Results 1 to 3 of 3
Reload Thread: 4 Gauge Or New Amp?
    BRONXHEART's Avatar
    BRONXHEART is offline Junior Member
    Mar 2008
    bronx, ny
    13
    Icon32 4 Gauge Or New Amp?
    My Buddy Wired My System In My Expedition, I Have A Punch P400 4 Ch amp Hooked Up To My pioneer door speakers And A Punch P500 2ch amp Hooked Up To My 2 P2's 12's In A Box. He Used 8 Gauge Wire for Everything. Someone Told Me It Would Hit Alot Harder If He Ran 4 Gauge Wire, It's Loud And Clear But it seems like it should hit harder, Should I change the wire to 4 gauge, or Get A Bigger Amp? Any Suggestions Would Be Greatly Appreciated.
    dipitydoo's Avatar
    dipitydoo is offline CarAudio.com Elite
    Apr 2006
    St. Louis, MO
    559
    Re: 4 Gauge Or New Amp?
    well, if you get a bigger amp, you're going to need bigger wires anyway. you may get less voltage drop by upgrading to larger wire, but not likely audible in this case. you should be concerned with proper fusing at the battery to protect the wire.
    Enellz's Avatar
    Enellz is offline The Triple O.G.
    Feb 2008
    Louisville, KY
    2,376
    first off how are the subs wired, because the specs say 500 rms @ 2 ohms which is decent, and yes I wouldnt had use a 8 awg wire. I pretty sure the amp manual even said use AT LEAST A 4 AWG.
    2003 CHEVY TRAILBLAZER
    AKA The Batmobile
    Pioneer 6000UB
    Sundown SAZ-3000D
    (2) Audio Q HDC3's
    Kinetik 2400
    40' of 1/0 Gauge
    A 38 HZ Box
    KICK ***!
