Results 1 to 7 of 7
Reload Thread: where can i find my factory amp
    chinxtaboi's Avatar
    chinxtaboi is offline CarAudio.com Elite
    Jul 2002
    tx
    33
    795
    i need to bypass factory amp to get sound in my speakers.....
    where can i find it!!!??!?!?!?!?!
    eengrms's Avatar
    eengrms is offline CarAudio.com Elite
    Feb 2003
    USA
    41
    556
    Re: where can i find my factory amp
    You could put all your questions under one post rather than creating a hundred of them, makes it easier to answer...
    You do not need to bypass the factory amp, per-say, you just need to run new speaker wire to all of the speakers from your new HU.
    Let me ask you this- if you found your factory amp, what are you going to do with it? You think you can just run a new set of RCA's to it? Factory amps don't have RCA inputs. They have proprietary 36-40pin connectors, and good luck figuring out what each wire does as there is no specific color coding to them. Maybe if you worked in a shop and could get your hands on a wiring diagram, but otherwise you're **** out of luck.
    JaJay721's Avatar
    JaJay721 is offline Senior VIP Member
    May 2003
    NJ
    229
    Well what car do you have? That would be useful information. Common places for factory amps is under the passenger/driver seat or somewhere in the trunk.
    chinxtaboi's Avatar
    Jul 2002
    tx
    33
    795
    well.......its a 1999 yukon denali...
    your saying i have to run wires from the headunit to all the speakers throughout the car...?
    Radar's Avatar
    Radar is offline Old balls
    Feb 2003
    Earth
    2,052
    My factory amps were being a ghetto with my new HU, and i didnt feel like running new wire, so I dropped $40 and saved me a hell of a lot of time and had BB bypass em.
    JaJay721's Avatar
    May 2003
    NJ
    229
    Yes. Speakers run off wire. If your amp is broken or unused, you need to run wire from your speakers to some power supply (IE headunit).
    eengrms's Avatar
    Feb 2003
    USA
    41
    556
    You should be able to get a bypass module for that vehicle.
    Check here:
    www.autotoys.com
