 3 of 3
Reload Thread: Having a problem with Ignition wire
    sacarap's Avatar
    sacarap is offline Junior Member
    Dec 2001
    Hey everyone,<br />I am new here but could really use someone's help. I have a 1994 MItsubishi Galant. I am installing a Sony xplod cd player and have come across a problem. I had everything working but when I was mounting the player I had a loose wire (ignition wire) and it got grounded out with the car on. Now my cd player will not turn on with the car because that wire does not have any power coming from it. I know the radio is not blown because if i hook up the ignition wire strait to the constant 12+v then it will turn on.
    So my question here is: Would there be another fuse other then in the main fuse box, for that ignition wire? I put the volt meter on it and its definitly dead. I checked in the cars fuse box for a fuse, but it doesn't have one there. I am guessing that there is another fuse somewhere, but I'm not sure where!!
    Any feedback would be greatly appreciated !!!
    Thank you !
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    40
    1,057
    try to trace it from teh fuse box to the deck. I cant see why there would be another but its very possible...If you are using a harness adapter you may have meltd it around the connection try disconnecting it from there and test for power again.
    Mike
    Your friendly neighborhood subaru freak!
    IowaBoomer's Avatar
    IowaBoomer is offline Member
    Dec 2001
    Walnut, IA
    97
    I had the same exact problem. You will probably need to simply replace your "RADIO" fuse in yourfuse box, and all should be repaired.
    edit...I just read your post agian, and I don't know if you replaced the fuse, so I'm leaving it here.
    [ 12-14-2001: Message edited by: IowaBoomer ]</p>
    New and Improved system:
    JL12W7
    Alpine 7893
    JL 500/1
    Big *** Vented Box.
    Eclipse 4'' 2 ways
    All adding up to a new bigger number...can't wait for the new season.
  1. Problem with knu wire and dist.
    By Slayerx in forum Wiring, Electrical and Installation Help
    Last Post: 02-03-2011, 07:16 PM
  2. Problem with 12ga wire for sub...
    By microhaxo in forum Wiring, Electrical and Installation Help
    Last Post: 12-27-2008, 11:35 PM
  3. Problem with my power wire
    By NeedDirections in forum Wiring, Electrical and Installation Help
    Last Post: 10-24-2007, 06:27 PM
  4. Having a problem with noise in my uncles system...HELP
    By focused313 in forum Wiring, Electrical and Installation Help
    Last Post: 08-05-2007, 09:22 PM
  5. having a problem with my left diamond m6 sub
    By iLL-Faded in forum Subwoofers
    Last Post: 07-02-2004, 11:35 AM
