Results 1 to 2 of 2
Reload Thread: cut through?
    Puff the dragon's Avatar
    Puff the dragon is offline Junior Member
    Dec 2001
    ohio
    15
    cut through?
    I have a 99' Dodge Dokota R/T regular cab with 6 MTX 8000 series 12's and 3 8100D 1500w amps in the bed. I have a 8" x 40" cut through in the cab but since they are 12" subs, they are pounding on the sheet metal of the cab and about half the sound is getting through to the dash. I can't really cut any higher because of wire harnesses from the factory. Help me out if you got any ideas, I am only hitting 148! With 6 12's it should be a bit higher.<br /> Thanks<br />jesseborgelt@hotmail.com[/EMAIL]
    This is my view only and should be saw as just that. I am not responsible for ****.
    <Bassik LowZ>'s Avatar
    <Bassik LowZ> Guest
    hmmm... have you ever considered an audio control wave guide? this lets you adjust the BASS wave frequienty futher from.... or closer into the cab... check it out on Audiocontrols site...later dude
  1. where to find the cut-through boot?
    By RumbleNTheTrunk in forum Enclosure Design & Construction Help
    Last Post: 06-06-2006, 07:34 PM
  2. cut through, need help
    By seth350 in forum Enclosure Design & Construction Help
    Last Post: 08-02-2005, 12:27 PM
  3. Cut-through
    By Jplaya135 in forum Enclosure Design & Construction Help
    Last Post: 06-13-2004, 04:57 PM
  4. cut through
    By callahanianhunk in forum Subwoofers
    Last Post: 04-04-2004, 10:08 PM
  5. any one w/ half a brain plz help- cut through?
    By Puff the dragon in forum Subwoofers
    Last Post: 12-16-2001, 12:37 AM
