Results 1 to 5 of 5
Reload Thread: power problem
    <ryan>'s Avatar
    <ryan> Guest
    power problem
    My lightning 2.200 amp (strike) has a problem. It all of a sudden stopped running power to the sub and the amp doesn't light up..i hooked a power tester up to it and it showed that it was running power...i tested all the fuses...i also took it into the local shop and they said there was nothing wrong with the amp...WHAT IS THE PROBLEM?!?!?!? <img src="confused.gif" border="0">
    LegendZ28's Avatar
    LegendZ28 is offline Member
    Dec 2001
    New York
    45
    [quote]Originally posted by &lt;ryan&gt;:<br /><strong>My lightning 2.200 amp (strike) has a problem. It all of a sudden stopped running power to the sub and the amp doesn't light up..i hooked a power tester up to it and it showed that it was running power...i tested all the fuses...i also took it into the local shop and they said there was nothing wrong with the amp...WHAT IS THE PROBLEM?!?!?!? <img src="confused.gif" border="0"> </strong><hr></blockquote>
    If there's no problem with the amp, then there might be a problem with the sub.
    Lanzar 1200D<br />(2) Audiobahn 1200EU<br />JVC KDSH99 (MP3 Deck)<br />Infinity Components (4 Mids, 4 Tweets)
    <Bassik LowZ>'s Avatar
    <Bassik LowZ> Guest
    A problem with the sub? LOL there is no problem with the sub that will make the amp NOT COME ON... **** dude weres your brain lol anywayz
    retrace those wires nice and slowly not leaving out any detail... check all terminal connections and all wires for breacks or cuts in them... its hard to say what causing it without actually looking at it
    LegendZ28's Avatar
    Dec 2001
    New York
    45
    [quote]Originally posted by &lt;Bassik LowZ&gt;:<br /><strong>A problem with the sub? LOL there is no problem with the sub that will make the amp NOT COME ON... **** dude weres your brain lol anywayz
    retrace those wires nice and slowly not leaving out any detail... check all terminal connections and all wires for breacks or cuts in them... its hard to say what causing it without actually looking at it</strong><hr></blockquote>
    If you had actually read his post you would have seen that he said the LIGHT doesn't come on, but he tested it with a power light and the amp is running power. He also took it to a shop that says nothing is wrong with the amp so obviously they tested it to see if the amp was running power as well.
    <Bassik LowZ> Guest
    regardless, a blown, or F'ed up sub wouldnt cause an amp not to power up.... but i may have took your statement wrong and i was just busting a little cheap joke at you, nothing serious...so dont get your ******* in abunch
    let me ask this...<br />Did the LED's on the amp power up when they tested it at the shop? if the LEDS are just burned up on the amp, then yes it is more then likely the sub has a coil froze up.
  1. Power Problem? Alternators?
    By snapperhead in forum Wiring, Electrical and Installation Help
    Last Post: 03-03-2003, 10:16 PM
  2. Carputer power problem
    By Freezer Burn in forum Wiring, Electrical and Installation Help
    Last Post: 02-28-2003, 11:01 AM
  3. HU Power Problem!!
    By SOUNDSTREAM-LNP in forum Wiring, Electrical and Installation Help
    Last Post: 12-24-2002, 03:17 PM
  4. Power problem
    By xin in forum Amplifiers
    Last Post: 11-06-2002, 06:51 PM
  5. Power problem
    By Inferno13 in forum General Discussion
    Last Post: 08-12-2002, 03:44 PM
