Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 60
Reload Thread: Is it ok to turn the Gain all the way up, if sub is underpowered ???
  1. #16
    Rookie_80's Avatar
    Rookie_80 is offline CarAudio.com Elite
    Oct 2007
    Houston,tx
    1,818
    Re: Is it ok to turn the Gain all the way up, if sub is underpowered ???
    Quote Originally Posted by Alpineinstaller View Post
    Yea mang.......turn that **** up, the gain is like one big volume knob.....
    good one
    BASS+CLEAR SOUND
  2. #17
    btdickey99's Avatar
    btdickey99 is offline I Hate the Tarheels
    Jul 2007
    Burlington, NC
    30
    6,627
    49 Post(s)
    Quote Originally Posted by BUMPING150S View Post
    Or you could set ur gains the right way with a DMM or O Scope?
    x10000
    2000 Chevy Silverado 4x4
    REFS: texasound82, duece212, flipside1212, l7runner, oxsign, tapout, Busabob, NightDrifter05, GOOSE, GohillaAudio, jmanpc, fwb_1234, Fusion_Freak, arkadiy, LoggedOut, Kmanian, KyleBechtold, Beerdrnkr, R/T Pimp, Louie68, dropped_tb, audiobaun, Psychodrama, JBLCAMRY, yunvme666, Buckyboy, CRXBMPN, bpres9991, Worlddre, KCha, operationcougar, Vitveet, and many more...
  3. #18
    grampi's Avatar
    grampi is offline CarAudio.com Elite
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    I can tell you from experience, don't do it. I had the gain and the bass boost turned all the way up on my sub amp (which still didn't provide the amount of output I was looking for) which caused blown fuses, and I also think that's what caused my HU's preamp output circuit to blow. Set your gains using a DMM, then if you need more output, either get a more powerful amp or more efficient subs.
  4. #19
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
  5. #20
    PuffDaddy_d's Avatar
    PuffDaddy_d is offline Engineering @ Texas Tech
    Feb 2008
    Houston & Lubbock, TX
    26
    Quote Originally Posted by Rookie_80 View Post
    Subwoofer setting is on. Now if guys had pioneer HU id be able to explain what options it has.
    For example it has option SLA (source level adjustment) if u increase it u get more bass but it distorts a lil bit
    The sub cutt of frequency is set 80.
    HPF high pass filter is at 80.
    The SLA feature is designed to help you match the volume levels of the CD source to your Radio source.... that is all. It is not a bass adjustment because all frequencies are affected equally. By increasing the SLA, you are making the CD volume louder, and by decreasing it you are making the Radio volume louder.
    "The goal of every super sub builder is to eclipse the current king, the Funky Pup. No one may get there, but we keep trying..."
    -- Dan Wiggins --
  6. #21
    Blove1991's Avatar
    Blove1991 is offline Single Cabin
    Jan 2007
    North Carolina
    1,801
    1 Post(s)
    Set gains with DMM, if your still not satisfied with output, try purchasing a more powerful amp.
    / thread
    Daily: 94 POS Accord
    Project: 86 2dr Chevy Blazer
    Refs: BMXbikes, Wragold, Tommyk, ThumpinTitan, NewAgeKing, BushJ311, l7runner, jco1385, Big Joker, SPY, xxxbasshead
  7. #22
    Rookie_80's Avatar
    Oct 2007
    Houston,tx
    1,818
    Quote Originally Posted by Blove1991 View Post
    / thread
    Not trying to sound ignorant but how do u do that?
    I read this info. Is this correct?
    The sub is Dual voice coil 4 ohm sub, run in parallel to get 2 ohm load.
    My amplifier is rated for 891 RMS watts at 2 ohms.
    So i guess my target voltage is 42.2 (sqrt of 891X2)
    so i should:
    - Disconnect the sub from amp.
    - Turn my gain/input sensetivity all the way down. Turn off bass boost and crossovers.
    - Turn on my head unit. Set the volume control to 3/4 of full. Set all equalization to zero. Turn off loudness.
    - Probe my amplifier's outputs. (what do they mean by that?)
    - Insert a CD (any CD or it has to be a TESt tone CD?).
    - Play music and adjust the gain until you reach my target voltage (42.2).
    - Reconnect sub and verify proper operation. Set crossovers and EQs
    BASS+CLEAR SOUND
  8. #23
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Get a more powerful amplifier if it's not loud enough...
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  9. #24
    2002XLT's Avatar
    2002XLT is offline Thats right bishes...
    Jun 2007
    H-Town, TX
    7,005
    12 Post(s)
    so i should:
    Pretty much, yes.
    Probing means putting the leads of the DMM into the speaker outputs on the amp.
    And i would suggest using a test tone. You can get them off ROE.
    And if you dont like the output after that you will need a bigger amp.
    Refs-
    http://forums.explorerx.com/index.php?showtopic=11984
    http://www.caraudio.com/forum/showthread.php?t=245865 http://www.caraudio.com/forum/showth...59#post3482859
    Ebay Feedback- http://myworld.ebay.com/lilchard1969/
    Vehicle-
    2002 Explorer XLT
    R1 Concepts Cross drilled/slotted rotors w/ performance pads, K&N FIPK Intake, Removed roof racks, Debadged, Tinted tails, Clear Corners, Upper and lower Billet Grilles,5% Tint all the way around
    Stereo- All stock.
  10. #25
    WrenchGuy's Avatar
    WrenchGuy is offline CarAudio.com Veteran
    Sep 2007
    East Tawas, MI
    2,023
    Star Over. Turn the HU up with 50hz until the speakers start distorting. See if you get a better volume setting. 3/4 is an average my Pioneer went well above 3/4 before clipping. (58 out of 62). Then use the DMM for your gains. After that you just might not have enough power.
  11. #26
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    I always buy I good 50% more power than what I think I need...like in your case, I would have bought a 1200-1500 watt amp.
    2,500+ designs since March 2011
  12. #27
    Jeremy M's Avatar
    Jeremy M is offline CarAudio.com Elite
    Oct 2007
    Moxee, Wa
    1,979
    3 Post(s)
    i have the same deck, what is your subwoofer volume on, on the deck?
    do u have loud on?
    06' Acura MDX
    Pioneer F90bt
    JL Audio XR 653csi
    Alpine PDX 150.2
    JL Audio 13TW5
    Alpine PDX 1000.1
    2010 Mazdaspeed3
    Alpine CDA-9887 (w/ imprint)
    2 sets of ID OEM 6.5
    2 sets of ID XS-28
    PG Xenon x200.4
    1 Atomic 5000.1
    2 RD Alpha D2 15's
    Tons of deadner and wire!
  13. #28
    Rookie_80's Avatar
    Oct 2007
    Houston,tx
    1,818
    Quote Originally Posted by Jeremy M View Post
    do u have loud on?
    Well with loud on (set on MIDS) i get decent bass. I was saying with loud off i don get much.
    you have your on? what are your HPF, SLA, SUB2, EQ settings?
    when you say subwoofer volume what do u mean?
    BASS+CLEAR SOUND
  14. #29
    Jeremy M's Avatar
    Oct 2007
    Moxee, Wa
    1,979
    3 Post(s)
    There's a subwoofer volume control built into the deck, its the button closest to the volume knob on the upper left, press it once, it should allow u to turn off and on the subs, press it again and it brings u to the volume control of the subs.
    sub- 50hz
    mids- 80hz
    loud- high
    eq- off
    06' Acura MDX
    Pioneer F90bt
    JL Audio XR 653csi
    Alpine PDX 150.2
    JL Audio 13TW5
    Alpine PDX 1000.1
    2010 Mazdaspeed3
    2 sets of ID XS-28
    PG Xenon x200.4
    1 Atomic 5000.1
    2 RD Alpha D2 15's
  15. #30
    Rookie_80's Avatar
    Oct 2007
    Houston,tx
    1,818
    sub- 50hz
    mids- 80hz
    loud- high
    eq- off
    Well then u r talking about SUB-W2 control. Mine is actually is set at 80Htz. Im gon try 50Hz today then.
    there's also Sub-W1 control thats used to turn the sub on or off, and also sets reverse or normal phase.
    Which amp and sub do u have?
    BASS+CLEAR SOUND
