Decisions?Decisions?
Ok fellas,
Help a fellow forum member out.
I am about to get a Tsunami GXA 1000(hopefully) to run my HC. I am also in the light of a second HC.
Problem:
I'm sure I want the second HC but its QVC and when wired to my current HC I can only do a 2-ohm load. Which should I get first the HC or the Tsunami amp? I need the 2002 HC and not sure how many will be left. About to get a great deal on a Tsunami and its still available after I lost out on a previous attempt to buy.
What would you do? Of course I would have to search for a second Tsunami amp to run both HCs but I could get 2500wtts maybe @ 2-ohms(So I've read), which would be perfect. I can run only one HC until I was to get the second amp but who's to say either will be easy to find later.
Depending on if someone contacts me back for payment which would you get first?
2006 Titan XE
Under construction!
Bookmarks
