I want to know if it'd be safe and ok to splice into my wire harness for my deck and add a power wire that can power my police scanner?
run a separate fused power wire to either your battery or fuse box.
Feedback link: http://www.caraudio.com/forum/search...archid=5825080
ty
might want to check local laws, in some states unless you are a fire fighter/policeman etc. its illegal to have one in your car or on you
refs
woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
Now designing / building boxes.
(Only building sealed and aero port boxes.)
PM me.
Feedback Thread
Refs: MSW Danny, atsaubrey (great seller), ampjunkielikeme, wgsj_fortvalley, tEh koRnDog, bad @SS chevy, Nismos14 (who is the man.)
I would make a new wire run from your batt. and fuse it with a switch
HU: DEH-80PRS
Doors Deadened
Front Stage: Rainbow SLC 265
Front Stage Amp: Image Dynamics i2600
Sub: Dayton RSS210HF-4 8"
Sub Amp: Image Dynamics i2300
Wire: Knu
In IL it is not illegal to have a scanner. You should determine how many watts/amps the scanner is rated for. Looking up the model specs online should give this info. This will allow you to determine if you can splice into an existing power wire or if you'll have to run a new one.
Also keep in mind that if you run RCAs/amps, you could possibly induce ground loop noise if you ground the scanner poorly.
System:
Pioneer P800PRS, 180A EA HO Alt, Kinetik HC1400
Memphis ST1500D, Eclipse 4100
RD 15" Elite, Polk MMC6500
Not running active...yet
if it does draw a lot of power and needs its own dedicated power wire you can always use a relay to hook it up to an ignition fuse so it's still only on when the car is...
Bookmarks
